Re: b3 - resolver model [message #486588] |
Fri, 18 September 2009 10:54 |
Henrik Lindberg Messages: 2509 Registered: July 2009 |
Copied from an email:
>> On Sep 17, 2009, at 10:12 PM, Thomas Hallgren wrote:
>> On 09/17/2009 01:57 AM, Henrik Lindberg wrote:
>> - In Buckminster, there are flags for mutable, source on readers, and
>> regexp pattern matching on component names to control the routing. In
>> b3, this is instead moved to a regular OSGi type filter. The OSGi
>> filter does not have the pattern matching capabilities of a regexp, but
>> wildcard at the end, or middle seems to be what everyone is using, so
>> this should be fine.
> I've been thinking some more about this. Perhaps the OSGi filter is too
> limited in it's pattern matching capabilities after all. Or, if not
> limited, then at least somewhat obscure. I think people are used to two
> types of pattern matching. The regular shell type matching (similar to
> what Ant uses) and the regexp.
Agree.
>> Experience shows that even very experienced developers tend to make
>> mistakes with regexp. Forgetting to escape the dot for instance, is very
>> common. The most pragmatic approach to pattern matching is probably to
>> do use the same approach as Ant. Developers, especially in the build
>> domain, are very familiar with that.
> I can see us do this in two ways.
> 1. We change the model so that the pattern matching is separate from
> other types of filters.
> 2. Since we have our own OSGi implementation, we can add pattern
> matching operator.
> I would opt for #1 since OSGi is a standard. It doesn't feel kosher to
> add our own operators to it.
Agree, here as well. I will reintroduce my earlier design that allows a
composition of different types of filters. (For newcomers who do not
know what I am talking about - there will be models posted soon).
>> - I modeled that the IResolver takes more that one Filter. I don't know
>> if that is a good idea, but it would allow easy composition of shared
>> filters for common namespaces; i.e. just add a filter for (or
>> (b3.namspace=osgi.bundle)(b3.namespace=eclipse.feature)) instead of
>> having to first compose a string with all constraints. Idea being to
>> reduce number of instances. For convenience sake, this can just as
>> easily be done in a filter factory (a useful implementation is in
>> Buckminster).
> My preference would be one single filter. Ease of composition is
> something that needs to be addressed by tooling one way or another.
Yes, agree - especially since the earlier design allowed composition of
filters - no need to have an additional way to compose them.
- henrik
Re: b3 - resolver model [message #486625 is a reply to message #486588] |
Fri, 18 September 2009 13:10 |
Yikes, if you are reading this using the Eclipse forum software, the attachment shows up as encoded text.... This post is an experiment to see what happens when adding attachments in the forum client (will news client get it ok?).
Hm, attachments made in the forum just disappears when posting.
[Updated on: Fri, 18 September 2009 13:13] Report message to a moderator
Re: b3 - resolver model [message #486797 is a reply to message #486640] |
Sat, 19 September 2009 06:22 |
I have no problem reading the attachment with the Thunderbird news reader. Looks good to me.
- thomas
> Well, it seems like the forum client screws this up - an attachment
> added in the forum client just disappears.
> Also noted that if edits are made in the forum, those edit are not sent
> out as news. (The post I am commenting on here was edited as a test).
> Now you know...
> - henrik
Re: b3 - resolver model [message #577630 is a reply to message #486640] |
- thomas
> Now you know...
> - henrik
FUDForum. Page generated in 0.03654 seconds
