Home » Language IDEs » ServerTools (WTP) » What are Smoke Tests ?
What are Smoke Tests ? [message #494262] Thu, 29 October 2009 19:47 Go to next message
sNop is currently offline sNopFriend
Hi dev,
i want to ask you, what smoke tests are and what they serve.
Thank you
Re: What are Smoke Tests ? [message #494279 is a reply to message #494262] Thu, 29 October 2009 21:59 Go to previous messageGo to next message
Originally posted by: runzhou.li.gmail.com
Smoke test is a general name represents the most basic black box test. That
is, you test the desired features you want to test to make sure they work as
expected, but not covering other cases.
The rest of the test are generally handled by the SV&V team.
"sNop" <snop3@seznam.cz> ???? news:hccrfi$fl1$1@build.eclipse.org...
> Hi dev,
> Thank you
Re: What are Smoke Tests ? [message #494564 is a reply to message #494279] Sat, 31 October 2009 13:55 Go to previous messageGo to next message
Runzhou Li napsal(a):
> That is, you test the desired features you want to test to make sure
> they work as expected, but not covering other cases.
Ok, thank you
Re: What are Smoke Tests ? [message #500728 is a reply to message #494262] Fri, 27 November 2009 18:49 Go to previous message
David Williams is currently offline David WilliamsFriend
I used to think this term just used by a few companies, but then found
it defined in wikipedia!
http://en.wikipedia.org/wiki/Smoke_testing
So, it must be a legitimate term, right? (ha ha).
In WTP we like to have a smoke test before declaring a build, just to
make sure nothing really odd happened that would make it embarrassing to
announce to the world ... that the build is ready for further testing.
Previous Topic:Project not showing to add to tomcat server
Next Topic:Is there a Pretty Printer for JSDT DOM?
Current Time: Wed May 23 05:22:48 GMT 2018
Powered by FUDForum. Page generated in 0.02070 seconds
