Home » Archived » M2M (model-to-model transformation) » [QVTO] Reflectively accessing a transformation
Re: [QVTO] Reflectively accessing a transformation [message #489841 is a reply to message #489641] |
Tue, 06 October 2009 08:11 |
Originally posted by: dvorak.radek.gmail.com
Hi Derek,
No API way yet. Anyway, even with this reflective access it's
not trivial to integrate QVT with another language, as for example
GMF Xpand did.
QVTO has still other issues to solve for pure transformation writers before
it can be extensible and open this way.
You have gotten to deep inside and too early ;)
Perhaps, what can be done is to open the AST model but I do not think its
helps too much.
/Radek
On Mon, 05 Oct 2009 14:54:21 +0200, Derek Palma <derek.palma@gmail.com>
wrote:
> I was wondering if there is a way to load a transformation/library, i.e.
> compile it and create the AST but not execute it, so I can look at the
> signatures transformation, helpers, queries. I am basically trying to
> achieve something analogous to Java reflection where I find the
> executable operations available in a class and make them accessible from
> another language and provide static type checking.
> Derek
Re: [QVTO] Reflectively accessing a transformation [message #490167 is a reply to message #489841] |
Wed, 07 October 2009 15:53 |
Derek Palma Messages: 141 Registered: July 2009 |
I just ran into an Ecore model for QVT Operational
(http://www.eclipse.org/QVT/1.0.0/Operational. Are instances of this created
when transformation/libraries are parsed. It looks like something I could
use. :)
Derek
"radek dvorak" <dvorak.radek@gmail.com> wrote in message
news:op.u1dc0ow412y5f2@kliste.local...
> Hi Derek,
> GMF Xpand did.
> before
> helps too much.
> /Radek
> wrote:
>> Derek
Re: [QVTO] Reflectively accessing a transformation [message #490561 is a reply to message #490167] |
Fri, 09 October 2009 07:54 |
Hi Derek,
Yes, the meta-model represents the AST, a result of QVTO modules
parsing/analysis.
At the moment, you can't make use of it as its not open as API, the
generated Java
package is 'internal'.
In case you want to experiment, there is a resource factory registered per
*.qvto file
extension. If loaded, you will receive Transformation/Library objects
in the resource contents.
/Radek
On Wed, 07 Oct 2009 17:53:56 +0200, Derek Palma <derek.palma@gmail.com>
wrote:
> created when transformation/libraries are parsed. It looks like
> something I could use. :)
> Derek
>> Hi Derek,
>> GMF Xpand did.
>> before
>> its
>> helps too much.
>> Regards,
>> /Radek
>> wrote:
>>> Hi,
>>> i.e. compile it and create the AST but not execute it, so I can look
>>> at the signatures transformation, helpers, queries. I am basically
>>> trying to achieve something analogous to Java reflection where I find
>>> the executable operations available in a class and make them
>>> accessible from another language and provide static type checking.
>>> Derek
Re: [QVTO] Reflectively accessing a transformation [message #490629 is a reply to message #490561] |
Fri, 09 October 2009 13:17 |
Do you happen to know the fully qualified class name of the Resource
implementation? I currently invoke all resource loading through my own code.
Derek
news:op.u1iv8lbp12y5f2@kliste.local...
> Hi Derek,
> parsing/analysis.
> generated Java
> *.qvto file
> /Radek
> wrote:
>> Derek
>>> Hi Derek,
>>> GMF Xpand did.
>>> before
>>> its
>>> helps too much.
>>> Regards,
>>> /Radek
>>> wrote:
>>>> Hi,
>>>> Derek
Re: [QVTO] Reflectively accessing a transformation [message #490737 is a reply to message #490561] |
Fri, 09 October 2009 22:26 |
Alex Mising name Messages: 51 Registered: August 2009 |
Member |
Eclipse User wrote on Fri, 09 October 2009 03:54 | Originally posted by: dvorak.radek.gmail.com
In case you want to experiment, there is a resource factory registered per *.qvto file extension. If loaded, you will receive Transformation/Library objects in the resource contents.
... which is also why .qvto files can be opened in any reflective model editor, such as Sample Ecore Model editor, MoDisco ModelEditor etc. (Right-click, Open With, Other ...) The best way to explore the QVT model, IMO ...
Alex
[Updated on: Fri, 09 October 2009 22:27] Report message to a moderator
Re: [QVTO] Reflectively accessing a transformation [message #490786 is a reply to message #490629] |
Sat, 10 October 2009 16:34 |
I found it.
"Derek Palma" <derek.palma@gmail.com> wrote in message
news:hand68$ir7$1@build.eclipse.org...
> code.
> Derek
>> Hi Derek,
>> parsing/analysis.
>> generated Java
>> per *.qvto file
>> Regards,
>> /Radek
>> wrote:
>>> Hi,
>>> Derek
>>>> Hi Derek,
>>>> GMF Xpand did.
>>>> before
>>>> its
>>>> helps too much.
>>>> Regards,
>>>> /Radek
>>>> wrote:
>>>>> Hi,
>>>>> Derek
Re: [QVTO] Reflectively accessing a transformation [message #490845 is a reply to message #490629] |
Sun, 11 October 2009 19:37 |
Hi Derek,
There is no need to access the resource implementation class, EMF ensures
that the right
implementation is used with qvto file name extension.
/Radek
On Fri, 09 Oct 2009 15:17:32 +0200, Derek Palma <derek.palma@gmail.com>
wrote:
> code.
> Derek
>> Hi Derek,
>> parsing/analysis.
>> generated Java
>> per *.qvto file
>> Regards,
>> /Radek
>> wrote:
>>> Hi,
>>> Derek
>>>> Hi Derek,
>>>> GMF Xpand did.
>>>> before
>>>> its
>>>> helps too much.
>>>> Regards,
>>>> /Radek
>>>> <derek.palma@gmail.com> wrote:
>>>>> Hi,
>>>>> find the executable operations available in a class and make them
>>>>> Derek
Current Time: Thu Apr 25 11:33:20 GMT 2024
Powered by FUDForum. Page generated in 0.03005 seconds
