Home » Language IDEs » Java Development Tools (JDT) » Ant editor warning about missing AnnotationProcessorFactory class
Ant editor warning about missing AnnotationProcessorFactory class [message #506515] Thu, 07 January 2010 14:58 Go to next message
David M. Karr is currently offline David M. KarrFriend
I'm building an app using JAXB and other frameworks. The Ant build works fine from both Eclipse and the command line.
The one minor annoyance I have is that Eclipse is giving me a warning on the taskdef for "schemagen":
<taskdef name="schemagen" classpathref="schemagen.classpath" classname="com.sun.tools.jxc.SchemaGenTask">
<classpath>
<fileset dir="lib" includes="*.jar"/>
</classpath>
</taskdef>
The warning is:
"A class needed by class com.sun.tools.jxc.SchemaGenTask cannot be found: com/sun/mirror/
apt/AnnotationProcessorFactory"
This class is found in the "tools.jar" of the JDK. I noticed that in the list of jars associated with the JRE, that jar is not included. So, I tried including it in both the project build path and the classpath for the Ant run configuration. Neither of those made any difference. It's still displaying that warning.
Re: Ant editor warning about missing AnnotationProcessorFactory class [message #506725 is a reply to message #506515] Fri, 08 January 2010 23:34 Go to previous messageGo to next message
Walter Harley is currently offline Walter HarleyFriend
"David M. Karr" <davidmichaelkarr@gmail.com> wrote in message
news:hi5eep$sq2$1@build.eclipse.org...
> <classpath>
> </classpath>
> </taskdef>
> The warning is:
> com/sun/mirror/
That class is also redistributed as part of the org.eclipse.jdt.apt.core
plugin, so you may be able to get it that way, if that helps.
Re: Ant editor warning about missing AnnotationProcessorFactory class [message #506770 is a reply to message #506725] Sat, 09 January 2010 15:11 Go to previous message
Thanks, but I don't see how that can help. I already put the tools.jar with the class in the project classpath. I can't imagine that putting a different jar with that same class in the classpath would make any difference.
Previous Topic:Getting Class information from Eclipse
Next Topic:Eclipse builder problem
Current Time: Sun Feb 25 20:16:42 GMT 2018
Powered by FUDForum. Page generated in 0.01984 seconds
