Home » Eclipse Projects » Rich Client Platform (RCP) » How to disable built-in shortcut keys provided by eclipse
How to disable built-in shortcut keys provided by eclipse [message #486350] Thu, 17 September 2009 11:37 Go to next message
Neha is currently offline NehaFriend
Member
In my application created i want to disable some of the built in shortcut
keys provided by eclipse rcp. For instance shortcut key "Ctrl + F8" for next
perspective.I dont want anythng to happen on this key.
Is there any way to do so? Please let me know
Thanks in advance!
Neha
Re: How to disable built-in shortcut keys provided by eclipse [message #486367 is a reply to message #486350] Thu, 17 September 2009 12:57 Go to previous messageGo to next message
Prakash G.R. is currently offline Prakash G.R.Friend
Create you own scheme and add the keybindings you need to it. In the
customization ini file add this line:
org.eclipse.ui/KEY_CONFIGURATION_ID = <your scheme id>
- Prakash
Platform UI Team, IBM
http://blog.eclipse-tips.com
Re: How to disable built-in shortcut keys provided by eclipse [message #486434 is a reply to message #486367] Thu, 17 September 2009 15:43 Go to previous messageGo to next message
Lars Vogel Unavailable until 15 August 2016 is currently offline Lars Vogel Unavailable until 15 August 2016Friend
Neha,
additional details for defining your scheme can be found here:
http://www.vogella.de/articles/EclipseCommands/article.html# keybinding
Just ignore the command part in the description.
Best regards, Lars
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
http://www.twitter.com/vogella - vogella on Twitter
Prakash G.R. wrote:
>> shortcut keys provided by eclipse rcp. For instance shortcut key "Ctrl
>> + F8" for next perspective.I dont want anythng to happen on this key.
> - Prakash
Re: How to disable built-in shortcut keys provided by eclipse [message #486534 is a reply to message #486434] Fri, 18 September 2009 05:32 Go to previous messageGo to next message
Member
Actually adding my own scheme works . I needed to overide the shortcut
"cntrl + N". But all other shortcuts are disabled.
Any way to avoid that
Thanks in advance !
Neha.
"Lars Vogel" <Lars.Vogel@gmail.com> wrote in message
news:h8tleb$hq3$1@build.eclipse.org...
> Neha,
> Best regards, Lars
> Prakash G.R. wrote:
>>> shortcut keys provided by eclipse rcp. For instance shortcut key "Ctrl +
>> - Prakash
Re: How to disable built-in shortcut keys provided by eclipse [message #487052 is a reply to message #486534] Mon, 21 September 2009 16:48 Go to previous message
Paul Webster is currently offline Paul WebsterFriend
You can make your scheme a child of the default scheme (the way the emacs scheme currently works). Then you can delete offending keys in your scheme (but whatever you don't touch will show through).
PW
Previous Topic:CocoaUIEnhancer
Next Topic:Model View Presenter: how to use with a command
Current Time: Tue Jan 16 08:00:09 GMT 2018
Powered by FUDForum. Page generated in 0.02250 seconds
