Home » Eclipse Projects » BIRT » Referencing parameter by name
Referencing parameter by name [message #495840] Fri, 06 November 2009 11:46 Go to next message
Missing name Missing name is currently offline Missing name Missing nameFriend
Member
Im using the BIRT report designed with a query of the form
select * from myTable where col1 = ? and col2 = ?
where I have defined two input parameters
param1 and param2 which are integers.
This works fine but if I want to do something along the lines of
select * from myTable where col1 = ? and col2 = ? and col3 < ?
it complains about binding, as I assume its confused about which parameter I am comparing against col3. Is it possible to use a parameter more than once in a query, like I want to do?
Can I reference the parameters by name rather than ? such as
select * from myTable where col1 = param1 and col2 = param2 and col3 < param2
I tried various combinations of params["param2"].value and :param2 but cant get it to work
thanks
Tom
[Updated on: Fri, 06 November 2009 11:47]
Report message to a moderator
Re: Referencing parameter by name [message #495949 is a reply to message #495840] Fri, 06 November 2009 18:18 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Tom,
Either just create a 3rd parameter and set it to the same thing as the
second or drop the dataset parameters and do the query in the before
open script
this.queryText = "select * from myTable where col1 = " +
jsvar/reportparm + ....
Jason
TREVOR.HIGGINS@FINEOS.COM wrote:
> param2
> cant get it to work
> thanks
> Tom
Re: Referencing parameter by name [message #496079 is a reply to message #495949] Sun, 08 November 2009 04:44 Go to previous messageGo to next message
Colin Sutton is currently offline Colin SuttonFriend
Hi jason,
This sounds like it could be very useful for me. Could you be a bit more explicit?
What would the code be to pick up param1, param2 and param3?
Colin
Jason Weathersby wrote:
> Tom,
> open script
> Jason
>> param2
>> cant get it to work
>> thanks
>> Tom
Re: Referencing parameter by name [message #496173 is a reply to message #495840] Mon, 09 November 2009 09:30 Go to previous messageGo to next message
Member
Thanks Jason - I created a third dataset parameter and bound it to an existing report parameter and this worked perfectly (not exactly the most intuitive way of doing it but it works!)
So basically I have the following binding:
Dataset Report
param1 -> param1
param2 -> param2
param3 -> param2
thanks for the help
Re: Referencing parameter by name [message #496336 is a reply to message #496079] Mon, 09 November 2009 18:04 Go to previous messageGo to next message
Colin
What code do you want?
Jason
Colin wrote:
> Hi jason,
> explicit?
> Colin
>> Tom,
>> open script
>> Jason
>>> Hi,
>>> < param2
>>> thanks
>>> Tom
Re: Referencing parameter by name [message #496391 is a reply to message #496336] Mon, 09 November 2009 20:09 Go to previous messageGo to next message
I have a report with two parameters which I match dozens of times in a query on multiple database
sources.
It's tedious matching all the ? and setting dataset param1, param2, ... all to the same report
parameter.
In the example below would the complete before open script be:
this.queryText = "select * from myTable where col1 = " + jsvar/reportparam1 + " and col2 = "
jsvar/reportparam2 " and col3 < " jsvar/reportparam1
Colin
> Colin
> Jason
> Colin wrote:
>> Hi jason,
>> more explicit?
>> Regards,
>> Colin
>>> Tom,
>>> the second or drop the dataset parameters and do the query in the
>>> before open script
>>> Jason
>>>> Hi,
>>>> < param2
>>>> thanks
>>>> Tom
Re: Referencing parameter by name [message #496404 is a reply to message #496079] Mon, 09 November 2009 21:57 Go to previous messageGo to next message
Scott Rosenbaum is currently offline Scott RosenbaumFriend
One other approach is to do your DataBinding after the report runs. We have
created a Script Function that does just that.
Have a look at the project where we are hosting this here. http://code.google.com/p/birt-functions-lib/
The specific function you are looking for is http://code.google.com/p/birt-functions-lib/wiki/BindParamet ers.
Using this function your SQL would like this:
select *
from myTable
where 0 = 0
/* BIND AND col1 = $param1 */
/* BIND AND col2 = $param2 */
/* BIND AND col3 < $param2 */
Where param1 and param2 are the names of the parameters. All you have to
do is install the plugin using the update manager, and you should be able
to use these functions.
Works great for multi-select parameters too.
Scott Rosenbaum
> Hi jason,
> more explicit? What would the code be to pick up param1, param2 and
> param3?
> Colin
>> Tom,
>> before open script
>> Jason
>>> Hi,
>>> < param2
>>> thanks
>>> Tom
Re: Referencing parameter by name [message #496602 is a reply to message #496391] Tue, 10 November 2009 16:07 Go to previous message
Colin,
That is correct. Reference report parameters like
params["myreportname"].value
Jason
> query on multiple database sources.
> all to the same report parameter.
> jsvar/reportparam1 + " and col2 = " jsvar/reportparam2 " and col3 < "
> jsvar/reportparam1
> Colin
>> Colin
>> Jason
>> Colin wrote:
>>> Hi jason,
>>> more explicit?
>>> Regards,
>>> Colin
>>>> Tom,
>>>> before open script
>>>> Jason
>>>>> Hi,
>>>>> col3 < param2
>>>>> thanks
>>>>> Tom
Previous Topic:Birt view in an eclipse project
Next Topic:Reset page number for each master page
Current Time: Tue Jun 19 12:57:45 GMT 2018
Powered by FUDForum. Page generated in 0.03051 seconds
