Home » Eclipse Projects » EGit / JGit » Author / Commiter Preference Settings / Last inputed values
Author / Commiter Preference Settings / Last inputed values [message #499777] Tue, 24 November 2009 04:50 Go to next message
Lars Vogel Unavailable until 15 August 2016 is currently offline Lars Vogel Unavailable until 15 August 2016Friend
During a commit EGit asked for the author / commiter and default with
the User System property then @ and when my ip.
Could you remember the last values which the user inputed? It is
time-consuming to correct these entries at every commit.
Best regards, Lars
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
http://www.twitter.com/vogella - vogella on Twitter
Re: Author / Commiter Preference Settings / Last inputed values [message #499799 is a reply to message #499777] Tue, 24 November 2009 08:30 Go to previous messageGo to next message
Mykola Nikishov is currently offline Mykola NikishovFriend
Member
Lars Vogel <Lars.Vogel@gmail.com> writes:
Lars, could you file an enhancement request using
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EGit& ;component=UI?
Actually it's worth two requests:
- to remember a previous user input (with multiple values, available as
a drop-down list and/or via completion).
- UI to change user's e-mail and name in a git configuration file for
those who don't have any other Git tool installed.
As a workaround you could just add (or edit) this section to your
..git/config file:
--8<---------------cut here---------------start------------->8---
[user]
email = my@email.com
name = My Name
--8<---------------cut here---------------end--------------->8---
MAN-UANIC
Re: Author / Commiter Preference Settings / Last inputed values [message #499893 is a reply to message #499799] Tue, 24 November 2009 13:20 Go to previous messageGo to next message
Hi Mykola,
Thanks for the reply and the workaround.
Bug reports:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=295994
https://bugs.eclipse.org/bugs/show_bug.cgi?id=295995
Best regards, Lars
> ..git/config file:
> [user]
> name = My Name
Re: Author / Commiter Preference Settings / Last inputed values [message #502275 is a reply to message #499893] Mon, 07 December 2009 15:04 Go to previous messageGo to next message
Michael Heuberger is currently offline Michael HeubergerFriend
Member
Where can I find that configuration file on Windows? I want to configure name and email.
Michael
Re: Author / Commiter Preference Settings / Last inputed values [message #502295 is a reply to message #502275] Mon, 07 December 2009 15:38 Go to previous messageGo to next message
Matthias Sohn is currently offline Matthias SohnFriend
> name and email.
See the git config documentation at
http://www.kernel.org/pub/software/scm/git/docs/git-config.h tml :
If not set explicitly with --file, there are three files where
git-config will search for configuration options:
$GIT_DIR/config
Repository specific configuration file. (The filename is of course
relative to the repository root, not the working directory.)
~/.gitconfig
User-specific configuration file. Also called "global" configuration
file.
$(prefix)/etc/gitconfig
System-wide configuration file.
On my Windows system I have (matching the above documentation):
- msysgit installed at D:\bin\git
- for a repo for C:\data\git\EGit\jgit the repo specific configuration is
located at C:\data\git\EGit\jgit\.git\config
- user specific configuration is here "C:\Documents and Settings\<my
userID>\.gitconfig"
- system wide configuration is here C:\bin\git\etc\gitconfig
Matthias
Re: Author / Commiter Preference Settings / Last inputed values [message #502303 is a reply to message #502295] Mon, 07 December 2009 16:12 Go to previous message
Member
Thank you very much! Your help was great, I solved that with the relative config file.
Cheers
Michael
Re: Author / Commiter Preference Settings / Last inputed values [message #575835 is a reply to message #499777] Tue, 24 November 2009 08:30 Go to previous message
Member
..git/config file:
[user]
name = My Name
MAN-UANIC
Re: Author / Commiter Preference Settings / Last inputed values [message #575873 is a reply to message #499799] Tue, 24 November 2009 13:20 Go to previous message
Hi Mykola,
Bug reports:
Best regards, Lars
> ..git/config file:
> [user]
> name = My Name
Re: Author / Commiter Preference Settings / Last inputed values [message #576328 is a reply to message #499893] Mon, 07 December 2009 15:04 Go to previous message
Member
Michael
Re: Author / Commiter Preference Settings / Last inputed values [message #576346 is a reply to message #576328] Mon, 07 December 2009 15:38 Go to previous message
> name and email.
$GIT_DIR/config
~/.gitconfig
file.
userID>\.gitconfig"
Matthias
Re: Author / Commiter Preference Settings / Last inputed values [message #576363 is a reply to message #502295] Mon, 07 December 2009 16:12 Go to previous message
Member
Cheers
Michael
Previous Topic:Can I use EMF Compare for differencing with EGit
Next Topic:How to revert changes?
Current Time: Fri Jan 19 13:53:22 GMT 2018
Powered by FUDForum. Page generated in 0.02760 seconds
