Home » Language IDEs » C / C++ IDE (CDT) » Problems occurred when invoking code from plug-in: "org.eclipse.core.filebuffers".(Eclipse CDT.debug problem to find resources and editor)
Problems occurred when invoking code from plug-in: "org.eclipse.core.filebuffers". [message #505590] Sat, 02 January 2010 10:45 Go to next message
BSchmitt is currently offline BSchmittFriend
Hello
I have created my file in Eclipse.CDT with debug option (wxWidgets). I'm getting consitently following failures:
1. Problems occurred when invoking code from plug-in: "org.eclipse.core.filebuffers".
2. A document setup participant failed to setup the document.
3. Unable to create editor ID org.eclipse.cdt.ui.editor.CEditor: Editor could not be initialized.
This three failure messages are allways showing up in the identical order as listed above. Compilation with gcc and gdb works fine without error messages.
Would be good to get a hint whats going wrong with my setup.
Bernhard
My system setup:
Windows Vista Home Premium (32 bit)
wxWidgets v2.8
MINGW gcc-3.4.5
Eclipse, Version: 3.5.1.R35x, Build id: M20090917-0800
C/C++ Development Tools, Version: 6.0.0.200909110608,
Build id: 200909110608
Here is the complete error log:
!ENTRY org.eclipse.core.filebuffers 4 2 2010-01-02 16:03:42.559
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.core.filebuffers".
!STACK 0
at org.eclipse.cdt.internal.core.CConfigBasedDescriptorManager. createProjDescriptionForDescriptor(CConfigBasedDescriptorMan ager.java:374)
at org.eclipse.cdt.internal.core.CConfigBasedDescriptorManager. findDescriptor(CConfigBasedDescriptorManager.java:341)
at org.eclipse.cdt.internal.core.CConfigBasedDescriptorManager. getDescriptor(CConfigBasedDescriptorManager.java:238)
at org.eclipse.cdt.core.CCorePlugin.getCProjectDescription(CCor ePlugin.java:639)
at org.eclipse.cdt.internal.ui.text.doctools.ProjectMap.load(Pr ojectMap.java:117)
at org.eclipse.cdt.internal.ui.text.doctools.ProjectMap.<init>(ProjectMap.java:58)
at org.eclipse.cdt.internal.ui.text.doctools.DocCommentOwnerMan ager.getProjectMap(DocCommentOwnerManager.java:212)
at org.eclipse.cdt.internal.ui.text.doctools.DocCommentOwnerMan ager.getCommentOwner(DocCommentOwnerManager.java:129)
at org.eclipse.cdt.internal.ui.text.CTextTools.getDocumentation CommentOwner(CTextTools.java:157)
at org.eclipse.cdt.internal.ui.text.CTextTools.setupCDocument(C TextTools.java:118)
at org.eclipse.cdt.internal.ui.editor.CDocumentSetupParticipant .setup(CDocumentSetupParticipant.java:48)
at org.eclipse.core.internal.filebuffers.ResourceTextFileBuffer Manager$1.run(ResourceTextFileBufferManager.java:151)
at org.eclipse.core.internal.filebuffers.ResourceTextFileBuffer Manager.createEmptyDocument(ResourceTextFileBufferManager.ja va:166)
at org.eclipse.core.internal.filebuffers.ResourceTextFileBuffer .initializeFileBufferContent(ResourceTextFileBuffer.java:293 )
at org.eclipse.core.internal.filebuffers.ResourceFileBuffer.cre ate(ResourceFileBuffer.java:245)
at org.eclipse.core.internal.filebuffers.TextFileBufferManager. connect(TextFileBufferManager.java:113)
at org.eclipse.ui.editors.text.TextFileDocumentProvider.createF ileInfo(TextFileDocumentProvider.java:559)
at org.eclipse.cdt.internal.ui.editor.CDocumentProvider.createF ileInfo(CDocumentProvider.java:856)
at org.eclipse.ui.editors.text.TextFileDocumentProvider.connect (TextFileDocumentProvider.java:478)
at org.eclipse.cdt.internal.ui.editor.CDocumentProvider.connect (CDocumentProvider.java:778)
at org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(Abst ractTextEditor.java:4134)
at org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(Status TextEditor.java:203)
at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetI nput(AbstractDecoratedTextEditor.java:1413)
at org.eclipse.ui.editors.text.TextEditor.doSetInput(TextEditor .java:166)
at org.eclipse.cdt.internal.ui.editor.CEditor.internalDoSetInpu t(CEditor.java:1357)
at org.eclipse.cdt.internal.ui.editor.CEditor.doSetInput(CEdito r.java:1322)
at org.eclipse.ui.texteditor.AbstractTextEditor$19.run(Abstract TextEditor.java:3115)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:372)
at org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:759)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:756)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2579)
