Home » Modeling » TMF (Xtext) » Xtext and the Antlr lexer hell
Xtext and the Antlr lexer hell [message #490999] Mon, 12 October 2009 18:04 Go to next message
Jens Kuenzer is currently offline Jens KuenzerFriend
I am trying to parse VHDL style character literal like 'x' and attribute ticks like x'HIGH. I think the generated antlr lexer can not handle this case where the ' is a literal delimiter and a token at the same time.
Here is my stripped down xtext:
grammar org.xtext.example.ApoTest
  import "http://www.eclipse.org/emf/2002/Ecore" as ecore
  generate apotest "http://www.xtext.org/example/apotest"
Model hidden(WS, COMMENT) : (name+=Name ';')*;
Name: (value=IDENTIFIER | value=CHARACTER_LITERAL) (APOSTROPHE extent+=Name | '.' extent+=Name)*;
terminal CHARACTER_LITERAL : APOSTROPHE (GRAPHIC_CHARACTER|APOSTROPHE APOSTROPHE) APOSTROPHE;
terminal APOSTROPHE : "'";
terminal COMMENT  : '--' !('\n'|'\r')* ('\r'? '\n')? ;
terminal WS : (' '|'\t'|'\r'|'\n')+ ;
terminal IDENTIFIER : ('a'..'z'|'A'..'Z') ( ( '_' )? (('a'..'z'|'A'..'Z') | ('0'..'9')) )*;
terminal GRAPHIC_CHARACTER : ('a'..'z'|'A'..'Z') | ('0'..'9') | '&' | '_' ;
And here is a testcase:
-- error with tick in this line:
bla ' error ;
-- working lines:
bla . noerror . good ;
ok . 'x' ;
'y' ;
Is it possible with xtext to support such a syntax ?
Re: Xtext and the Antlr lexer hell [message #491004 is a reply to message #490999] Mon, 12 October 2009 18:29 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Jens,
this is not possible with terminal rules but data type rules should work
fine.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Jens Kuenzer schrieb:
> bla ' error ;
> -- working lines:
> ok . 'x' ;
> 'y' ;
Re: Xtext and the Antlr lexer hell [message #491193 is a reply to message #491004] Tue, 13 October 2009 15:35 Go to previous messageGo to next message
Thanks for guidance. I got this working but wonder why it is so tricky:
Model hidden(SPACE, WS, COMMENT) : (name+=Name ';')*;
Name : isVar?=VAR? (value=IDENTIFIER | value=CHARACTER_LITERAL) (APOSTROPHE extent+=Name | DOT extent+=Name)*;
DOT hidden(SPACE, WS, COMMENT) : DOT_CHAR;
APOSTROPHE hidden(SPACE, WS, COMMENT) : APOSTROPHE_CHAR;
REHIDE hidden(SPACE, WS, COMMENT) : "^"?;
CHARACTER_LITERAL hidden() : APOSTROPHE_CHAR (GRAPHIC_CHARACTER | APOSTROPHE_CHAR APOSTROPHE_CHAR) APOSTROPHE_CHAR REHIDE;
IDENTIFIER hidden() : CHARACTER ( ( UNDERSCORE )? (CHARACTER | DIGIT) )* REHIDE;
GRAPHIC_CHARACTER : CHARACTER | DIGIT | DOT_CHAR | UNDERSCORE | SPACE | OTHER_CHAR;
terminal WS : ('\t'|'\r'|'\n')+ ;
terminal SPACE : ' ';
terminal VAR : ('V'|'v')('A'|'a')('R'|'r');
terminal UNDERSCORE : '_';
terminal APOSTROPHE_CHAR : "'";
terminal DOT_CHAR : '.';
terminal CHARACTER : ('a'..'z'|'A'..'Z');
terminal DIGIT : ('0'..'9');
terminal OTHER_CHAR : '/' | ':' | ';' | '<' | '=' | '>' | '|'
I still need to find a way how to handle input like:
 invar ;
Is there a way to define a empty REHIDE rule to circumvent the hidden bug ?
Re: Xtext and the Antlr lexer hell [message #491331 is a reply to message #491193] Wed, 14 October 2009 07:40 Go to previous messageGo to next message
Hi Jens,
it is a bug and local hidden tokens should not require this kind of
virtual rules. However, I'm afraid there is no other workaround.
