Home » Eclipse Projects » Rich Client Platform (RCP) » Re: org.eclipse.equinox.ds missing contraint
Re: org.eclipse.equinox.ds missing contraint [message #505617] Sun, 03 January 2010 17:41
Christophe Fondacci is currently offline Christophe FondacciFriend
Member
I got the exact same problem with 3.5.1 build 20090920-1017
After investigations it appears that each time i export a product with the
"Generate metadata repository" option checked, this error was raised by the
exported product.
If I uncheck this box, then I can export the product and it runs without any
problem...
Hope this helps.
Christophe.
"Paul Webster" <pwebster@ca.ibm.com> a écrit dans le message de groupe de
discussion : gs7fss$1ao$5@build.eclipse.org...
> msacarny wrote:
>> PW-
>> I've got org.eclipse.equinox.util in the product under 'plugins'.
> And it shows up resolved on a diag?
>> I've noticed that the error message indicates:
>> Missing Constraint: Import-Package:
>> org.eclipse.equinox.internal.util.event; version="1.0.0"
> I don't believe this matters, and 1.0 is the same as 1.0.0 (I think).
>> Also, o.e.equinox.ds has a start level of 1. Could this be a startup,
>> race condition kind of problem?
> DS did need to be started early, but I would expect o.e.equinox.util to be
> started early as well (it's a framework bundle after all, no?)
> You might have to take your question to eclipse.technology.equinox (they
> know more about DS and start levels :-)
> PW
> Paul Webster
> http://wiki.eclipse.org/Platform_Command_Framework
> http://wiki.eclipse.org/Command_Core_Expressions
> http://wiki.eclipse.org/Menu_Contributions
> http://wiki.eclipse.org/Menus_Extension_Mapping
> http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/guide/workbench.htm
Previous Topic:Application Menu bar disappears when used OLEControlSite
Next Topic:How to package RCP app for Fedora
Current Time: Mon Apr 23 09:57:18 GMT 2018
Powered by FUDForum. Page generated in 0.01826 seconds
