Home » Modeling » EMF » Problem with href
Problem with href [message #492727] Wed, 21 October 2009 14:27 Go to next message
Originally posted by: fabrice.lima.lopes.gmail.com
I have a problem when I execute an ATL transformation programmatically.
The output XMI file is generated strangely, there are "href" everywhere :
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:s2="http://www.sebastian2.com/ecore/referential"
xmlns:s2c=" http://www.sebastian2.com/ecore/referential/creationcontaine r"
xmlns:s2m="http://www.sebastian2.com/ecore/referential/mediacontainer"
xmlns:s2r=" http://www.sebastian2.com/ecore/referential/resourcecontaine r"
xmlns:s2t=" http://www.sebastian2.com/ecore/referential/temporalcontaine r">
<s2:DomainModel>
<projects href="#/2"/>
</s2:DomainModel>
<s2r:Folder>
<essenceMasters href="#/8"/>
<essenceMasters href="#/9"/>
</s2r:Folder>
<s2:Project name="Projet Sebastian">
<temporalContainer>
<temporalSequenceMasters href="#/3"/>
</temporalContainer>
<creationContainer>
<contentUnits href="#/4"/>
</creationContainer>
</s2:Project>
</xmi:XMI>
I am expected something like this :
xmlns:s2r=" http://www.sebastian2.com/ecore/referential/resourcecontaine r">
<temporalContainer>
<temporalSequenceMasters title="SequenceEISTI" duration="480"
editing="/0/@creationContainer/@contentUnits.0/@mediaCreations.0 "/>
<creationContainer>
<contentUnits>
<mediaCreations xsi:type="s2c:Editing" name="SequenceEISTI">
<edits sourceOut="240" recordOut="240"
selectedVariant="/1/@essenceMasters.0"/>
<edits sourceOut="240" recordIn="240" recordOut="480"
selectedVariant="/1/@essenceMasters.1"/>
</mediaCreations>
</contentUnits>
</s2:Project>
<s2r:Folder>
<essenceMasters>
<fileInfo xsi:type="s2m:VideoFile" pixelWidth="720"
pixelHeight="486" frameNumber="240"/>
<nodeInfo name="EISTITitle06.mov"
path=" file://localhost/Users/zoubeida/Desktop/Test%20FCP%20Sebasti an/ProjetFabrice/EISTITitle06.mov"/>
</essenceMasters>
<essenceMasters>
<nodeInfo name="EISTITitle10.mov"
path=" file://localhost/Users/zoubeida/Desktop/Test%20FCP%20Sebasti an/ProjetFabrice/EISTITitl10.mov"/>
</essenceMasters>
</s2r:Folder>
</xmi:XMI>
Re: Problem with href [message #492731 is a reply to message #492727] Wed, 21 October 2009 14:36 Go to previous messageGo to next message
Fabrice,
It sounds like you are using non-containment references where really you
want containment references instead.
Fabrice LIMA LOPES wrote:
> Hello,
> programmatically. The output XMI file is generated strangely, there
> <s2:DomainModel>
> </s2:DomainModel>
> <s2r:Folder>
> </s2r:Folder>
> <temporalContainer>
> <creationContainer>
> </s2:Project>
> </xmi:XMI>
> <temporalContainer>
> <creationContainer>
> <contentUnits>
> </mediaCreations>
> </contentUnits>
> </s2:Project>
> <s2r:Folder>
> <essenceMasters>
> </essenceMasters>
> <essenceMasters>
> </essenceMasters>
> </s2r:Folder>
> </xmi:XMI>
Re: Problem with href [message #492737 is a reply to message #492731] Wed, 21 October 2009 14:47 Go to previous messageGo to next message
Thank u for reply Ed,
Containements are set at "true" on the ecore file
Ed Merks a écrit :
> Fabrice,
>> Hello,
>> <s2:DomainModel>
>> </s2:DomainModel>
>> <s2r:Folder>
>> </s2r:Folder>
>> <temporalContainer>
>> <creationContainer>
>> </s2:Project>
>> </xmi:XMI>
>> <temporalContainer>
>> <creationContainer>
>> <contentUnits>
>> </mediaCreations>
>> </contentUnits>
>> </s2:Project>
>> <s2r:Folder>
>> <essenceMasters>
>> </essenceMasters>
>> <essenceMasters>
>> </essenceMasters>
>> </s2r:Folder>
>> </xmi:XMI>
Re: Problem with href [message #492744 is a reply to message #492737] Wed, 21 October 2009 14:58 Go to previous messageGo to next message
Fabrice,
This you must be supporting proxy resolving containment... Who is
responsible for putting all these objects into the root of the
resource? If they're contained by a containment reference already, then
it's not necessary to put them directly in the root of the resource as well.
> Ed Merks a écrit :
>> Fabrice,
>> you want containment references instead.
>>> Hello,
>>> <s2:DomainModel>
>>> </s2:DomainModel>
>>> <s2r:Folder>
>>> </s2r:Folder>
>>> <temporalContainer>
>>> <creationContainer>
>>> </s2:Project>
>>> </xmi:XMI>
>>> <temporalContainer>
>>> <creationContainer>
>>> <contentUnits>
>>> </mediaCreations>
>>> </contentUnits>
>>> </s2:Project>
>>> <s2r:Folder>
>>> <essenceMasters>
>>> </essenceMasters>
>>> <essenceMasters>
>>> </essenceMasters>
>>> </s2r:Folder>
>>> </xmi:XMI>
Re: Problem with href [message #492749 is a reply to message #492744] Wed, 21 October 2009 15:15 Go to previous messageGo to next message
This problem only happens when I launch it programmatically. If I launch
the transformation by the eclipse pluggin, it's working well.
Re: Problem with href [message #492762 is a reply to message #492749] Wed, 21 October 2009 15:55 Go to previous messageGo to next message
Fabrice,
I don't really know what to say...
> launch the transformation by the eclipse pluggin, it's working well.
Re: Problem with href [message #493007 is a reply to message #492749] Thu, 22 October 2009 16:35 Go to previous messageGo to next message
Cedric Brun is currently offline Cedric BrunFriend
Did you registered all the required ecore models in the EPackage registry in
your Java code ? are you launching it as a pure java application or within
an Eclipse application ?
I'm forwarding to the m2m newsgroup as it's an ATL related issue.
http://cedric.brun.io news and articles on eclipse and eclipse modeling.
Re: Problem with href [message #493008 is a reply to message #492727] Thu, 22 October 2009 16:36 Go to previous message
in
Cédric
> Hello,
> <s2:DomainModel>
> </s2:DomainModel>
> <s2r:Folder>
> </s2r:Folder>
> <temporalContainer>
> <creationContainer>
> </s2:Project>
> </xmi:XMI>
> <temporalContainer>
> <creationContainer>
> <contentUnits>
> </mediaCreations>
> </contentUnits>
> </s2:Project>
> <s2r:Folder>
> <essenceMasters>
> </essenceMasters>
> <essenceMasters>
> </essenceMasters>
> </s2r:Folder>
> </xmi:XMI>
Previous Topic:Not enforcing order/multiplicity in an xsd:sequence
Next Topic:EObjectObservableList in EMF Databinding 1.1
Current Time: Tue Feb 20 12:18:05 GMT 2018
Powered by FUDForum. Page generated in 0.01979 seconds
