Home » Archived » BPMN Modeler » Problem with lanes
Problem with lanes [message #501277] Tue, 01 December 2009 17:49 Go to next message
mio is currently offline mioFriend
i thing you know this bug but i post it;
i have a diagram (saved) with a pool without lanes, and with some task (Vertices) inside; in this case if I add a lane and save, all the Vertices in the pool don't update their status and remain without the attribute lanes;
the only solution that I've found is to move, a little, every Vertices in the lane to update their status Sad
BPMN Modeler version: 1.1.0.2009.03191021-43-7E77g7IAgA7EA
Eclipse version: 3.4.0
any suggestion?
tnx a lot
Re: Problem with lanes [message #501793 is a reply to message #501277] Thu, 03 December 2009 19:46 Go to previous messageGo to next message
Originally posted by: atoulme.intalio.com
Can you please file a bug for this with a reproducible test case ?
Antoine
mio wrote:
> Hi
> attribute lanes;
> in the lane to update their status :(
> any suggestion?
> tnx a lot
Re: Problem with lanes [message #503782 is a reply to message #501277] Tue, 15 December 2009 17:46 Go to previous messageGo to next message
Hi Antoine
tnx for the reply;
the problem appear always, unless i have only one vertices in the pool.
Consider the case of a new BPMN model with the only default task in the default pool. In this case if i insert a lane and save, all its ok, but if i insert another task SAVE and THEN insert the lane and SAVE, in the .bpmn file the new vertice created as no references with the lane in their attributes.
I hope i was clear
tnx
Damiano
Re: Problem with lanes [message #504845 is a reply to message #503782] Wed, 23 December 2009 01:17 Go to previous message
Can you file a bug with those steps please ?
Antoine
On 12/15/09 9:46 AM, mio wrote:
> Hi Antoine
> tnx for the reply;
> their attributes.
> I hope i was clear
> tnx
> Damiano
Previous Topic:editing / creating diagrams
Next Topic:copying BPMNDiagram
Current Time: Fri May 25 15:09:32 GMT 2018
Powered by FUDForum. Page generated in 0.02481 seconds
