Home » Eclipse Projects » Equinox » RCP App Fails on startup: IllegalStateException
Re: RCP App Fails on startup: IllegalStateException [message #50894 is a reply to message #50865] |
Thu, 20 October 2005 01:06 |
Originally posted by: jeff_nospam_mcaffer.ca.ibm.com
A couple things.
- Bugzilla is more effective for this kind of issue
- The application service is registered by the runtime plugin. I suspect
that you are not installing/starting the runtime. It should be listed on
the osgi.bundles list in the config.ini or on the command as a -D vm arg.
- when you export the features, what are you doing for a launcher,
startup.jar, config.ini etc. You should consider defining a PRODUCT and
exporting the product and then packaging that up.
Jeff
"Paul Wuethrich" <paul.wuethrich@eye-ris.com> wrote in message
news:dj5lut$g94$1@news.eclipse.org...
> Can anyone shed any light on this?
> thx
> news:dj0td9$fb2$1@news.eclipse.org...
> > FYI, I use the feature export functionality of eclipse so that all
> plugins,
> > both eclipse and ours, are moved into a staging area for the application
> > packaging step whereby I run a script which builds a self-extracting
> > executable. So I'm using the same plugins that are used in my
functional
> > development environment. I've been hoping that something is "shoddy"
> > somewhere but I still don't understand what the source of this error is.
> > I've stepped through the code in the dev environment but I'm not
> connecting
> > the dots as to what circumstances will cause this to fail
> > (ParameterizedRunnable returns null):
> > EclipseStarter.java
> > public static Object run(Object argument) throws Exception {
> > if (Profile.PROFILE && Profile.STARTUP)
> > Profile.logEnter("EclipseStarter.run(Object)()", null); //$NON-NLS-1$
> > if (!running)
> > throw new
> > IllegalStateException(EclipseAdaptorMsg.ECLIPSE_STARTUP_NOT_ RUNNING);
> > // if we are just initializing, do not run the application just
return.
> > if (initialize)
> > return new Integer(0);
> > initializeApplicationTracker();
> > Profile.logTime("EclipseStarter.run(Object)()", "applicaton tracker
> > initialized"); //$NON-NLS-1$ //$NON-NLS-2$
> > LINE 364>>>>ParameterizedRunnable application =
(ParameterizedRunnable)
> > applicationTracker.getService();
> > news:dioesh$ceb$1@news.eclipse.org...
> > > We just migrated from 3.1 M6 to 3.1.1 and our RCP application will not
> run
> > > as a standalone application (but works fine as a launch configuration
> from
> > > the IDE).
> > > I'm guessing this is something obvious but I can't seem to find it.
> This
> > > occurs
> > > whether I try to point to an existing workspace or not.
> > > !ENTRY org.eclipse.osgi 2005-10-13 09:42:50.753
> > > !MESSAGE Application error
> > > !STACK 1
> > > java.lang.IllegalStateException: Unable to acquire application
service.
> > > at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:367)
> > > at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
> > > at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> > > at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
> > > at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
> > > at java.lang.reflect.Method.invoke(Unknown Source)
> > > at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
> > > at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
> > > at org.eclipse.core.launcher.Main.run(Main.java:973)
> > > at org.eclipse.core.launcher.Main.main(Main.java:948)
Re: RCP App Fails on startup: IllegalStateException [message #51085 is a reply to message #50894] |
Thu, 20 October 2005 15:20 |
paul wuethrich Messages: 128 Registered: July 2009 |
Thanks Jeff,
I usually assume user error or configuration rather than a bug. For this
particular issue, I assumed something configuration related as this worked
fine for our 3.0x and 3.1M builds. This problem arose with the migration
from 3.1M6 to 3.1.1.
