Home » Newcomers » Newcomers » Workspace_Loc value error(Property not found error on specifying build.xml)
Workspace_Loc value error [message #503134] Fri, 11 December 2009 02:57
kenan Missing name is currently offline kenan Missing nameFriend
I have a web application that I want to deploy onto OC4J 10.1.3 from within eclipse.
I have checked out my code and setup the OC4J server in eclipse.
However, when I try to specify the build.xml file from the ANT PUBLISHER PROPERTY from the OC4J Server page on eclipse, it give the following error,
Property not found.
In the input file dialog the path to the build.xml file is specified as follows,
${workspace_loc:/ molpages/website/makefiles/build.xml}
I think that it is not finding the value for workspace_loc. I have tried to specify it by going to Tools-->Run and Debug-->String Substitution but it still gives the same error.
Any ideas,
Thanks, Kenan.
[Updated on: Fri, 11 December 2009 02:57]
Report message to a moderator
Previous Topic:Build The app in unix Machine
Next Topic:Eclipse JDT integration in a swing application
Current Time: Mon Apr 23 15:35:27 GMT 2018
Powered by FUDForum. Page generated in 0.02655 seconds
