Home » Eclipse Projects » EclipseLink » Help! Weird EclipseLink exception(IndirectList not compatible with transparent indirection)
icon5.gif  Help! Weird EclipseLink exception [message #505271] Mon, 28 December 2009 23:45 Go to next message
Joe is currently offline Joe
Hi all,
I'm new for using EclipseLink as JPA implementation as I'd like to use JPA 2.0 with latest Spring 3.
I've encountered a weird exception during unit-testing which I cannot figure out why it happens. Please help!!
------- User.java-----------------
@Entity
@Table(name="users")
public class User {
	@Id
	@Column(name="username")
	private String username;
	@Column(name="password")
	private String password;
	@OneToMany(fetch=FetchType.LAZY, mappedBy="fromUser")
	@OrderColumn(name="mail_id desc")
	private List<UserMail> sentMails;
	@OneToMany(fetch=FetchType.LAZY, mappedBy="toUser")
	private List<UserMail> receivedMails;
	public int hashCode() {
		final int prime = 31;
		int result = 1;
		result = prime * result + ((username == null) ? 0 : username.hashCode());
		return result;
	public boolean equals(Object obj) {
		if (this == obj)
			return true;
		if (obj == null)
			return false;
		if (!(obj instanceof User))
			return false;
		User other = (User) obj;
		if (username == null) {
			if (other.username != null)
				return false;
		} else if (!username.equals(other.username))
			return false;
		return true;
	//generated getters and setters
	public String getUsername() {
		return username;
	public void setUsername(String username) {
		this.username = username;
	public String getPassword() {
		return password;
	public void setPassword(String password) {
		this.password = password;
	public List<UserMail> getSentMails() {
		return sentMails;
	public void setSentMails(List<UserMail> sentMails) {
		this.sentMails = sentMails;
	public List<UserMail> getReceivedMails() {
		return receivedMails;
	public void setReceivedMails(List<UserMail> receivedMails) {
		this.receivedMails = receivedMails;
-------- Mail.java----------------------------------------
@Entity
@Table(name="mails")
public class Mail {
	@Id
	@Column(name="mail_id")
	private long id;
	@Column(name="title")
	private String title;
	@Column(name="content")
	private String content;
	@OneToMany(fetch=FetchType.LAZY, mappedBy="mail")
	@OrderColumn(name="to_username asc")
	private List<UserMail> shipments;
	public long getId() {
		return id;
	public void setId(long id) {
		this.id = id;
	public String getTitle() {
		return title;
	public void setTitle(String title) {
		this.title = title;
	public String getContent() {
		return content;
	public void setContent(String content) {
		this.content = content;
	public List<UserMail> getShipments() {
		return shipments;
	public void setShipments(List<UserMail> shipments) {
		this.shipments = shipments;
--------UserMail.java-----------------------------
@Entity
@IdClass(UserMail.Pk.class)
@Table(name="user_mails")
public class UserMail {
	public static class Pk implements Serializable {
		private static final long serialVersionUID = 7883097744987560068L;
		private long mail;
		private String fromUser;
		private String toUser;
			int result = 1;
			result = prime * result + ((fromUser == null) ? 0 : fromUser.hashCode());
			result = prime * result + (int) (mail ^ (mail >>> 32));
			result = prime * result + ((toUser == null) ? 0 : toUser.hashCode());
			return result;
			if (this == obj)
				return true;
			if (obj == null)
				return false;
			if (!(obj instanceof Pk))
				return false;
			Pk other = (Pk) obj;
			if (fromUser == null) {
				if (other.fromUser != null)
					return false;
			} else if (!fromUser.equals(other.fromUser))
				return false;
			if (mail != other.mail)
				return false;
			if (toUser == null) {
				if (other.toUser != null)
					return false;
			} else if (!toUser.equals(other.toUser))
				return false;
			return true;
		public long getMail() {
			return mail;
		public void setMail(long mail) {
			this.mail = mail;
		public String getFromUser() {
			return fromUser;
		public void setFromUser(String fromUser) {
			this.fromUser = fromUser;
		public String getToUser() {
			return toUser;
		public void setToUser(String toUser) {
			this.toUser = toUser;
	@Id
	@ManyToOne
	@JoinColumn(name="mail_id", referencedColumnName="mail_id")
	private Mail mail;
	@Id
	@ManyToOne
	@JoinColumn(name="from_username", referencedColumnName="username")
	private User fromUser;
	@Id
	@ManyToOne
	@JoinColumn(name="to_username", referencedColumnName="username")
	private User toUser;
	@Column(name="status")
	private int status;
	public Mail getMail() {
		return mail;
	public void setMail(Mail mail) {
		this.mail = mail;
	public User getFromUser() {
		return fromUser;
	public void setFromUser(User fromUser) {
	public User getToUser() {
		return toUser;
	public void setToUser(User toUser) {
	public int getStatus() {
		return status;
	public void setStatus(int status) {
		this.status = status;
The exception encountered shows as follows:
Exception [EclipseLink-148] (Eclipse Persistence Services - 2.0.0.v20091127-r5931): org.eclipse.persistence.exceptions.DescriptorException
Exception Description: The container policy [IndirectListContainerPolicy(class org.eclipse.persistence.indirection.IndirectList)] is not compatible with transparent indirection.
