Home » Eclipse Projects » Eclipse Platform » How to correctly integrate a milestone build?
How to correctly integrate a milestone build? [message #498102] Sat, 14 November 2009 13:49 Go to next message
Originally posted by: formatzeh.gmx.de
I want to use the EMF 2.6.0M2 milestone [1] because the fixed bug 255786
promises some new power in automatic model validation. So I downloaded
the All-In-One SDK from [1] and put the content of the zip into a new
folder in the dropins folder. But when opening Eclipse the only version
which will be displayed in the plug-ins tab in the installation details
is 2.5.0. That's why I'm asking for help how to integrate a milestone
correctly.
[1]
http://www.eclipse.org/modeling/emf/downloads/?project=emf&a mp;showAll=1&hlbuild=S200909211047#S200909211047
[2] https://bugs.eclipse.org/bugs/show_bug.cgi?id=255786
Re: How to correctly integrate a milestone build? [message #498112 is a reply to message #498102] Sat, 14 November 2009 15:43 Go to previous messageGo to next message
David Wegener is currently offline David WegenerFriend
> correctly.
> [1]
Why not just run the milestone build?
If you want to try just incorporating the EMF changes follow the
directions here:http://www.eclipse.org/modeling/emf/updates/ to add the
milestones update sight to update manager.
Re: How to correctly integrate a milestone build? [message #498120 is a reply to message #498112] Sat, 14 November 2009 17:34 Go to previous messageGo to next message
Hi David,
sorry for the stupid question but how do I do this? Until now I have no
experiences with milestone builds.
I added http://download.eclipse.org/modeling/emf/updates/milestones/ to
the update sites and only checked "EMF/XSD All in one SDK" to install.
But I got the following error messages:
Cannot complete the install because one or more required items could not
be found.
Software being installed: EMF/XSD All-In-One SDK 2.6.0.v200911060804
(org.eclipse.emf.all.feature.group 2.6.0.v200911060804)
Missing requirement: XSD to Ecore Mapping 2.5.0.v200911060804
(org.eclipse.emf.mapping.xsd2ecore 2.5.0.v200911060804) requires 'bundle
org.eclipse.core.runtime [3.6.0,4.0.0)' but it could not be found
Cannot satisfy dependency:
To: org.eclipse.xsd.sdk.feature.group [2.6.0.v200911060804]
(org.eclipse.xsd.mapping.feature.group 2.6.0.v200911060804)
To: org.eclipse.emf.mapping.xsd2ecore [2.5.0.v200911060804]
From: XSD - XML Schema Definition SDK 2.6.0.v200911060804
(org.eclipse.xsd.sdk.feature.group 2.6.0.v200911060804)
To: org.eclipse.xsd.mapping.feature.group [2.6.0.v200911060804]
Seems that I need Eclipse 3.6? I thought that I just can install an
update into my Galileo version.
Re: How to correctly integrate a milestone build? [message #498123 is a reply to message #498120] Sat, 14 November 2009 18:06 Go to previous messageGo to next message
> Hi David,
A Milestone build is the same as a regular build. Unzip it to a
directory on your computer and run eclipse/eclipse.exe depending on your
platform.
> be found.
> From: EMF/XSD All-In-One SDK 2.6.0.v200911060804
> From: XSD Mapping 2.6.0.v200911060804
The 2.6 version looks to have been developed against the 3.6 Eclipse
version. Plugins have version dependencies since they depend on
specific behaviors in their dependent plugins. You have to have the
required minimum version in order to run the plugin.
Re: How to correctly integrate a milestone build? [message #498181 is a reply to message #498123] Sun, 15 November 2009 16:12 Go to previous message
Ok thanks, now I took Eclipse 3.6 and could install the EMF build.
Previous Topic:How to wait on refresh during headless project creation from a CLI?
Next Topic:simple search for projects(etc..) by name
Current Time: Fri May 25 07:27:01 GMT 2018
Powered by FUDForum. Page generated in 0.02153 seconds
