Home » Eclipse Projects » Riena » Riena Release 1.2.0.0
Riena Release 1.2.0.0 [message #503723] Tue, 15 December 2009 14:01 Go to next message
Christian Campo is currently offline Christian CampoFriend
Hi All,
Riena is now released. All the downloads are available in the locations noted below. Thanks to all committers and
contributers for their work on making this a stable version.
Instructions on how to get started can be found here http://wiki.eclipse.org/Riena_Getting_started
The P2 Update site is here http://download.eclipse.org/rt/riena/1.2.0.0/update/
For Windows users there is target platform download
http://www.eclipse.org/downloads/download.php?file=/rt/riena /Riena-target-200912141645-1.2.0.0-win32.zip
Note that Riena 1.2.0.0 is based on Eclipse 3.5. (Galileo). It should also run on Helios platforms, but did not do a
test to verify that.
New and Noteworthy is here http://wiki.eclipse.org/Riena_New_And_Noteworthy#1.2.0.0 (it contains a list of bugs that
were fixed between RC1 and the release and also a list of all bugs that we fixed)
Any feedback is welcomed.
The next release is Riena 2.0 which will come out with Helios. As the version indicates we will make a number of API
changes to make it even easier to use Riena. We warn you well ahead about these and supply notes to how to convert old
API calls to new ones.
- christian
Re: Riena Release 1.2.0.0 [message #503917 is a reply to message #503723] Wed, 16 December 2009 12:15 Go to previous message
UPDATE: Due to a mix up in the feature versions, we have rebuilt target platform and update site and uploaded the new
versions.
The update site was updated in place. The targetplatform has now a 'b' at the end of the filename......
http://www.eclipse.org/downloads/download.php?file=/rt/riena /Riena-target-200912141645-1.2.0.0-win32b.zip
Changes are also reflected in the wiki. The changes really only mean a better and clearer naming of the features and in
the features.jars. Plugins are not affected.
christian
Christian Campo schrieb:
> Hi All,
> noted below. Thanks to all committers and contributers for their work on
> also run on Helios platforms, but did not do a test to verify that.
> list of bugs that were fixed between RC1 and the release and also a list
> version indicates we will make a number of API changes to make it even
> to how to convert old API calls to new ones.
> - christian
Re: Riena Release 1.2.0.0 [message #584424 is a reply to message #503723] Wed, 16 December 2009 12:15 Go to previous message
versions.
christian
> Hi All,
> - christian
Previous Topic:Riena Release 1.2.0.0
Next Topic:Binding own structure to TreeTable
Current Time: Wed Jun 20 06:16:45 GMT 2018
Powered by FUDForum. Page generated in 0.02586 seconds
