Home » Eclipse Projects » Buckminster » Resolution of svn:externals
Resolution of svn:externals [message #492421] Tue, 20 October 2009 08:07 Go to next message
Stefan Schuster is currently offline Stefan Schuster
I'm trying to set up a Buckminster based RCP product / update site build
and so far I've set up a simple cquery and rmap file from the examples
given in the Buckminster Book. It works fine up to one thing:
The Eclipse projects are stored in a svn repository which contains a
directory on which a `svn:externals` property is defined. When I resolve
& materialize the cquery, the references defined by the `svn:externals`
are not resolved & materialized (a righ-click > `Team` > `Update` will
of course fetch the missing resoureces...).
I'm using Eclipse 3.5.1 (Mac OS X & Linux 32 bit) for RCP / plug-in
developers along with Buckminster and Subversive from the Galileo update
site.
Thanks in advance for any help, idea, comment,...
Stefan
Re: Resolution of svn:externals [message #492437 is a reply to message #492421] Tue, 20 October 2009 08:38 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas Hallgren
Hi Stefan,
Buckminsters approach is to use the higher level API's provided by Subversive and Subclipse. We just do a check-out in
Java. Apparently, something is missing in the way we do this
Can you please file a bugzilla?
Thomas Hallgren
On 10/20/2009 02:07 PM, Stefan Schuster wrote:
> site.
> Best regards,
> Stefan
Re: Resolution of svn:externals [message #492488 is a reply to message #492437] Tue, 20 October 2009 11:21 Go to previous message
Hi Thomas, thanks for your reply!
I just filed bug #292775
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=292775)
Stefan
Thomas Hallgren schrieb:
> Hi Stefan,
> Subversive and Subclipse. We just do a check-out in Java. Apparently,
> Thomas Hallgren
Previous Topic:custom default start level or contig.ini
Next Topic:Materialization issue
Current Time: Sat May 25 20:58:16 EDT 2013
Powered by FUDForum. Page generated in 0.01573 seconds