We do have a product and application defined and our
INSTALL/configuration/config.ini contains the following entries (we have
never specified the osgi.bundles parameter):
eclipse.application=com.eyeris.eyeprofit.modelconfig.ui.Mode lConfigApplicati
on
eclipse.product=com.eyeris.eyeprofit.modelconfig.ui.console
The INSTALL/features directory contains two features both of which have a
feature.xml:
com.eyeris.eyeprofit.eclipse.base.plugins_1.0.0
com.eyeris.eyeprofit.ui.plugins_1.0.0
The INSTALL/plugins directory now contains all IDE and proprietary plugins
(a result of trying to debug the problem)
As for the launcher, the INSTALL directory contains what we've used
previously:
eclipse.exe
startup.jar
..eclipseproduct
And our startup parameters are also how they've been previously:
"C:\Program Files\Eyeris\EyeProfit\Integration\eclipse.exe" -vmargs -Xmx480M
So it sounds like we need to update the config.ini with at least one bundle,
which one(s)?
osgi.bundles =??
Paul
"Jeff McAffer" <jeff_nospam_mcaffer@ca.ibm.com> wrote in message
news:dj6qii$vm7$1@news.eclipse.org...
> A couple things.
> Jeff
> > thx
> > plugins,
application
> functional
is.
> > connecting
> > > EclipseStarter.java
//$NON-NLS-1$
> > > if (!running)
> > > throw new
> return.
> > > if (initialize)
not
> > run
configuration
> > from
> > > > the IDE).
> > This
> > > > occurs
> > > > !STACK 1
> service.
> > > > at
> > > > at
Re: RCP App Fails on startup: IllegalStateException [message #51113 is a reply to message #51085] |
Thu, 20 October 2005 16:13 |
I tried add the following to config.ini but still got the same error:
osgi.bundles=org.eclipse.osgi.services, org.eclipse.osgi.util,
news:dj8cj9$2rr$1@news.eclipse.org...
> Thanks Jeff,
> on
> feature.xml:
> previously:
> eclipse.exe
> startup.jar
> .eclipseproduct
> "C:\Program
bundle,
> which one(s)?
> osgi.bundles =??
> Paul
> > A couple things.
suspect
on
arg.
> > Jeff
> > > thx
> > > plugins,
> application
> > functional
"shoddy"
> is.
> > > connecting
> > > > EclipseStarter.java
> //$NON-NLS-1$
> > > > if (!running)
> > > > throw new
> > return.
> > > > if (initialize)
tracker
> not
> > > run
> configuration
> > > from
> > > > > the IDE).
it.
> > > This
> > > > > occurs
> > > > > !STACK 1
> > service.
> > > > > at
> > > > > at
Source)
Re: RCP App Fails on startup: IllegalStateException [message #51198 is a reply to message #51113] |
Thu, 20 October 2005 23:07 |
This worked however...
osgi.bundles=org.eclipse.core.runtime@2:start,
org.eclipse.update.configurator@3:start
news:dj8foc$7j1$1@news.eclipse.org...
> > Thanks Jeff,
this
worked
migration
> > on
a
> > feature.xml:
plugins
> > previously:
> > eclipse.exe
> > startup.jar
> > .eclipseproduct
> > "C:\Program
> bundle,
> > which one(s)?
> > osgi.bundles =??
> > Paul
> > > A couple things.
> suspect
> on
> arg.
and
> > > Jeff
> > > > thx
> > > > plugins,
> > application
self-extracting
> > > functional
> "shoddy"
error
> > is.
> > > > connecting
> > > > > EclipseStarter.java
> > //$NON-NLS-1$
> > > > > if (!running)
> > > > > throw new
> > > return.
> > > > > if (initialize)
> tracker
will
> > not
> > > > run
> > configuration
> > > > from
> > > > > > the IDE).
> it.
> > > > This
> > > > > > occurs
> > > > > > !STACK 1
> > > service.
> > > > > > at
> > > > > > at
> Source)
> > > > > > at
Re: RCP App Fails on startup: IllegalStateException [message #51308 is a reply to message #51198] |
Sat, 22 October 2005 00:37 |
yes. That is the standard osgi.bundles list for Eclipse. The runtime gives
you the registry etc and the update.configurator installs all the rest of
the bundles.
Jeff
news:dj97vt$8a9$1@news.eclipse.org...
