Home » Eclipse Projects » Remote Application Platform (RAP) » A simple button with a simple ListViewer simply doesn't work
A simple button with a simple ListViewer simply doesn't work [message #494313] Fri, 30 October 2009 08:52 Go to next message
Ralf Heydenreich is currently offline Ralf HeydenreichFriend
Hi all,
I get a very strange behaviour from my application. What I want is a
simple PushButton which opens a new Shell. This Shell should display a
List. There I've used a ListViewer. The first time I press the Button
all things are fine. But the second time the following message appears
in my browser window:
<begin_message>
Could not evaluate javascript response:
TypeError: w is undefined
org.eclipse.swt.EventUtil.suspendEventHandling();var req =
org.eclipse.swt.Request.getInstance();req.setRequestCounter( "24" );var
wm = org.eclipse.swt.WidgetManager.getInstance();var w =
wm.findWidgetById( "w103" );w.setBackgroundColor( "#cccccc" );var w =
wm.findWidgetById( "w26" );w.setSpace( 257, 94, -93, 94 );w.setActive(
true );var w = wm.newWidget( "w163", "w26", true, null,
"org.eclipse.swt.widgets.List" );w.init( true );w.addState( "rwt_BORDER"
);w.setOverflow( "auto" );w.setSpace( 0, 0, 0, 0 );w.setZIndex( 300
);w.setTabIndex( 1 );w.setChangeSelectionNotification( "action" );var w
= wm.findWidgetById( "w26" );w.setActiveControl( wm.findWidgetById(
"w163" ) );org.eclipse.swt.WidgetManager.getInstance().focus( "w163"
);qx.ui.core.Widget.flushGlobalQueues();org.eclipse.swt.Even tUtil.resumeEventHandling();
</begin_message>
Now some code fragments. In the constructor, I wrote:
* @param parent the parent shell
* @param container the container in which the element should be placed
public MySimpleListViewer(final Shell parent, Composite container) {
popupDialogShell = new Shell(parent, SWT.NONE);
init(container);
* Initializes the PushButton
* @param container the container in which the PushButton should
be placed
private void init(Composite container) {
button = new Button(container, SWT.PUSH);
button.setText("\u2026"); // only three dots
* Appends a SelectionListener to the Button. At first the
ListViewer
* is build and initialized.
public void activatePushButton() {
buildListViewer();
button.addSelectionListener(new SelectionAdapter(){
public void widgetSelected(SelectionEvent event) {
GridLayout gridLayout = new GridLayout(1, false);
popupDialogShell.setLayout(gridLayout);
if(listViewer.getContentProvider() == null)
buildListViewer();
popupDialogShell.pack();
popupDialogShell.open();
* This method builds the ListViewer and initializes it with
* the right values.
private void buildListViewer() {
GridData gridData = new GridData(GridData.HORIZONTAL_ALIGN_END);
gridData.horizontalAlignment = GridData.FILL;
gridData.heightHint = 180;
listViewer = new ListViewer(popupDialogShell);
// field contentProvider is set before
listViewer.setContentProvider(contentProvider);
// field labelProvider is set before
listViewer.setLabelProvider(labelProvider);
// field customListInput is set before
listViewer.setInput(customListInput);
listViewer.getList().setLayoutData(gridData);
// String[] selectedItems are all items which are previously selected
//(first time empty)
listViewer.getList().setSelection(selectedItems);
listViewer.getList().addFocusListener(new FocusAdapter() {
public void focusLost(FocusEvent e) {
if (listViewer.getList().getSelectionCount() > 0) {
StringBuffer sb = new StringBuffer();
for(String s: listViewer.getList().getSelection()) {
if(sb.length() > 0) sb.append(";");
sb.append(s);
System.out.println(sb.toString());
selectedItems = listViewer.getList().getSelection();
} else {
System.out.println("nothing selected");
popupDialogShell.close();
The fields contentProvider, labelProvider and customListInput are set
via Setters for my class and aren't null (checked with Debugger). Is
there anything what I've overseen? Or is there a completely different
solution? I've build this example in SWT, too. There it works fine.
TIA,
Ralf.
Re: A simple button with a simple ListViewer simply doesn't work [message #494319 is a reply to message #494313] Fri, 30 October 2009 09:27 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
Hi Ralf,
this is definitely a bug. Please file a bugzilla and attach a code to
reproduce it.
TIA,
Ivan
R. Heydenreich wrote:
> Hi all,
> <begin_message>
> </begin_message>
> init(container);
> be placed
> ListViewer
> buildListViewer();
> buildListViewer();
> * the right values.
> sb.append(s);
> } else {
> TIA,
> Ralf.
Re: A simple button with a simple ListViewer simply doesn't work [message #495245 is a reply to message #494319] Wed, 04 November 2009 10:32 Go to previous message
Ivan Furnadjiev schrieb:
> Hi Ralf,
> reproduce it.
Hi Ivan,
I've just opened a new bug. It was a little difficult to reproduce it
outside our complex application. But now I've got the same error in a
HelloWorld project. Please see Bug 294178. There I've attached a little
project for testing.
Ralf.
> TIA,
> Ivan
>> Hi all,
>> <begin_message>
>> </begin_message>
>> init(container);
>> be placed
>> ListViewer
>> buildListViewer();
>> buildListViewer();
>> * the right values.
>> for(String s:
>> sb.append(s);
>> selectedItems =
>> } else {
>> TIA,
>> Ralf.
Previous Topic:ConsoleView in RAP
Next Topic:Change UIThreads' name
Current Time: Sun Apr 22 03:20:31 GMT 2018
Powered by FUDForum. Page generated in 0.02035 seconds
