Home » Eclipse Projects » DTP » Queries returning results containing MySQL DATE columns return no results
Queries returning results containing MySQL DATE columns return no results [message #488366] Mon, 28 September 2009 12:49 Go to next message
No real name is currently offline No real nameFriend
I have a table called candidates with the following DDL
CREATE TABLE candidates (
ID INTEGER UNSIGNED NOT NULL,
Candidate_Type_ID INTEGER UNSIGNED,
Current_Employer VARCHAR(45),
Current_employer_hide BIT,
current_employer_start DATE,
years_with_cur_employer INTEGER UNSIGNED,
profession_position_id INTEGER UNSIGNED,
DoB DATE DEFAULT '0000-00-00' NOT NULL,
Qualifications VARCHAR(45),
Memberships TEXT,
Awards TEXT,
Languages TEXT,
User_ID INTEGER UNSIGNED DEFAULT 0 NOT NULL,
reward_rate INTEGER UNSIGNED DEFAULT 50 NOT NULL,
personalstatement TEXT,
profession_id INTEGER UNSIGNED NOT NULL,
universities TEXT NOT NULL,
industry_id INTEGER UNSIGNED NOT NULL,
industry_text VARCHAR(255),
status_id INTEGER UNSIGNED DEFAULT 1 NOT NULL,
profession_position VARCHAR(255),
modified DATETIME
) ENGINE=InnoDB;
The statement
SELECT candidates.industry_text FROM candidates
will return 24 records.
The statement
SELECT candidates.industry_text, candidates.current_employer.start_date FROM candidates
fails.
Any statement that selects a DATE column fails. Statements selecting DATETIME columns succeed.
Both queries succeed and return results using other tools.
Re: Queries returning results containing MySQL DATE columns return no results [message #488918 is a reply to message #488366] Wed, 30 September 2009 17:15 Go to previous message
Brian Fitzpatrick is currently offline Brian FitzpatrickFriend
Please create a bugzilla for this in Datatools and we can look into it.
--Fitz
> Memberships TEXT,
> Awards TEXT,
> Languages TEXT,
> modified DATETIME
> ) ENGINE=InnoDB;
> The statement
> The statement
> FROM candidates
> fails.
Previous Topic:unable to deactivate DTP via capabilities in gallileo
Next Topic:Queries returning results containing MySQL DATE columns return no results
Current Time: Mon Jan 22 19:54:21 GMT 2018
Powered by FUDForum. Page generated in 0.01603 seconds