> > > Thanks Jeff,
> this
> worked
> migration
have
> > > on
have
> a
> > > feature.xml:
> plugins
> > > previously:
> > > eclipse.exe
> > > startup.jar
> > > .eclipseproduct
> > > "C:\Program
> > bundle,
> > > which one(s)?
> > > osgi.bundles =??
> > > Paul
> > > > A couple things.
> > suspect
listed
> > on
> > arg.
> and
> > > > Jeff
> > > > > thx
all
> > > > > plugins,
> > > application
> self-extracting
> > > > functional
> > "shoddy"
> error
> > > is.
> > > > > connecting
> > > > > > EclipseStarter.java
> > > //$NON-NLS-1$
> > > > > > if (!running)
> > > > > > throw new
just
> > > > return.
> > > > > > if (initialize)
> > tracker
> will
> > > not
> > > > > run
> > > configuration
> > > > > from
> > > > > > > the IDE).
find
> > it.
> > > > > This
> > > > > > > occurs
> > > > > > > !STACK 1
> > > > service.
> > > > > > > at
> > > > > > > at
Method)
Source)
> > Source)
> > > > > > > at
Re: RCP App Fails on startup: IllegalStateException [message #51658 is a reply to message #51308] |
Wed, 26 October 2005 15:13 |
Jeff,
I thought this had resolved my build issues but I had forgotten that during
the troubleshooting process I had copied all of the Eclipse plugins into the
build area that is used as the source for building an installable image.
Anyway, upon realization of that, I removed all but the required plugins
(the same list of plugins used in my dev environment and specified in my
launch configuration). This broke my build and the platform could not find
my application as specified in the config.ini file. Anyway, now I'm
confused and clearly do not understand the configuration requirements for
RCP applications in 3.1.1. Do I need to specify additional bundles in the
config.ini for RCP applications (i.e. plugin which represents the primary
feature, all of them, etc.)??
As a reminder, all of this was functional in 3.01 and through 3.1 M6.
Here is how the application directory is structured:
INSTALL_LOC/
startup.jar
eclipse.ini
eclipse.exe
.eclipseproduct
/workspace
/plugins
/features
feature1(required eclipse plugins)
feature.xml
feature2(our plugins)
feature.xml
/configuration
config.ini
The config.ini contains:
on
This is the list of required eclipse plugins that our RCP application
depends on:
id="org.apache.ant"
id="org.apache.lucene"
id="org.eclipse.compare"
id="org.eclipse.core.commands"
id="org.eclipse.core.expressions"
id="org.eclipse.core.filebuffers"
id="org.eclipse.core.resources"
id="org.eclipse.core.resources.compatibility"
id="org.eclipse.core.resources.win32"
id="org.eclipse.core.runtime"
id="org.eclipse.core.runtime.compatibility"
id="org.eclipse.draw2d"
id="org.eclipse.emf"
id="org.eclipse.emf.common"
id="org.eclipse.emf.common.ui"
id="org.eclipse.emf.ecore"
id="org.eclipse.emf.ecore.xmi"
id="org.eclipse.emf.edit"
id="org.eclipse.emf.edit.ui"
id="org.eclipse.gef"
id="org.eclipse.help"
id="org.eclipse.help.appserver"
id="org.eclipse.help.base"
id="org.eclipse.help.ui"
id="org.eclipse.help.webapp"
id="org.eclipse.jface"
id="org.eclipse.jface.text"
id="org.eclipse.osgi"
id="org.eclipse.pde.runtime"
id="org.eclipse.swt"
id="org.eclipse.swt.win32.win32.x86"
id="org.eclipse.team.core"
id="org.eclipse.team.ui"
id="org.eclipse.text"
id="org.eclipse.tomcat"
id="org.eclipse.ui"
id="org.eclipse.ui.cheatsheets"
id="org.eclipse.ui.editors"
id="org.eclipse.ui.forms"
id="org.eclipse.ui.ide"
id="org.eclipse.ui.intro"
id="org.eclipse.ui.views"
id="org.eclipse.ui.win32"
id="org.eclipse.ui.workbench"
id="org.eclipse.ui.workbench.compatibility"
id="org.eclipse.ui.workbench.texteditor"
id="org.eclipse.update.configurator"
id="org.eclipse.update.core"
id="org.eclipse.update.core.win32"
id="org.eclipse.update.scheduler"
id="org.eclipse.update.ui"
id="org.junit"
thanks in advance
Paul
news:djc1ju$lk2$1@news.eclipse.org...
gives
> the bundles.
