Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Generate emtl file without acceleo nature?
[Acceleo] Generate emtl file without acceleo nature? [message #494221] Thu, 29 October 2009 15:57 Go to next message
Marcus  is currently offline Marcus Friend
I like to invoke the AcceleoService on template code without using the acceleoBuilder in the .project file. In other words, I like to manually invoke the acceleo compiler on the template code via API calls.
How can I generate the emtl file based on the template code (typically avaiable in a mtl file)?
Many thanks in advance.
Re: [Acceleo] Generate emtl file without acceleo nature? [message #494307 is a reply to message #494221] Fri, 30 October 2009 08:02 Go to previous message
Laurent Goubet is currently offline Laurent GoubetFriend
--------------060807000903090406050806
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi Markus,
You can take a look at the unit tests code, as we call the parser from
code to avoid cluttering these tests with emtl files. Specifically,
org.eclipse.acceleo.engine.tests.unit.AbstractAcceleoTest#pa rse(String)
is in charge of the parsing and emtl file creation.
Laurent Goubet
Obeo
Marcus a écrit :
Content-Type: text/x-vcard; charset=utf-8;
name="laurent_goubet.vcf"
Content-Disposition: attachment;
filename="laurent_goubet.vcf"
YmVnaW46dmNhcmQNCmZuOkxhdXJlbnQgR291YmV0DQpuOkdvdWJldDtMYXVy ZW50DQpvcmc6
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyLyI+T2JlbzwvYT4NCmVtYWls O2ludGVybmV0
OmxhdXJlbnQuZ291YmV0QG9iZW8uZnINCnVybDpodHRwOi8vd3d3Lm9iZW8u ZnINCnZlcnNp
b246Mi4xDQplbmQ6dmNhcmQNCg0K
--------------060807000903090406050806--
Previous Topic:[XPAND] accessing <<FILE ...>> from Java
Next Topic:Use case specification and transformation
Current Time: Sat Feb 24 20:03:49 GMT 2018
Powered by FUDForum. Page generated in 0.01498 seconds
