Re: Draw a Line [message #500963 is a reply to message #500132] |
Mon, 30 November 2009 13:47  |
Thomas Messages: 79 Registered: October 2009 |
Member |
Maybe i have found 1 solution. When i set source and target editpart for my PolylineConnectionEx on my diagrameditpart, with xyanchors, then i should be able to draw somehow a line. It still doesn´t work.
http://www.eclipsezone.com/eclipse/forums/t101269.html
2nd reply is my solution, because i don´t want to have (1/1) shapes. because if i export this as an svg, this shapes should not be exportet by the gmf export.
public void setSource(EditPart editPart) {
System.out.println("setSource "+editPart);
super.setSource(editPart);
//source should be diagrameditpart
/* (non-Javadoc)
* @see org.eclipse.gef.editparts.AbstractConnectionEditPart#setTarget(org.eclipse.gef.EditPart)
public void setTarget(EditPart editPart) {
System.out.println("setTarget "+editPart);
super.setTarget(editPart);
//target should be diagrameditpart
protected ConnectionAnchor getSourceConnectionAnchor() {
System.out.println("getSourceConnectionAnchor");
return super.getSourceConnectionAnchor();
//xyanchor
/* (non-Javadoc)
* @see org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionNodeE ditPart#getSourceConnectionAnchor(org.eclipse.gef.Connection EditPart)
public ConnectionAnchor getSourceConnectionAnchor(
ConnectionEditPart connEditPart) {
return super.getSourceConnectionAnchor(connEditPart);
//xyanchor
/* (non-Javadoc)
* @see org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionNodeE ditPart#getSourceConnectionAnchor(org.eclipse.gef.Request)
public ConnectionAnchor getSourceConnectionAnchor(Request request) {
return super.getSourceConnectionAnchor(request);
//xyanchor
/* (non-Javadoc)
* @see org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionNodeE ditPart#getTargetConnectionAnchor()
protected ConnectionAnchor getTargetConnectionAnchor() {
System.out.println("getTargetConnectionAnchor");
return super.getTargetConnectionAnchor();
//xyanchor
/* (non-Javadoc)
* @see org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionNodeE ditPart#getTargetConnectionAnchor(org.eclipse.gef.Connection EditPart)
public ConnectionAnchor getTargetConnectionAnchor(
return super.getTargetConnectionAnchor(connEditPart);
//xyanchor
/* (non-Javadoc)
* @see org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionNodeE ditPart#getTargetConnectionAnchor(org.eclipse.gef.Request)
public ConnectionAnchor getTargetConnectionAnchor(Request request) {
return super.getTargetConnectionAnchor(request);
//xyanchor
/* (non-Javadoc)
* @see org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionNodeE ditPart#getTargetEditPart(org.eclipse.gef.Request)
public EditPart getTargetEditPart(Request request) {
System.out.println("getTargetEditPart");
return super.getTargetEditPart(request);
//xyanchor
[Updated on: Mon, 30 November 2009 13:47] Report message to a moderator
FUDForum. Page generated in 0.02536 seconds