> Jeff
> > > > Thanks Jeff,
> > this
> > worked
> > migration
> have
> > > > on
> have
> > a
> > > > feature.xml:
> > plugins
> > > > previously:
> > > > eclipse.exe
> > > > startup.jar
> > > > .eclipseproduct
> > > > "C:\Program
> > > bundle,
> > > > which one(s)?
> > > > osgi.bundles =??
> > > > Paul
> > > > > A couple things.
> > > suspect
> listed
> > > on
vm
> > > arg.
PRODUCT
> > and
> > > > > Jeff
> > > > > > thx
> all
> > > > > > plugins,
> > > > application
> > self-extracting
> > > > > functional
> > > "shoddy"
> > error
> > > > is.
not
> > > > > > connecting
> > > > > > > EclipseStarter.java
> > > > //$NON-NLS-1$
> > > > > > > if (!running)
> > > > > > > throw new
> just
> > > > > return.
> > > > > > > if (initialize)
> > > tracker
application
> > will
> > > > not
> > > > > > run
> > > > configuration
> > > > > > from
> > > > > > > > the IDE).
> find
> > > it.
> > > > > > This
> > > > > > > > occurs
> > > > > > > > !STACK 1
application
> > > > > service.
> > > > > > > > at
> > > > > > > > at
> Method)
> Source)
> > > Source)
> > > > > > > > at
Re: RCP App Fails on startup: IllegalStateException [message #51817 is a reply to message #51658] |
Thu, 27 October 2005 02:14 |
Paul,
The structure looks good. I can't think of anything that changed after M6.
The error you were getting in the orginal post is very low-level and is
indicating to me that the runtime plugin is not starting. Try the following
to investigate further.
- put -console -noexit on the command line. This should give you an OSGi
console and stop Equionx from exiting
- at the osgi> prompt, type ss (short status)
- you should see a list of bundles.
- look at the list carefully. You want everything to be in RESOLVED or
ACTIVE state. plugins that are in INSTALLED state are potential problems.
- for any bundle that is listed as INSTALLED, get its number and type diag
NN where NN is the bundle id number.
- this should report the reasons why it is not RESOLVED or ACTIVE.
- if you find some problems, try to fix them.
The only other thing I can think of is that the product definition should
specify the application. Please ensure that hte product extension has the
correct application id.
For now that is all I can think of.
Jeff
news:djo6ed$oab$1@news.eclipse.org...
> Jeff,
during
the
find
> INSTALL_LOC/
> startup.jar
> eclipse.ini
> eclipse.exe
> .eclipseproduct
> /workspace
> /plugins
> /features
> feature.xml
> feature.xml
> /configuration
> config.ini
> on
> depends on:
> id="org.apache.ant"
> id="org.eclipse.ui"
> id="org.junit"
> thanks in advance
> Paul
> gives
of
> > the bundles.
> > Jeff
error:
> > > > > Thanks Jeff,
For
> > > this
this
> > > worked
> > > migration
(we
> > have
> > > > > on
> > have
> > > a
> > > > > feature.xml:
> > > plugins
used
> > > > > previously:
> > > > > eclipse.exe
> > > > > startup.jar
> > > > > .eclipseproduct
> > > > > "C:\Program
one
> > > > bundle,
> > > > > which one(s)?
> > > > > osgi.bundles =??
> > > > > Paul
> > > > > > A couple things.
