Re: Newbie Running TPTP with WTP - Could not launch in profiling mode [message #489725 is a reply to message #488820] |
Mon, 05 October 2009 16:47  |
Eugene Chan Messages: 287 Registered: July 2009 |
Hi Tom,
The All-in-one does not included the WTP integration, you will have to
download the TPTP All plugin Runtime, plus WTP, GEF and DTP under the TPTP
plugins section of the download page. Alternative, you can use the software
update wizard to install the integration >
http://www.eclipse.org/tptp/home/downloads/updateManager.php
"Tom Hickerson" <thickerson@akazaresearch.com> wrote in message
news:h9virg$eec$1@build.eclipse.org...
> Hi all,
> I am running TPTP 4.6.1 (all-in-one download with Galieo) with WTP. Per
> the instructions under the Quick Start video, if I select the Dynamic Web
> Project, then select Profile As > Run on Server, I should be able to
> launch the profiler and select reports. Instead, I get the following
> message:
> Could not launch in profiling mode because no profilers are configured.
> I go under Profile Configurations and try to Attach an Agent, but there
> are no Agents available.
> What should I do to configure a profiler?
> Thanks in advance, Tom H.
FUDForum. Page generated in 0.03328 seconds
