Home » Eclipse Projects » SWTBot » pressShortcut() problem with Keystrokes.MOD2(event )
pressShortcut() problem with Keystrokes.MOD2 [message #487776] Thu, 24 September 2009 08:00 Go to next message
Andrii  is currently offline Andrii
i have the problem with sending shortcuts to widgets.
Then i use
keyboard().pressShortcut(Keystrokes.MOD3, Keystrokes.MOD1, Keystrokes.DOWN);
to press shortcut, my widget receive the events
Key pressed: KeyEvent{McGrid {} time=624807531 data=null character='\0' keyCode=65536 stateMask=0 doit=true}
Key pressed: KeyEvent{McGrid {} time=624807531 data=null character='\0' keyCode=262144 stateMask=65536 doit=true}
Key pressed: KeyEvent{McGrid {} time=624807531 data=null character='\0' keyCode=16777218 stateMask=327680 doit=true}
release keys here
and this is correct, but when i use
Keystrokes.MOD2
in my shortcuts, calling
keyboard().pressShortcut(Keystrokes.MOD2, Keystrokes.MOD1, Keystrokes.DOWN);
events are
Key pressed: KeyEvent{McGrid {} time=625248750 data=null character='\0' keyCode=131072 stateMask=0 doit=true}
Key pressed: KeyEvent{McGrid {} time=625248750 data=null character='\0' keyCode=262144 stateMask=131072 doit=true}
Key pressed: KeyEvent{McGrid {} time=625248750 data=null character='\0' keyCode=16777218 stateMask=262144 doit=true}
Key pressed: KeyEvent{McGrid {} time=625248750 data=null character='\0' keyCode=131072 stateMask=262144 doit=true}
release keys here
What i am doing wrong? How i can press CTRL+SHIFT+ARROW_DOWN shortcut ?
Re: pressShortcut() problem with Keystrokes.MOD2 [message #487850 is a reply to message #487776] Thu, 24 September 2009 10:50 Go to previous messageGo to next message
I try to use org.eclipse.swtbot.swt.finder.keyboard.SWTKeyboardStrategy and org.eclipse.swtbot.swt.finder.keyboard.MockKeyboardStrategy
with no result, parsing Keystrokes.SHIFT seems to be incorrect
But I can handle this by sending event directly using
AbstractSWTBot.notify(final int eventType, final Event createEvent, final Widget widget)
so this works for me,
notifyKeyboardEvent(SWT.MOD1|SWT.MOD2, '\0', SWT.ARROW_DOWN);
where
protected Event keyEvent(final int modificationKey, final char c, final int keyCode) {
    final Event keyEvent = createEvent();
    keyEvent.stateMask = modificationKey;
    keyEvent.character = c;
    keyEvent.keyCode = keyCode;
    return keyEvent;
public void notifyKeyboardEvent(final int modificationKey, final char c, final int keyCode) {
notify(SWT.KeyDown, keyEvent(modificationKey, c, keyCode));
but as i see MockKeyboardStrategy do exaclty the same but unfortunatelly send strange event sequence.....
Re: pressShortcut() problem with Keystrokes.MOD2 [message #487960 is a reply to message #487850] Fri, 25 September 2009 01:03 Go to previous messageGo to next message
Ketan Padegaonkar is currently offline Ketan Padegaonkar
Hi Andrii,
I just looked at the keyboard constants defined in the Keystrokes class,
and the corresponding constants in the swt class.
MOD1 and MOD2 keys are defined as CTRL and SHIFT respectively, so I'm
unsure why that does not work -- Please file a bug with a link to this
conversation and I'll take a look at it.
Regarding the mock strategy -- this is to be used only as a last resort.
This strategy has its own quirks and does not work when there are verify
listeners hooked in etc. Use sparingly with caution.
Ketan
http://studios.thoughtworks.com/twist | http://twitter.com/ketanpkr
> where
> int keyCode) {
> return keyEvent;
Re: pressShortcut() problem with Keystrokes.MOD2 [message #488033 is a reply to message #487960] Fri, 25 September 2009 08:15 Go to previous message
Hi Ketan, thanks for reply
https://bugs.eclipse.org/bugs/show_bug.cgi?id=290527
Previous Topic:How to test RCP product?
Next Topic:Returning to a base state after an error...?
Current Time: Wed May 22 18:41:18 EDT 2013
Powered by FUDForum. Page generated in 0.01512 seconds