I
> > > > suspect
> > listed
> > > > on
a -D
> vm
> > > > arg.
launcher,
> PRODUCT
> > > and
> > > > > > Jeff
> > > > > > > thx
that
> > all
> > > > > > > plugins,
> > > > > application
> > > self-extracting
my
> > > > > > functional
> > > > "shoddy"
this
> > > error
> > > > > is.
> not
> > > > > > > connecting
> > > > > > > > EclipseStarter.java
> > > > > //$NON-NLS-1$
> > > > > > > > if (!running)
> > > > > > > > throw new
> > just
> > > > > > return.
> > > > > > > > if (initialize)
"applicaton
> > > > tracker
message
> application
> > > will
> > > > > not
> > > > > > > run
> > > > > configuration
> > > > > > > from
> > > > > > > > > the IDE).
> > find
> > > > it.
> > > > > > > This
> > > > > > > > > occurs
> > > > > > > > > !STACK 1
> application
> > > > > > service.
> > > > > > > > > at
> > > > > > > > > at
> > Method)
> > Source)
> > > > > > > > > at
> > > > Source)
> > > > > > > > > at
Re: RCP App Fails on startup: IllegalStateException [message #52047 is a reply to message #51817] |
Tue, 01 November 2005 17:50 |
Thanks Jeff, I'll take a look.
Also, it sounds like you're saying that an RCP application need only define
provided eclipse.product and eclipse.application are defined and that the
remaining configuration is "correct"?
news:djpd4e$8qk$1@news.eclipse.org...
> Paul,
M6.
following
> Jeff
> > Jeff,
> during
> the
> find
for
the
primary
> > INSTALL_LOC/
> > startup.jar
> > eclipse.ini
> > eclipse.exe
> > .eclipseproduct
> > /workspace
> > /plugins
> > /features
> > feature.xml
> > feature.xml
> > /configuration
> > config.ini
> > on
> > depends on:
> > id="org.apache.ant"
> > id="org.eclipse.ui"
> > id="org.junit"
> > thanks in advance
> > Paul
> > gives
> of
> > > the bundles.
> > > Jeff
> error:
> > > > > > Thanks Jeff,
> For
> > > > this
> this
> > > > worked
> > > > migration
> (we
> > > have
> > > > > > on
which
> > > have
> > > > a
> > > > > > feature.xml:
proprietary
> > > > plugins
> used
> > > > > > previously:
> > > > > > eclipse.exe
> > > > > > startup.jar
> > > > > > .eclipseproduct
> > > > > > "C:\Program
> one
> > > > > bundle,
> > > > > > which one(s)?
> > > > > > osgi.bundles =??
> > > > > > Paul
> > > > > > > A couple things.
> I
> > > > > suspect
be
> > > listed
> > > > > on
> a -D
> > vm
> > > > > arg.
> launcher,
> > PRODUCT
> > > > and
> > > > > > > Jeff
> > > > > > > > thx
message
> that
> > > all
> > > > > > > > plugins,
the
> > > > > > application
> > > > self-extracting
in
> my
> > > > > > > functional
is
> > > > > "shoddy"
> this
> > > > error
> > > > > > is.
I'm
> > not
> > > > > > > > connecting
> > > > > > > > > EclipseStarter.java
Exception
> > > > > > //$NON-NLS-1$
> > > > > > > > > if (!running)
> > > > > > > > > throw new
application
> > > just
> > > > > > > return.
> > > > > > > > > if (initialize)
> "applicaton
> > > > > tracker
> message
> > application
> > > > will
> > > > > > not
> > > > > > > > run
> > > > > > configuration
> > > > > > > > from
> > > > > > > > > > the IDE).
to
> > > find
> > > > > it.
> > > > > > > > This
> > > > > > > > > > occurs
> > > > > > > > > > !STACK 1
> > application
> > > > > > > service.
> > > > > > > > > > at
> > > > > > > > > > at
> > > Method)
> > > Source)
> > > > > > > > > > at
> > > > > Source)
> > > > > > > > > > at
> > > > > > > > > > at
Re: RCP App Fails on startup: IllegalStateException [message #52126 is a reply to message #52047] |
Wed, 02 November 2005 03:24 |
Paul, what I am suggesting is a config.ini that looks like
eclipse.product=<your product id here>
The product extension should then identify the application to use when
running that product.
