Home » Eclipse Projects » Buckminster » maven dependency scope
maven dependency scope [message #506508] Thu, 07 January 2010 13:46 Go to next message
Originally posted by: pajai.extrabright.com
Hi all,
Maven defines scopes with respect to dependencies. By default a
dependency has the scope 'compile', unless it is specified otherwise
(e.g. 'test').
Example (from pom.xml of artifactA):
<dependency>
<groupId>sample.group</groupId>
<artifactId>artifactB</artifactId>
<version>1</version>
<scope>test</test>
</dependency>
When in a bundle I have a dependency to artifactA, which defines a
test-scope dependency to artifactB (see previous snippet), then I am
generally not interested to fetch artifactB.
My question: can I with Buckminster restrict the transitive dependency
fetching to the 'compile' scope?
Thanks in advance.
Cheers!
Patrick
Re: maven dependency scope [message #506736 is a reply to message #506508] Sat, 09 January 2010 05:36 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas HallgrenFriend
Hi Patrick,
Limiting based on scope sounds very reasonable. It is not yet implemented though, so a bugzilla for
this would be appreciated. A couple of questions since you seem knowledgeable in this area:
- Is the scope always present?
- If it's not present, does it always default to 'compile'?
- Would a solution where you can define the scope in a maven RMAP provider be OK (default being
'compile')
Thomas Hallgren
Patrick J. wrote:
> Hi all,
> (e.g. 'test').
> <dependency>
> <scope>test</test>
> </dependency>
> Thanks in advance.
> Cheers!
> Patrick
Re: maven dependency scope [message #507032 is a reply to message #506736] Mon, 11 January 2010 12:46 Go to previous messageGo to next message
Hi Thomas,
Thanks for your answer. Ok, I'll write a bugzilla for this.
The scope is not always present. It is per default 'compile'.
Yes. (As of the latest maven 2 version).
> provider be OK (default being 'compile')
This might be a good solution (although I am not a maven guru). There is
more info about the maven scopes at [1]. There are 6 scopes defined
which have each a different behavior with respect to transitive
dependency inclusion (e.g. a compile-scope dependency will be a
compile-dependency of all dependent projects while a test-scope
dependency will affect only the project defining it). Perhaps a short
reflection with a maven guru on that topic would be good (since maven is
a world in itself).
Patrick
[1]
http://maven.apache.org/guides/introduction/introduction-to- dependency-mechanism.html#Dependency_Scope
Re: maven dependency scope [message #507464 is a reply to message #507032] Wed, 13 January 2010 15:08 Go to previous message
Hi Thomas,
Here is the bugzilla entry to that:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=299491
Cheers!
Patrick
Previous Topic:import of root files, root folders - but the directory structure will be flatten
Next Topic:Updating a self made eclipse product (site.p2) problem
Current Time: Fri Jun 22 23:07:36 GMT 2018
Powered by FUDForum. Page generated in 0.01736 seconds
