Home » Eclipse Projects » Remote Application Platform (RAP) » [Tree] Focus Problem
( ) 1 Vote
| [Tree] Focus Problem [message #495242] |
Wed, 04 November 2009 05:23  |
Steffen Messages: 14 Registered: September 2009 |
Junior Member |
i have found an issue in the Tree-Control.
Tested against CVS-Head (4th November).
The Problem:
You click (also doubleclick) on a TreeItem to set the focus to a specific Text-Control. The Text-Control get its focusGain-Event and there seems to be no problem. However, if you click a second time on the same TreeItem so that the same Text-Control should gain the focus it does not get the focus. I expect by clicking on a TreeItem the Text-Ctrl get first a focusLost-Event because the Tree-Control gain the Focus but this is not the case. Only if you manually set the focus to another control, e.g. with your mousepointer, the Text-Ctrl get the focusLost-Event and you are able to reset the focus to the same Text-Ctrl by clicking on the appropriate TreeItem.
Strangely, if you use a Table-Control instead you can't reproduce this problem. By using this control the Text-Control always get the focusLost-Event.
In following source you can find a sample-code for testing. Implemented is also a Table-Control to see the difference.
package raptest;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.FocusEvent;
import org.eclipse.swt.events.FocusListener;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.events.SelectionListener;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.layout.RowData;
import org.eclipse.swt.layout.RowLayout;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableItem;
import org.eclipse.swt.widgets.Text;
import org.eclipse.swt.widgets.Tree;
import org.eclipse.swt.widgets.TreeItem;
public class MClass
enum CtrlEnum
Ctrl_1,
Ctrl_2,
Ctrl_3,
enum EventDialog
TextDlg,
TreeDlg,
TableDlg,
private TextDialog textDialog;
private TreeDialog treeDialog;
private TableDialog tableDialog;
public MClass(Display display)
// Init Dialogs and size/locate them
textDialog = new TextDialog(display, this);
treeDialog = new TreeDialog(display, this);
tableDialog = new TableDialog(display, this);
textDialog.setSize(400,200);
treeDialog.setSize(400,200);
tableDialog.setSize(400,200);
textDialog.setLocation(50,50);
treeDialog.setLocation(50,250);
tableDialog.setLocation(50,450);
textDialog.layout(true,true);
textDialog.open();
treeDialog.open();
tableDialog.open();
blockShell(treeDialog);
public static void blockShell(Shell shell)
Display display = null;
if (shell == null)
display = Display.getCurrent();
else
display = shell.getDisplay();
while (shell != null && !shell.isDisposed())
if (!display.readAndDispatch())
display.sleep();
public void ClickedEventHandler(CtrlEnum ctrlEnum, EventDialog eventDialog)
if(eventDialog != EventDialog.TextDlg)
textDialog.setFocusToItem(ctrlEnum);
if(eventDialog != EventDialog.TreeDlg)
treeDialog.setFocusToItem(ctrlEnum);
if(eventDialog != EventDialog.TableDlg)
tableDialog.setFocusToItem(ctrlEnum);
public class TextDialog extends Shell
private Tree tree;
public TextDialog(Display display, final MClass mClass)
super(display);
this.getShell().setText("TextDialog");
RowLayout rowLayout = new RowLayout();
//rowLayout.pack = true;
rowLayout.type = SWT.VERTICAL;
rowLayout.fill = true;
this.setLayout(rowLayout);
for(CtrlEnum ctrlEnum : CtrlEnum.values())
Text text = new Text(this, SWT.BORDER);
text.setData(ctrlEnum);
text.setText(ctrlEnum.toString());
Point size = text.computeSize(SWT.DEFAULT, SWT.DEFAULT);
text.setLayoutData(new RowData(200, size.y));
// Give every Text-Control a FocusListener
text.addFocusListener(new FocusListener()
public void focusLost(FocusEvent event)
Text text = (Text)event.widget;
System.out.println("focusLost (" + text.getData().toString() + ")" + System.currentTimeMillis());
public void focusGained(FocusEvent event)
System.out.println("focusGain (" + text.getData().toString() + ")" + System.currentTimeMillis());