Jeff
news:dk89t0$6fl$1@news.eclipse.org...
define
> > Paul,
> M6.
> following
OSGi
problems.
diag
should
the
> > Jeff
> > > Jeff,
> > during
into
> > the
image.
plugins
my
> > find
> for
> the
> primary
> > > INSTALL_LOC/
> > > startup.jar
> > > eclipse.ini
> > > eclipse.exe
> > > .eclipseproduct
> > > /workspace
> > > /plugins
> > > /features
> > > feature.xml
> > > feature.xml
> > > /configuration
> > > config.ini
> > > on
> > > depends on:
> > > id="org.apache.ant"
> > > id="org.eclipse.ui"
> > > id="org.junit"
> > > thanks in advance
> > > Paul
runtime
> > > gives
rest
> > of
> > > > the bundles.
> > > > Jeff
> > error:
> > > > > > > Thanks Jeff,
bug.
> > For
> > > > > this
> > this
> > > > > worked
the
> > > > > migration
entries
> > (we
> > > > have
> > > > > > > on
> which
> > > > have
> > > > > a
> > > > > > > feature.xml:
> proprietary
> > > > > plugins
> > used
> > > > > > > previously:
> > > > > > > eclipse.exe
> > > > > > > startup.jar
> > > > > > > .eclipseproduct
previously:
> > > > > > > "C:\Program
least
> > one
> > > > > > bundle,
> > > > > > > which one(s)?
> > > > > > > osgi.bundles =??
> > > > > > > Paul
message
> > > > > > > > A couple things.
plugin.
> > I
> > > > > > suspect
> be
> > > > listed
> > > > > > on
> > a -D
> > > vm
> > > > > > arg.
> > launcher,
> > > PRODUCT
> > > > > and
> > > > > > > > Jeff
message
> > > > > > > > > thx
> message
so
> > that
> > > > all
> > > > > > > > > plugins,
> the
> > > > > > > application
> > > > > self-extracting
> in
> > my
> > > > > > > > functional
something
> is
> > > > > > "shoddy"
of
> > this
> > > > > error
> > > > > > > is.
> I'm
> > > not
> > > > > > > > > connecting
fail
> > > > > > > > > > EclipseStarter.java
> Exception
null);
> > > > > > > //$NON-NLS-1$
> > > > > > > > > > if (!running)
> > > > > > > > > > throw new
> application
> > > > just
> > > > > > > > return.
> > > > > > > > > > if (initialize)
> > "applicaton
> > > > > > tracker
> > message
> > > application
> > > > > will
> > > > > > > not
> > > > > > > > > run
launch
> > > > > > > configuration
> > > > > > > > > from
> > > > > > > > > > > the IDE).
seem
> to
> > > > find
> > > > > > it.
> > > > > > > > > This
> > > > > > > > > > > occurs
not.
> > > > > > > > > > > !STACK 1
> > > application
> > > > > > > > service.
> > > > > > > > > > > at
> > > > > > > > > > > at
> > > > > > > > > > > at
> > > > Method)
> > > > > > > > > > > at
> > > > Source)
> > > > > > > > > > > at
> > > > > > Source)
> > > > > > > > > > > at
> > > > > > > > > > > at
Re: RCP App Fails on startup: IllegalStateException [message #52313 is a reply to message #52126] |
Wed, 02 November 2005 18:02 |
Thanks, I just wanted to make sure that I was clear on that-it's got to be
something in my environment.
news:dk9bgo$fqr$1@news.eclipse.org...
> Jeff
> define
the
> > > Paul,
after
> > M6.
is
> > following
> OSGi
or
> problems.
> diag
> should
> the
> > > Jeff
> > > > Jeff,
> > > during
> into
> > > the
> image.
> plugins
in
> my
not
> > > find
requirements
> > for
in
> > the
> > primary
M6.
