Home » Eclipse Projects » Subversive » How to install SVN connectors manually(SVN Connector)
How to install SVN connectors manually [message #507812] Thu, 14 January 2010 13:14 Go to next message
Ray Hurst is currently offline Ray Hurst
I have the SVN connector zip file. How do I install the SVN connectors manually. I tried unzipping the file into the eclipse folder but the program still insists on going to the website to get the and SVN preferences do show them as being installed. They are in the eclipse plugins directory.
Re: How to install SVN connectors manually [message #508265 is a reply to message #507812] Mon, 18 January 2010 03:20 Go to previous messageGo to next message
Igor Burilo is currently offline Igor Burilo
Hello Ray,
You can install connectors through Eclipse Update Mananer(p2), in Eclipse
3.5 select menu Help/Install New Software... then click Add... button near
'Work with...' combo and in opened Add Site dialog click Archive... button
to select connectors archive in file system.
>plugins directory.
Re: How to install SVN connectors manually [message #508738 is a reply to message #508265] Tue, 19 January 2010 23:17 Go to previous messageGo to next message
I need to know how to install them manually. Eclipse.org is blocked so I can't use the Install software option. I used to be able to unsip the connectors into the eclipse directory but this doesn't work anymore.
Re: How to install SVN connectors manually [message #509057 is a reply to message #508738] Thu, 21 January 2010 04:50 Go to previous messageGo to next message
Hello Ray,
If you already have a zip of connectors (archived update site), you can
follow steps that I described in previous comment; it doesn't require to
access Eclipse.org server because you install connectors from your local
file system (also connectors are located not on Eclipse.org server but on
Polarion server); here you need to point to a location of connectors archive
on local file system.
Depending on your Eclipse version, you can unpack connectors in Eclipse's
dropins: http://wiki.eclipse.org/Equinox_p2_Getting_Started
Re: How to install SVN connectors manually [message #642992 is a reply to message #507812] Fri, 03 December 2010 10:37 Go to previous messageGo to next message
Jason  is currently offline Jason
Where did you find the zip files? I can only locate the jar files here:
http://community.polarion.com/projects/subversive/download/e clipse/2.0/helios-site/
When i tried to install manually by point to the jar files it doesn't work.
Re: How to install SVN connectors manually [message #643007 is a reply to message #642992] Fri, 03 December 2010 11:04 Go to previous message
nvm i found it
It is under the Archives area
http://community.polarion.com/projects/subversive/download/e clipse/2.0/builds/
Previous Topic:History view - Show merged revisions on demand
Next Topic:Subversive compare very slow
Current Time: Tue Oct 08 07:52:32 EDT 2013
Powered by FUDForum. Page generated in 0.01551 seconds
