Home » Eclipse Projects » Platform - User Assistance (UA) » Product Name on window/tab
Product Name on window/tab [message #502369] Mon, 07 December 2009 21:12 Go to next message
Rob Kimm is currently offline Rob KimmFriend
Hi -
I'm running into an issue with something that should be simple - which probably means I'm missing something obvious...
I'm trying to get my help product name to appear on the title bar/tab label of a browser window.
I have the following settings:
in config.ini:
eclipse.product=com.myproduct.docs.helpProduct
in plugin.xml for com.myproduct.docs:
<extension point="org.eclipse.core.runtime.products" id="com.myproduct.docs">
<product name="%productName" application=""/>
</extension>
in plugin.properties for com.myproduct.docs:
name=My System Help
providerName=MY_company
productName=My System
in MANIFEST.MF:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Localization: plugin
Bundle-Name: %name
Bundle-Vendor: %providerName
Eclipse-LazyStart: true
Bundle-SymbolicName: com.myproduct.docs; singleton:=true
Bundle-Version: 1.0
starting either standalone help or infocenter mode, with -plugincustomization plugins\com.myproduct.docs\plugin_customization.ini or without, and with org.eclipse.help.base/windowTitlePrefix=true or =false, I get the same result.
With true, window/tab title is "Help - "
With false, window/tab title is the url of help/index.jsp.
Other customizations (banner, help home, etc.) work fine.
In the log file, I find the following:
!ENTRY org.eclipse.equinox.app 0 0 2009-12-07 14:54:35.184
!MESSAGE Product com.myproduct.docs could not be found.
What am I missing?
Thanks for the help...
Rob Kimm
Re: Product Name on window/tab [message #502493 is a reply to message #502369] Tue, 08 December 2009 14:26 Go to previous messageGo to next message
Lee Anne Kowalski is currently offline Lee Anne KowalskiFriend
Member
Hi Rob,
One thing I see is that the id in the <extension> element should be the
ultimate portion of the eclipse.product; that is, it should be your
"helpProduct" portion. For example:
<extension point="org.eclipse.core.runtime.products" id="helpProduct">
</extension>
Then, windowTitlePrefix should be set to "false" to pick up your title.
While I don't know if anything else is amiss, certainly the
<extension>'s id should be helpProduct given what is in your config.ini
file.
Best,
Lee Anne
http://www.linkedin.com/in/leeannekowalski
Rob Kimm wrote:
> Hi -
> in config.ini:
> </extension>
> name=My System Help
> in MANIFEST.MF:
> Bundle-Name: %name
> Bundle-Version: 1.0
> With true, window/tab title is "Help - " With false, window/tab title is
> What am I missing?
> Rob Kimm
Re: Product Name on window/tab [message #642754 is a reply to message #502493] Thu, 02 December 2010 15:42 Go to previous messageGo to next message
TWPete  is currently offline TWPete Friend
Bumping this question.
Having the exact same problem. Tried Lee Anne's suggestion but with no luck. Sad
Anyone willing to work me through it?
Re: Product Name on window/tab [message #643421 is a reply to message #642754] Mon, 06 December 2010 19:23 Go to previous message
Chris Austin is currently offline Chris AustinFriend
I sometimes get this error message when the plugin that actually contains my product definition cannot be found or started. You can enable the osgi prompt by adding -console to your eclipse run arguments. When the app starts up you will get an osgi prompt. Type ss <plugin id> to see if your plugin is found, and type start <plugin number found in ss> to try and start it - you will see an exception if it fails.
Example:
osgi> ss org.eclipse.help.base
Framework is launched.
id	State       Bundle
7	RESOLVED    org.eclipse.help.base.nl2_3.5.2.v201009231809
	            Master=207
44	RESOLVED    org.eclipse.help.base.nl1_3.5.2.v201009231809
	            Master=207
50	RESOLVED    org.eclipse.help.base.nl2a_3.5.2.v201009231809
	            Master=207
207	ACTIVE      org.eclipse.help.base_3.5.2.v201009090800
	            Fragments=7, 44, 50, 209
209	RESOLVED    org.eclipse.help.base.nlBidi_3.5.2.v201009231809
	            Master=207
osgi> start 207
osgi>
Previous Topic:how to update recursively using CVS?
Next Topic:Jetty IO exceptions accessing help
Current Time: Wed May 23 15:18:07 GMT 2018
Powered by FUDForum. Page generated in 0.01591 seconds
