Home » Modeling » UML2 » Possible bug in UML2 Genmodel
Possible bug in UML2 Genmodel [message #493180] Fri, 23 October 2009 13:57 Go to next message
Originally posted by: florianwendland.freenet.de
Hi all,
just found a bug in the UML2 genmodel, when the code for an Ecore model,
which was imported from UML2 model, is generated. In fact, when you
going to subset a derived subset association end, the generator inserts
a EObject(Resolving)EList instead of a
SubsetSupersetEObjectResolvingEList. I changed it manually and it works
as supposed.
May i raise an issue at bugzilla?
Marc-Florian
Re: Possible bug in UML2 Genmodel [message #494199 is a reply to message #493180] Thu, 29 October 2009 14:50 Go to previous messageGo to next message
james bruck is currently offline james bruckFriend
Yes please go ahead and raise any bugzilla you see fit.
Please add more details in the bugzilla and possibly an example. From the
description below I'm not sure I fully understand whether there is an acutal
issue or not.
- James.
"Marc-Florian Wendland" <florianwendland@freenet.de> wrote in message
news:hbscog$atc$1@build.eclipse.org...
> Hi all,
> which was imported from UML2 model, is generated. In fact, when you going
> to subset a derived subset association end, the generator inserts a
> EObject(Resolving)EList instead of a SubsetSupersetEObjectResolvingEList.
> I changed it manually and it works as supposed.
> Marc-Florian
Re: Possible bug in UML2 Genmodel [message #628014 is a reply to message #493180] Thu, 29 October 2009 14:53 Go to previous message
issue or not.
- James.
> Hi all,
> Marc-Florian
Previous Topic:Creating UML diagrams programmatically
Next Topic:Creating UML diagrams programmatically
Current Time: Tue Feb 20 15:56:01 GMT 2018
Powered by FUDForum. Page generated in 0.01743 seconds
