Home » Newcomers » Newcomers » problem solved
icon7.gif  problem solved [message #508224] Sun, 17 January 2010 20:05 Go to next message
No real name is currently offline No real nameFriend
hi,
I figured out my problem. Eclipse is now off and running.
Thanks much.
[Updated on: Sun, 17 January 2010 20:40]
Report message to a moderator
Re: eclipse can't find Java VM even with "-vm" option [message #508225 is a reply to message #508224] Sun, 17 January 2010 16:12 Go to previous messageGo to next message
David Wegener is currently offline David WegenerFriend
sjpschmid@gmail.com wrote:
> My newly downloaded eclipse will not start because it can't find the
> Java virtual machine. I do have a Java installation, and even tried the
> command line option "-vm", but no luck. Here are the specifics:
> my machine: Windows Vista Home Premium 64-bit
> my eclipse: eclipse-SDK-3.5.1-win32-x86_64.zip
> I installed it into "C:\Program Files\Eclipse".
> my java: is located in "C:\Program Files(x86)\Java\jre6\...
> The command I tried running is:
> eclipse -vm "C:\Program Files(x86)\Java\jre6\bin\javaw"
> The error message I get is: "No Java virtual machine is found after
> searching the following locations: "C:\Program
> Can anyone help?
> If I need to provide any more information about my configuration, please
> let me know. Thanks much.
There is no file called javaw on Windows. Executables have a .exe
extension on Windows. Add .exe onto the end of javaw ("...\javaw.exe").
Re: eclipse can't find Java VM even with "-vm" option [message #509260 is a reply to message #508225] Thu, 21 January 2010 14:18 Go to previous message
Eric Rizzo is currently offline Eric RizzoFriend
>> the command line option "-vm", but no luck. Here are the specifics:
>> Can anyone help?
>> please let me know. Thanks much.
Also, see http://wiki.eclipse.org/Eclipse.ini
Previous Topic:Eclipse won't start up
Next Topic:.project file missing
Current Time: Fri Apr 20 18:25:41 GMT 2018
Powered by FUDForum. Page generated in 0.03138 seconds
