Home » Language IDEs » C / C++ IDE (CDT) » Steps "randomly" in debug mode...(Would be nice if it stepped line by line instead)
Steps "randomly" in debug mode... [message #487439] Wed, 23 September 2009 09:37 Go to next message
Jonas Arvidsson is currently offline Jonas ArvidssonFriend
Ubuntu 9.04, Ecplise Build ID: 20090619-0625
When I use step (F5 and F6) while debugging a project in Eclipse, it doesn't step line by line. Instead it jumps backwards and forwards, totally by it's own decisions. I suppose it has to do with how the code actually are compiled/run, but it's still frustrating. Is there any way to avoid this?
Re: Steps "randomly" in debug mode... [message #487467 is a reply to message #487439] Wed, 23 September 2009 11:15 Go to previous messageGo to next message
Derek is currently offline DerekFriend
Member
> to avoid this?
You most probably have a high level of optimization on your debug build.
Suggest you use -O0 which will stop the compiler optimising your code.
Derek
Re: Steps "randomly" in debug mode... [message #487483 is a reply to message #487439] Wed, 23 September 2009 12:00 Go to previous messageGo to next message
I started with Eclipse only a week ago, have been using IAR Embeddedb Workbench mostly before.
Where to I add this optimization turn off line? And just to be sure, it is first a "O" like in "Orion" and then a zero?
Re: Steps "randomly" in debug mode... [message #487488 is a reply to message #487483] Wed, 23 September 2009 12:15 Go to previous messageGo to next message
Member
Assuming you are letting Eclipse manage your projects,
Project->Properties
C/C++/Settings
'Compiler'
Optimization (here you will find a drop down)
If you are using Makefiles, you need to add -O0 to the compiler command
line.
Yes, 'O' as in Optimization and '0' as in zero. You can also have 1, 2,
3, s, t for optimzation levels.
Derek
Re: Steps "randomly" in debug mode... [message #487678 is a reply to message #487439] Thu, 24 September 2009 06:59 Go to previous messageGo to next message
Seems like we have different versions of Eclipse? Because I can't find such setting
http://www.flickr.com/photos/42861164@N06/3950114432/
Edit: Can't even get the screen shot that show my settings to show in this message, please visit the link!
[Updated on: Thu, 24 September 2009 07:00]
Report message to a moderator
Re: Steps "randomly" in debug mode... [message #487817 is a reply to message #487678] Thu, 24 September 2009 13:55 Go to previous messageGo to next message
Member
> such setting
Nope. Thats in every version (barring some slight variation in names).
If you don't see it, that implies you have a "Makefile" project, meaning
you wrote and are supplying the makefile. In which case you need to add
the -O0 switch to the compiler.
Derek
Re: Steps "randomly" in debug mode... [message #488410 is a reply to message #487439] Mon, 28 September 2009 14:57 Go to previous messageGo to next message
I see... Replaced -O2 with -O0, but the debugger still jumps which makes it pretty difficult to debug properly.
Re: Steps "randomly" in debug mode... [message #488415 is a reply to message #488410] Mon, 28 September 2009 15:10 Go to previous messageGo to next message
Member
I suspect that you are not debugging with the change. Delete all the
executables and objects and rebuild.
Derek
Re: Steps "randomly" in debug mode... [message #488595 is a reply to message #488415] Tue, 29 September 2009 11:56 Go to previous message
Hm, tried that as well now, but it still jumps a little bit strange, like in this piece of code:
dataToSend[dataLength++] = GetReturnValue(element.ReturnValue);
dataToSend[dataLength++] = 'S';
dataToSend[dataLength++] = 'T';
I have a breakpoint on the first line. When I press F6 i jumps to the next line. Then I press F5, and are now on the third line. But when I press F5 again, it jumps back to the first line, and does not proceed further on until I press F5 again.
Previous Topic:Cannot update/install on clean Linux 64 installation
Next Topic:Change, undo changes, still the program behaves different than before?!?
Current Time: Wed Jan 24 06:18:28 GMT 2018
Powered by FUDForum. Page generated in 0.02022 seconds
