Home » Archived » Memory Analyzer (MAT) » How to setup MAT in Eclipse SDK(How to setup MAT in Eclipse SDK)
How to setup MAT in Eclipse SDK [message #506039] Tue, 05 January 2010 20:12 Go to next message
Jamal  is currently offline Jamal Friend
Hi All,
I am new to eclipse, using Eclipse SDK for java.
And also used for debugging my stand alone java application.
My Question is how to setup MAT in eclipse and analyze my project.
Any Help.
Re: How to setup MAT in Eclipse SDK [message #506106 is a reply to message #506039] Wed, 06 January 2010 08:14 Go to previous messageGo to next message
Andreas Buchen is currently offline Andreas BuchenFriend
Hi Jamal,
to analyze your standalone application, you first need a heap dump which was taken while your application is running. The Memory Analyzer does not analyze source code or anything, but an image of the object in memory at runtime.
Read here how to get an heap dump:
http://wiki.eclipse.org/MemoryAnalyzer#Getting_a_Heap_Dump
Once you have that dump, you can either use the standalone version of the MAT (just open the dump and go):
http://www.eclipse.org/mat/downloads.php
Or alternatively install MAT into your Eclipse using the update manager (it's on the Galileo update site).
Andreas.
Re: How to setup MAT in Eclipse SDK [message #506188 is a reply to message #506106] Wed, 06 January 2010 08:53 Go to previous message
Thanks Andreas. let me give a try.
Previous Topic:Retained heap in histogram view
Next Topic:Request For Alternate View Of LinkedList
Current Time: Sat May 26 17:57:25 GMT 2018
Powered by FUDForum. Page generated in 0.02085 seconds