Did you file a bugzilla?
Sebastian
> REHIDE;
> OTHER_CHAR;
> I still need to find a way how to handle input like: invar ; Is there a
Re: Xtext and the Antlr lexer hell [message #491395 is a reply to message #491331] Wed, 14 October 2009 12:42 Go to previous messageGo to next message
Ok the hidden() bug is in bugzilla.
But back to my never ending lexer problems:
I don't think data type rules can replace a good lexer.
Because now I have problems parsing these identifier:
varray ;
v2 ;
The first one is a "var" "ray" instead of a single identifier.
The second one just fails.
Here my current version of xtext:
VAR hidden(): V A R REHIDE;
CHARACTER : (A|B|C|D|E|F|G|H|I|J|K|L|M|N|O|P|Q|R|S|T|U|V|W|X|Y|Z);
terminal A : ('a'|'A');
terminal B : ('b'|'B');
terminal C : ('c'|'C');
terminal D : ('d'|'D');
terminal E : ('e'|'E');
terminal F : ('f'|'F');
terminal G : ('g'|'G');
terminal H : ('h'|'H');
terminal I : ('i'|'I');
terminal J : ('j'|'J');
terminal K : ('k'|'K');
terminal L : ('l'|'L');
terminal M : ('m'|'M');
terminal N : ('n'|'N');
terminal O : ('o'|'O');
terminal P : ('p'|'P');
terminal Q : ('q'|'Q');
terminal R : ('r'|'R');
terminal S : ('s'|'S');
terminal T : ('t'|'T');
terminal U : ('u'|'U');
terminal V : ('v'|'V');
terminal W : ('w'|'W');
terminal X : ('x'|'X');
terminal Y : ('y'|'Y');
terminal Z : ('z'|'Z');
Is there a way to use xtext with an better external lexer?
Or are there some options like greediness in xtext?
Re: Xtext and the Antlr lexer hell [message #491496 is a reply to message #491395] Wed, 14 October 2009 19:31 Go to previous messageGo to next message
Hi Jens,
there exist plenty of possiblities to tweak Xtext and the way it
instantiates models.
The 'varSomething' example may be solved with a custom IAstFactory
implementation, for example.
Maybe you should outline the actual use case so we could try to match it
to the Xtext concepts.
Sebastian
> varray ;
> v2 ;
> REHIDE;
> OTHER_CHAR;
Re: Xtext and the Antlr lexer hell [message #491637 is a reply to message #491496] Thu, 15 October 2009 10:38 Go to previous messageGo to next message
The use case is a vhdl compiler and my problem is rooted in the lexical analysis that is not able to handle a character literal like 'x' and a attribute marker like name'attribute.
The antlr lexical analysis detects a "name'attribute" as the identifier token "name" and a lexical error in an character literal " 'at " instead the tick token " ' " and an identifier "attribute". I am not sure whether this is a bug in Antlr or Xtext or my description of lexical tokens. I think datatype rules can not help because this introduces much more trouble detecting normal tokens.
Re: Xtext and the Antlr lexer hell [message #492684 is a reply to message #491637] Wed, 21 October 2009 11:52 Go to previous message
Hi, after reverting some of the changes I have now a solution:
IDENTIFIER : CHARACTER | LONG_IDENTIFIER;
terminal VAR : ("v"|"V")("a"|"A")("r"|"R");
terminal CHARACTER : ('a'..'z')|('A'..'Z');
terminal LONG_IDENTIFIER : CHARACTER ( ( UNDERSCORE )? (CHARACTER | DIGIT) )*;
The problem was the change of the IDENTIFIER rule to be a datatype rule.
Once reverted most of it back to a terminal rule it seems to work.
The trick here was the IDENTIFIER datatype rule because the CHARACTER rule matched better than the LONG_IDENTIFIER rule. Even a single character also matches a LONG_IDENTIFIER this is hidden by CHARACTER rule.
Maybe the xtext documentation of terminal tokens could clearify which terminal token matches first. Or another good idea would be a warning that parts of a terminal token is hidden by other tokens.
Previous Topic:Xpand imports - No Definition 'templates::Template::main for xpand2::Type' found!
Next Topic:Left factoring
Current Time: Fri May 25 07:20:57 GMT 2018
Powered by FUDForum. Page generated in 0.02206 seconds
