Home » Eclipse Projects » DTP » Need help generating the SQL Parser(SQL Parser)
Need help generating the SQL Parser [message #497074] Thu, 12 November 2009 13:12 Go to next message
aiquefernandez  is currently offline aiquefernandez Friend
Hi!.
Recently I was working with the SQL Parser generated with de DTP project, but I've lost it.
I'm building a new environment, but I don´t know how to generate the SQL Parser on my own. I've downloaded the Eclipse, with the EMF, GEF, LPG and DTP jars, but if I try to write the code from http://www.eclipse.org/datatools/project_sqldevtools/sqltool s_doc/SQL%20Query%20Parser%20User%20documentation.htm the SQLQueryParserManager class doesn`t appear. How can I generate the parser?.
Thank for the help, I'm really stuck in the project Sad.
Re: Need help generating the SQL Parser [message #503344 is a reply to message #497074] Sat, 12 December 2009 00:08 Go to previous message
Brian Payton is currently offline Brian PaytonFriend
Can you explain more about what you are trying to do? I don't
understand the part about the SQLQueryParserManager class not appearing.
You should get that class with a standard download of DTP. It's in
the org.eclipse.datatools.sqltools.parsers.sql.query plugin.
aiquefernandez wrote:
> Hi!.
> parser?.
> Thank for the help, I'm really stuck in the project :(.
Previous Topic:unable to build Stored procedures
Next Topic:Need help generating the SQL Parser
Current Time: Fri Feb 23 15:15:11 GMT 2018
Powered by FUDForum. Page generated in 0.01410 seconds
