| Using Ruby Debugger [message #507911] |
Fri, 15 January 2010 02:27  |
podensk Messages: 9 Registered: July 2009 |
Junior Member |
So far in all of my experiments I have been unable to get the debugger to work in DLTK for ruby.
I tried with Mac OS X + ruby 1.8.7 on Eclipse 3.5.1 with DLTK 1.0. No luck.
Tried also with Mac OS X + ruby 1.9.1p376 on Eclipse 3.5.1 with DLTK 1.0. No luck.
Are there any docs that describe the steps to get set up to use the ruby debugger?
All of the other features in the editor work quite nicely. DLTK appears to be a very nice IDE for ruby scripting except for not being able to get debugger working.
Thanks!
| Re: Using Ruby Debugger [message #526397 is a reply to message #507911] |
Sat, 10 April 2010 06:41   |
Christian H Messages: 2 Registered: April 2010 |
Junior Member |
Hi there,
that works perfectly fine for Ruby 1.8.x, but since i'm using Ruby 1.9.1, i can't even install the "ruby-debug" gem, because it tells me "can't handle 1.9.x" yet.
So I tried with "ruby-debug19" (and ruby-debug-base19 etc). Soon I figured that DLTK isn't looking in the .../gems/1.9.1/gems/ folder for the plugin (gabe me the error that "ruby-debug" wasn't installed), so I edited the source of org.eclipse.dltk.ruby.fastdebugger to do so, saw that there were some problems with ruby 1.8.x style case-expressions in org.eclipse.dltk.ruby.abstractdebugger and fixed them also.
Now I don't get the "can't find ruby-debug" error anymore, but instead after a while hanging at 92 % org.eclipse.dltk.launcher throws an exception that initalizing the debugger was taking too long and thus terminated the whole thing.
I figured that I am using the R2.0 dev version of DLTK, since that may cause the problem, I will try the R1.0 Stable Release. Is there anything else I could do to get this up and running in case that's not the solution?
kind regards,
christian
| Re: Using Ruby Debugger [message #529122 is a reply to message #526397] |
Fri, 23 April 2010 02:44   |
Alex Panchenko Messages: 332 Registered: July 2009 |
Hi Christian,
I think that code was not tested with ruby 1.9.
It seems that installation paths could be OS specific, so you can just
disable the check of ruby-debug gem - there is a checkbox in Preferences
- Ruby - Debug - Engines - Fast Ruby Debugger.
Anyway it's better to work with DLTK 2.0 as this is the version under
development now.
I'll try to test it with ruby 1.9. If you've found what should be
changed in DLTK could you please share your findings?
Alex
On 10/04/10 17:41, Christian H wrote:
> Hi there,
> kind regards,
> christian
| Re: Using Ruby Debugger [message #529145 is a reply to message #529122] |
Fri, 23 April 2010 04:23  |
Junior Member |
Hi Alex,
actually the path IS Os specific, but thats covered by the code in DLTK, for you only have to look at the path relative to the installation dir. but the Version of ruby was hard coded in there, so I had to change it to 1.9.1. Just disabling the check doesn't work.
I'll post a list of the changes I made to the DLTK Sources, soon. But anyway these didn't get the debugger to work. I ended up with a error message that didn't tell me anything but "Error". So I can't go any further at the moment.
greetings
christian
FUDForum. Page generated in 0.02764 seconds