setFocusToTreeItem((CtrlEnum) text.getData());
mClass.ClickedEventHandler((CtrlEnum) text.getData(), EventDialog.TextDlg);
tree = new Tree(this, SWT.SINGLE | SWT.BORDER);
tree.setSize(100, 100);
TreeItem treeItem = new TreeItem(tree, SWT.NONE);
treeItem.setData(ctrlEnum);
treeItem.setText(ctrlEnum.toString());
tree.addSelectionListener(new SelectionListener()
public void widgetSelected(SelectionEvent e){ }
public void widgetDefaultSelected(SelectionEvent e)
TreeItem[] selItems = tree.getSelection();
if(selItems.length > 0)
// we have a Single-Selection
System.out.println("widgetDefaultSelected");
CtrlEnum ctrlEnum = (CtrlEnum) selItems[0].getData();
mClass.ClickedEventHandler(ctrlEnum, EventDialog.TreeDlg);
private void setFocusToTreeItem(CtrlEnum ctrlEnum)
for(TreeItem treeItem : tree.getItems())
CtrlEnum ctrlEnumData = (CtrlEnum) treeItem.getData();
if(ctrlEnum == ctrlEnumData)
treeItem.setText(treeItem.getData().toString() + " SELECTED");
else
treeItem.setText(treeItem.getData().toString());
public void setFocusToItem(CtrlEnum ctrlEnum)
// Search the matching Text-Control
for(Control control : getChildren())
if(control instanceof Text)
CtrlEnum ctrlEnumData = (CtrlEnum) control.getData();
Text text = (Text)control;
text.selectAll();
text.setFocus();
break;
setFocusToTreeItem(ctrlEnum);
public class TreeDialog extends Shell
private Tree tree;
public TreeDialog(Display display, final MClass mClass)
super(display);
this.getShell().setText("TreeDialog");
this.setLayout(new FillLayout());
tree = new Tree(this, SWT.SINGLE);
// Search the matching treeItem
else
public class TableDialog extends Shell
private Table table;
public TableDialog(Display display, final MClass mClass)
super(display);
this.getShell().setText("TableDialog");
table = new Table(this, SWT.SINGLE);
TableItem tableItem = new TableItem(table, SWT.NONE);
tableItem.setData(ctrlEnum);
tableItem.setText(ctrlEnum.toString());
table.addSelectionListener(new SelectionListener()
TableItem[] selItems = table.getSelection();
for(TableItem treeItem : table.getItems())
else
[Updated on: Wed, 04 November 2009 09:51] Report message to a moderator
| Re: [Tree] Focus Problem [message #496186 is a reply to message #495242] |
Mon, 09 November 2009 05:21   |
Junior Member |
Here the source a 2nd time:
RAP-Version: CVS-Head (4th November)
package raptest;
public class MClass
enum CtrlEnum
Ctrl_1,
Ctrl_2,
Ctrl_3,
enum EventDialog
TextDlg,
TreeDlg,
TableDlg,
textDialog.open();
treeDialog.open();
tableDialog.open();
if (shell == null)
else
display.sleep();
private Tree tree;
super(display);
else
text.selectAll();
text.setFocus();
break;
private Tree tree;
super(display);
else
super(display);
else
[Updated on: Mon, 09 November 2009 05:29] Report message to a moderator
| Re: [Tree] Focus Problem [message #496200 is a reply to message #496186] |
Mon, 09 November 2009 05:44   |
Ivan Furnadjiev Messages: 1562 Registered: July 2009 |
Hi Steffen,
the problem exists only if you click on the tree that is in non focused
(active) shell (dialog). If you have only one Shell - TextDialog for
example, everything is working as expected. The actual problem is that,
clicking on the Tree does not activate the parent shell. Please file a
bugzilla about this issue.
Best,
Ivan
> package raptest;
> import org.eclipse.swt.widgets.Display;
> public class MClass
> enum CtrlEnum
> Ctrl_1,
> Ctrl_2,
> Ctrl_3,
> enum EventDialog
> TextDlg,
> TreeDlg,
> TableDlg,
> textDialog.open();
> treeDialog.open();
> tableDialog.open();
> if (shell == null)
> else
> display.sleep();
> eventDialog)
> private Tree tree;
> super(display);
> @Override
> @Override
> @Override
> @Override
> SELECTED");
> else {
> text.selectAll();
> text.setFocus();
> break;
> private Tree tree;
> super(display);
> @Override
> @Override
> SELECTED");
> else {
> super(display);
> @Override
> @Override
> SELECTED");
> else {
Current Time: Tue Oct 08 08:02:59 EDT 2013
Powered by FUDForum. Page generated in 0.01839 seconds