> > > > INSTALL_LOC/
> > > > startup.jar
> > > > eclipse.ini
> > > > eclipse.exe
> > > > .eclipseproduct
> > > > /workspace
> > > > /plugins
> > > > /features
> > > > feature.xml
> > > > feature.xml
> > > > /configuration
> > > > config.ini
> > > > on
application
> > > > depends on:
> > > > id="org.apache.ant"
> > > > id="org.eclipse.ui"
> > > > id="org.junit"
> > > > thanks in advance
> > > > Paul
> runtime
> > > > gives
> rest
> > > of
> > > > > the bundles.
> > > > > Jeff
> > > error:
> > > > > > > > Thanks Jeff,
> bug.
> > > For
> > > > > > this
as
> > > this
> > > > > > worked
> the
> > > > > > migration
> entries
> > > (we
> > > > > have
> > > > > > > > on
> > which
> > > > > have
> > > > > > a
> > > > > > > > feature.xml:
> > proprietary
> > > > > > plugins
we've
> > > used
> > > > > > > > previously:
> > > > > > > > eclipse.exe
> > > > > > > > startup.jar
> > > > > > > > .eclipseproduct
> previously:
> > > > > > > > "C:\Program
> least
> > > one
> > > > > > > bundle,
> > > > > > > > which one(s)?
> > > > > > > > osgi.bundles =??
> > > > > > > > Paul
> message
> > > > > > > > > A couple things.
> plugin.
> > > I
> > > > > > > suspect
should
> > be
> > > > > listed
> > > > > > > on
as
> > > a -D
> > > > vm
> > > > > > > arg.
> > > launcher,
a
> > > > PRODUCT
> > > > > > and
> > > > > > > > > Jeff
> message
> > > > > > > > > > thx
> > message
> so
> > > that
> > > > > all
> > > > > > > > > > plugins,
for
> > the
> > > > > > > > application
> > > > > > self-extracting
used
> > in
> > > my
> > > > > > > > > functional
> something
> > is
> > > > > > > "shoddy"
> of
> > > this
> > > > > > error
> > > > > > > > is.
but
> > I'm
> > > > not
> > > > > > > > > > connecting
> fail
> > > > > > > > > > > EclipseStarter.java
> > Exception
> null);
> > > > > > > > //$NON-NLS-1$
> > > > > > > > > > > if (!running)
> > > > > > > > > > > throw new
> > application
> > > > > just
> > > > > > > > > return.
> > > > > > > > > > > if (initialize)
> > > "applicaton
> > > > > > > tracker
> > > message
> > > > application
> > > > > > will
> > > > > > > > not
> > > > > > > > > > run
> launch
> > > > > > > > configuration
> > > > > > > > > > from
> > > > > > > > > > > > the IDE).
> seem
> > to
> > > > > find
> > > > > > > it.
> > > > > > > > > > This
> > > > > > > > > > > > occurs
> not.
> > > > > > > > > > > > !STACK 1
> > > > application
> > > > > > > > > service.
> > > > > > > > > > > > at
> > > > > > > > > > > > at
> > > > > > > > > > > > at
> > > > > Method)
> > > > > > > > > > > > at
> > > > > Source)
> > > > > > > > > > > > at
> > > > > > > Source)
> > > > > > > > > > > > at
> > > > > > > > > > > > at
> > > > > > > > > > > > at
> > > > > > > > > > > > at
Re: RCP App Fails on startup: IllegalStateException [message #52392 is a reply to message #52126] |
Thu, 03 November 2005 21:44 |
Resolved!
As expected, it was configuration. A dependent emf plugin wasn't getting
exported the build location. The confusing part was that the error messages
referred to a bogus plugin version "0.0.0":
!ENTRY org.eclipse.osgi 2005-11-03 12:06:28.579
!MESSAGE Bundle
update@plugins/com.eyeris.eyeprofit.ui.core.model.editor_1.0.9/ [13] was not
resolved.
