Re: How to properly shutdown Eclipse RAP application? [message #505579 is a reply to message #505561] |
Fri, 01 January 2010 22:38 |
No real name Messages: 4 Registered: December 2009 |
Junior Member |
I agree it is not very natural.
I was looking for ways to close client session cleanly so that it does not prompt the following message:
The server seems to be temporarily unavailable. Would you like to retry?
If I click OK, I get the same message again.
If I calick Cancel, then I get the following message in the browser window:
Request failed.
HTTP Status Code: 12029
As to the use case, it is displaying a few screens to collect user inputs and based on those inputs it performs certain actions. I provide a way to pass all inputs via Java property file, which works fine today, and am implementating a GUI version so we can provide more descriptive meaning to each property on the screen. We can choose to implement it as RCP application, but that will require X11 support on Unix/Linux platform, which is a pain to most customers, if I implement it as RAP, all we need is just the browser.
Re: How to properly shutdown Eclipse RAP application? [message #505973 is a reply to message #505579] |
Tue, 05 January 2010 16:47 |
Stefan Messages: 316 Registered: July 2009 |
you must not call System.exit() because this will terminate the whole VM
with all running sessions being lost. If you want to have something like
a logout button that the user can click to terminate the current
session, maybe this posting helps:
http://www.eclipse.org/forums/index.php?t=msg&th=34206&a mp;start=0&
Stefan.
> Request failed.
FUDForum. Page generated in 0.04588 seconds