at org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:3133)
at org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:3160)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:798)
at org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:644)
at org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:462)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:286)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2857)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2762)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2754)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2705)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2701)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2685)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2676)
at org.eclipse.cdt.dsf.debug.ui.sourcelookup.DsfSourceDisplayAd apter$DisplayJob$3.run(DsfSourceDisplayAdapter.java:385)
at org.eclipse.cdt.dsf.debug.ui.sourcelookup.DsfSourceDisplayAd apter$DisplayJob.openEditor(DsfSourceDisplayAdapter.java:390 )
at org.eclipse.cdt.dsf.debug.ui.sourcelookup.DsfSourceDisplayAd apter$DisplayJob.openEditor(DsfSourceDisplayAdapter.java:371 )
at org.eclipse.cdt.dsf.debug.ui.sourcelookup.DsfSourceDisplayAd apter$DisplayJob.runInUIThread(DsfSourceDisplayAdapter.java: 307)
at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:95)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3855)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3476)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
!ENTRY org.eclipse.core.filebuffers 4 0 2010-01-02 16:03:42.559
!MESSAGE A document setup participant failed to setup the document.
!STACK 0
!ENTRY org.eclipse.ui 4 0 2010-01-02 16:03:42.574
!MESSAGE Unable to create editor ID org.eclipse.cdt.ui.editor.CEditor: Editor could not be initialized.
!STACK 0
at org.eclipse.cdt.internal.core.language.LanguageMappingStore. getProjectDescription(LanguageMappingStore.java:110)
at org.eclipse.cdt.internal.core.language.LanguageMappingStore. decodeMappings(LanguageMappingStore.java:75)
at org.eclipse.cdt.core.model.LanguageManager.getLanguageConfig uration(LanguageManager.java:447)
at org.eclipse.cdt.internal.core.language.LanguageMappingResolv er.computeLanguage(LanguageMappingResolver.java:57)
at org.eclipse.cdt.core.model.LanguageManager.getLanguageForFil e(LanguageManager.java:587)
at org.eclipse.cdt.internal.core.model.TranslationUnit.getLangu age(TranslationUnit.java:767)
at org.eclipse.cdt.internal.ui.editor.CEditor.internalDoSetInpu t(CEditor.java:1369)
!ENTRY org.eclipse.ui 2 2 2010-01-02 16:03:42.590
!MESSAGE Ignored attempt to add saveable that was already registered
!STACK 0
org.eclipse.core.runtime.AssertionFailedException: unknown saveable: org.eclipse.ui.internal.DefaultSaveable@197627b from part: org.eclipse.ui.internal.ErrorEditorPart@197627b
at org.eclipse.ui.internal.SaveablesList.logWarning(SaveablesLi st.java:187)
at org.eclipse.ui.internal.SaveablesList.addModel(SaveablesList .java:117)
at org.eclipse.ui.internal.SaveablesList.addModels(SaveablesLis t.java:289)
at org.eclipse.ui.internal.SaveablesList.postOpen(SaveablesList .java:684)
at org.eclipse.ui.internal.PartList.partOpened(PartList.java:23 4)
at org.eclipse.ui.internal.PartList.access$0(PartList.java:210)
at org.eclipse.ui.internal.PartList$1.propertyChanged(PartList. java:40)
at org.eclipse.ui.internal.WorkbenchPartReference.fireInternalP ropertyChange(WorkbenchPartReference.java:375)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:610)
Re: Problems occurred when invoking code from plug-in: "org.eclipse.core.filebuffers". [message #507302 is a reply to message #505590] Tue, 12 January 2010 20:55 Go to previous message
to follow-up with this issue.
Meanwhile I have created a new clean workspace and have manually implemented my C++ environmental settings as well as copied manually my source files. As a result it works now.
Most likely I had a somehow corrupted project file in Eclipse since the C++ settings are 100% identical.
Previous Topic:Using CDT without projects
Next Topic:no console when debugging CDT (C++)
Current Time: Sun Jun 24 22:58:16 GMT 2018
Powered by FUDForum. Page generated in 0.01855 seconds
