Home » Language IDEs » C / C++ IDE (CDT) » error with gsl eclipse (even simple code does not excuted.)
error with gsl eclipse [message #497917] Fri, 13 November 2009 14:48 Go to next message
yaseen  is currently offline yaseen Friend
Hi...
I tried to run the following simple program in C++ in Eclipse (with CDT), using the GNU Scientific Library:
#include <iostream>
#include<conio.h>
#include<cmath>
#include <gsl/gsl_statistics.h>
using namespace std;
int main()
double data[5] = {17.2, 18.1, 16.5, 18.3, 12.6};
double mean;
mean = gsl_stats_mean(data, 1, 5);
cout<< mean <<endl;
return 0;
I've indicated the include directory and linked the libraries relevant to GSL.
I got the error:
**** Internal Builder is used for build ****
g++ -IC:\Program Files\eclipse\GnuWin32\include -O0 -g3 -Wall -c -fmessage-length=0 -osrc\reg.o ..\src\reg.cpp
g++ -LC:\Program Files\eclipse\GnuWin32\lib -oreg.exe src\reg.o -lgsl
g++: Files\eclipse\GnuWin32\lib: No such file or directory
Build error occurred, build is stopped
Time consumed: 625 ms.
any help please....!!!??
Re: error with gsl eclipse [message #497965 is a reply to message #497917] Fri, 13 November 2009 14:52 Go to previous messageGo to next message
Derek is currently offline DerekFriend
Member
On 13/11/2009 14:48, yaseen wrote:
> Hi...
> #include <iostream>
> #include<conio.h>
> #include<cmath>
> int main()
> double mean;
> cout<< mean <<endl;
> return 0;
> to GSL.
> I got the error:
> Time consumed: 625 ms. any help please....!!!??
Surround the path in quotes:
g++ -L"C:\Program Files\eclipse\GnuWin32\lib" -oreg.exe src\reg.o -lgsl
Derek
Re: error with gsl eclipse [message #497967 is a reply to message #497965] Fri, 13 November 2009 15:15 Go to previous messageGo to next message
Thank you for this fast replay
it is solved....the path directory was wrong.
thanks again.
[Updated on: Fri, 13 November 2009 15:38]
Report message to a moderator
Re: error with gsl eclipse [message #497988 is a reply to message #497967] Fri, 13 November 2009 15:39 Go to previous message
Member
On 13/11/2009 15:15, yaseen wrote:
> Thank you for this fast replay but i already have this path and it is
> correct. could you give me more advice please....
> thanks in advance
I told you. If the path contains spaces, it *must* be surrounded in
quotes. This applies to anything you do in Windows, not just Eclipse.
Derek
Previous Topic:Class definition
Next Topic:Re: Lua DLL
Current Time: Sun Apr 22 12:47:48 GMT 2018
Powered by FUDForum. Page generated in 0.02025 seconds