Mapping: org.eclipse.persistence.mappings.OneToManyMapping[sentMails]
Descriptor: RelationalDescriptor(User --> [DatabaseTable(users)])
Mapping: org.eclipse.persistence.mappings.OneToManyMapping[receivedMails]
Local Exception Stack:
	at org.eclipse.persistence.exceptions.DescriptorException.invalidContainerPolicyWithTransparentIndirection(DescriptorException.java:772)
	at org.eclipse.persistence.internal.indirection.TransparentIndirectionPolicy.validateContainerPolicy(TransparentIndirectionPolicy.java:521)
	at org.eclipse.persistence.mappings.CollectionMapping.validateBeforeInitialization(CollectionMapping.java:2184)
	at org.eclipse.persistence.descriptors.ClassDescriptor.validateBeforeInitialization(ClassDescriptor.java:5260)
	at org.eclipse.persistence.descriptors.ClassDescriptor.preInitialize(ClassDescriptor.java:3323)
	at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:429)
	at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:406)
	at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.postConnectDatasource(DatabaseSessionImpl.java:671)
	at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.login(DatabaseSessionImpl.java:633)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:230)
	at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:368)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.getServerSession(EntityManagerFactoryImpl.java:151)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:207)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManager(EntityManagerFactoryImpl.java:195)
	at org.springframework.orm.jpa.JpaTransactionManager.createEntityManagerForTransaction(JpaTransactionManager.java:400)
	at org.springframework.orm.jpa.JpaTransactionManager.doBegin(JpaTransactionManager.java:321)
	at org.springframework.transaction.support.AbstractPlatformTransactionManager.getTransaction(AbstractPlatformTransactionManager.java:371)
	at org.springframework.transaction.interceptor.TransactionAspectSupport.createTransactionIfNecessary(TransactionAspectSupport.java:336)
	at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:102)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
	at $Proxy12.authenticate(Unknown Source)
	at test.UserServiceTest.testAuthenticate(UserServiceTest.java:26)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:616)
	at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:44)
	at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
	at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:41)
	at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
	at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
	at org.springframework.test.context.junit4.statements.RunBeforeTestMethodCallbacks.evaluate(RunBeforeTestMethodCallbacks.java:74)
	at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:31)
	at org.springframework.test.context.junit4.statements.RunAfterTestMethodCallbacks.evaluate(RunAfterTestMethodCallbacks.java:82)
	at org.springframework.test.context.junit4.statements.SpringRepeat.evaluate(SpringRepeat.java:72)
	at org.springframework.test.context.junit4.SpringJUnit4ClassRunner.runChild(SpringJUnit4ClassRunner.java:240)
	at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:46)
	at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:180)
	at org.junit.runners.ParentRunner.access$000(ParentRunner.java:41)
	at org.junit.runners.ParentRunner$1.evaluate(ParentRunner.java:173)
	at org.springframework.test.context.junit4.statements.RunBeforeTestClassCallbacks.evaluate(RunBeforeTestClassCallbacks.java:61)
	at org.springframework.test.context.junit4.statements.RunAfterTestClassCallbacks.evaluate(RunAfterTestClassCallbacks.java:70)
	at org.junit.runners.ParentRunner.run(ParentRunner.java:220)
	at org.springframework.test.context.junit4.SpringJUnit4ClassRunner.run(SpringJUnit4ClassRunner.java:180)
	at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:46)
	at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
[Updated on: Mon, 28 December 2009 23:55]
Report message to a moderator
Re: Help! Weird EclipseLink exception [message #506443 is a reply to message #505271] Thu, 07 January 2010 09:46 Go to previous message
Doug Clarke is currently offline Doug Clarke
Joe,
I believe the issue is that you want the UserMail instances in
ordered when they are read in. To do this you need to use:
@OrderBy("mail_id desc")
@OrderBy causes the resulting collection to be ordered when returned from the database. The @OrderColumn specifies a 'index' column where the order of the list as it exists in memory can be maintained when the list is persisted and later read in.
Doug
Previous Topic:Eclipselink 1.1.3 query hang up
Next Topic:JPQL join fetch usable in native EclipseLink application?
Current Time: Wed Jun 19 07:25:13 EDT 2013
Powered by FUDForum. Page generated in 0.01568 seconds
