Home » Modeling » EMF » [CDO] OutOfMemoryError when committing frequently
[CDO] OutOfMemoryError when committing frequently [message #503776] Tue, 15 December 2009 12:20 Go to next message
Walter Hargassner is currently offline Walter HargassnerFriend
I'm using CDO 2.0 and have a CDO client and server running within one
process. As we have limited resources, we need to have a look at the
memory consumption. Currently I'm ending up in an OutOfMemoryError.
We have the following use case:
1. Create a hierarchically structured model (about 2.000 CDOObjects)
2. Storing the model in one resource on the server
3. Getting the single root element
4. Set a new value for each element
5. Commit the transaction
6. Continue with step 4.
For the server setup I've used the server config file and set the
currentLRUCapacity and the revisedLRUCapacity to 1, supportingAudits is
set to false. On the client side I created a new LRUCache and set it in
the CDOSessionConfiguration.
After step 3 we need about 30 MB of heap size. After a few minutes we
run out of memory (64 MB).
First experience I've made is, that somehow the revisedLRUCapacity and
currentLRUCapacity from the config file are ignored. The created cache
uses 1000 and 1000 as default values. I've set the cache size manually,
both to 1, but it does not really change anything.
By using the profiler I found out, that I have a lot of
LinkedList$Entry, KeyedSoftReference, CDOIDAndVersionImpl objects,
nearly the same number of HashMap$Entry objects and a lot of
CDORevisionImpl and CDOListImpl objects.
Any hints for me where else I should have a look?
BR
Walter
Re: [CDO] OutOfMemoryError when committing frequently [message #503868 is a reply to message #503776] Wed, 16 December 2009 07:56 Go to previous message
Eike Stepper is currently offline Eike StepperFriend
Hi Walter,
Comments below...
Walter Hargassner schrieb:
> memory consumption.
Are you using JVMAcceptor and JVMConnector instead of TCP connections?
> is set to false. On the client side I created a new LRUCache and set
> it in the CDOSessionConfiguration.
If reloading revisions is fast (client and server are in the same VM)
you could even consider to set a NOOPRevisionCache (self-made). Or you
just set a MEMRevisionCache
How big are your 2000 revisions in total?
> manually, both to 1, but it does not really change anything.
That sounds like https://bugs.eclipse.org/bugs/show_bug.cgi?id=292375 .
We want to publish new builds ASAP.
"A lot" is not very specific :P How do the numbers relate to your use cases?
Hard to say. First ensure that the cache sizes are really what you
expect them to be. Then try to find out whether the system consumes more
memory than expected. There's a chance that you just need more memory.
Cheers
/Eike
Previous Topic:[CDO] 2.0 / 3.0 compatibility
Next Topic:[CDO] Exception on commit
Current Time: Sat Jun 23 14:25:04 GMT 2018
Powered by FUDForum. Page generated in 0.01629 seconds