!SUBENTRY 1 org.eclipse.osgi 2005-11-03 12:06:28.579
!MESSAGE Missing required bundle
com.eyeris.eyeprofit.ui.project.validator_0.0.0.
com.eyeris.eyeprofit.ui.datasource.model.editor_0.0.0.
Thanks alot for your help.
p
> Jeff
> define
the
> > > Paul,
after
> > M6.
is
> > following
> OSGi
or
> problems.
> diag
> should
> the
> > > Jeff
> > > > Jeff,
> > > during
> into
> > > the
> image.
> plugins
in
> my
not
> > > find
requirements
> > for
in
> > the
> > primary
M6.
> > > > INSTALL_LOC/
> > > > startup.jar
> > > > eclipse.ini
> > > > eclipse.exe
> > > > .eclipseproduct
> > > > /workspace
> > > > /plugins
> > > > /features
> > > > feature.xml
> > > > feature.xml
> > > > /configuration
> > > > config.ini
> > > > on
application
> > > > depends on:
> > > > id="org.apache.ant"
> > > > id="org.eclipse.ui"
> > > > id="org.junit"
> > > > thanks in advance
> > > > Paul
> runtime
> > > > gives
> rest
> > > of
> > > > > the bundles.
> > > > > Jeff
> > > error:
> > > > > > > > Thanks Jeff,
> bug.
> > > For
> > > > > > this
as
> > > this
> > > > > > worked
> the
> > > > > > migration
> entries
> > > (we
> > > > > have
> > > > > > > > on
> > which
> > > > > have
> > > > > > a
> > > > > > > > feature.xml:
> > proprietary
> > > > > > plugins
we've
> > > used
> > > > > > > > previously:
> > > > > > > > eclipse.exe
> > > > > > > > startup.jar
> > > > > > > > .eclipseproduct
> previously:
> > > > > > > > "C:\Program
> least
> > > one
> > > > > > > bundle,
> > > > > > > > which one(s)?
> > > > > > > > osgi.bundles =??
> > > > > > > > Paul
> message
> > > > > > > > > A couple things.
> plugin.
> > > I
> > > > > > > suspect
should
> > be
> > > > > listed
> > > > > > > on
as
> > > a -D
> > > > vm
> > > > > > > arg.
> > > launcher,
a
> > > > PRODUCT
> > > > > > and
> > > > > > > > > Jeff
> message
> > > > > > > > > > thx
> > message
> so
> > > that
> > > > > all
> > > > > > > > > > plugins,
for
> > the
> > > > > > > > application
> > > > > > self-extracting
used
> > in
> > > my
> > > > > > > > > functional
> something
> > is
> > > > > > > "shoddy"
> of
> > > this
> > > > > > error
> > > > > > > > is.
but
> > I'm
> > > > not
> > > > > > > > > > connecting
> fail
> > > > > > > > > > > EclipseStarter.java
> > Exception
> null);
> > > > > > > > //$NON-NLS-1$
> > > > > > > > > > > if (!running)
> > > > > > > > > > > throw new
> > application
> > > > > just
> > > > > > > > > return.
> > > > > > > > > > > if (initialize)
> > > "applicaton
> > > > > > > tracker
> > > message
> > > > application
> > > > > > will
> > > > > > > > not
> > > > > > > > > > run
> launch
> > > > > > > > configuration
> > > > > > > > > > from
> > > > > > > > > > > > the IDE).
> seem
> > to
> > > > > find
> > > > > > > it.
> > > > > > > > > > This
> > > > > > > > > > > > occurs
> not.
> > > > > > > > > > > > !STACK 1
> > > > application
> > > > > > > > > service.
> > > > > > > > > > > > at
> > > > > > > > > > > > at
> > > > > > > > > > > > at
> > > > > Method)
> > > > > > > > > > > > at
> > > > > Source)
> > > > > > > > > > > > at
> > > > > > > Source)
> > > > > > > > > > > > at
> > > > > > > > > > > > at
> > > > > > > > > > > > at
> > > > > > > > > > > > at
Current Time: Fri Apr 19 20:07:40 GMT 2024
Powered by FUDForum. Page generated in 0.06569 seconds
