Home » Eclipse Projects » XML Schema Definition (XSD) » key/keyref does not validate with recursion?
key/keyref does not validate with recursion? [message #485136] Thu, 10 September 2009 15:22 Go to next message
Toan is currently offline ToanFriend
Member
Hi everyone,
Is it true that key/keyref does not validate with recursion? I have this
question because that when I validate the following xml file, the
validation of an element defined with recursion doesn't work. Following is
xml and the corresponding xsd file. Thanks in advance!
Toan.
xsd file :
<?xml version="1.0" encoding="ISO-8859-1"?>
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<xsd:element name="CompositeType" type="CompositeType" />
<xsd:element name="Model" type="Model">
<!-- CompositeTypeKey/KeyRef -->
<xsd:key name="CompositeTypeKey">
<xsd:selector
xpath=".//CompositeType" />
<xsd:field xpath="./typeName" />
</xsd:key>
<xsd:keyref name="CompositeTypeRef" refer="CompositeTypeKey">
<xsd:selector
xpath=".//Attribute/CompositeTypeReference" />
<xsd:field xpath="." />
</xsd:keyref>
</xsd:element>
<xsd:complexType name="CompositeType">
<xsd:sequence>
<xsd:element minOccurs="0" name="typeName"
type="xsd:string" />
<xsd:element maxOccurs="unbounded" minOccurs="0"
name="Attribute" type="Attribute" />
</xsd:sequence>
</xsd:complexType>
<xsd:complexType name="Attribute">
<xsd:sequence>
<xsd:element minOccurs="0" name="name" type="xsd:string" />
<xsd:choice minOccurs="1">
<xsd:element minOccurs="1" maxOccurs="1"
name="CompositeTypeReference" type="xsd:string" />
</xsd:choice>
</xsd:sequence>
</xsd:complexType>
<xsd:complexType name="Model">
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
xml file :
<?xml version="1.0" encoding="ISO-8859-1" standalone="no"?>
<Model xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="test.xsd" >
<CompositeType>
<typeName>Bozo</typeName>
</CompositeType>
<CompositeType>
<typeName>MyData</typeName>
<Attribute>
<name>b</name>
<CompositeTypeReference>Bozo</CompositeTypeReference>
</Attribute>
<Attribute>
<name>d</name>
<CompositeType>
<typeName>CustomData</typeName>
</CompositeType>
</Attribute>
<Attribute>
<name>n</name>
<CompositeType>
<typeName>NewData</typeName>
<Attribute>
<name>m</name>
<CompositeTypeReference>My</CompositeTypeReference>
</Attribute>
<Attribute>
<name>c</name>
<CompositeTypeReference>Custom</CompositeTypeReference>
</Attribute>
</CompositeType>
</Attribute>
</CompositeType>
</Model>
Notice that when validate if the validation of recursion works, there will
be two errors at :
because the right references are :
<CompositeTypeReference>MyData</CompositeTypeReference>
<CompositeTypeReference>CustomData</CompositeTypeReference >
Re: key/keyref does not validate with recursion? [message #485151 is a reply to message #485136] Thu, 10 September 2009 15:37 Go to previous messageGo to next message
Toan,
It's probably better to ask this question on a Xerces forum because the
XSD model doesn't provide support validation of XML instances only
support for validating XSD instances themselves.
Toan wrote:
> Hi everyone,
> this question because that when I validate the following xml file, the
> Following is xml and the corresponding xsd file. Thanks in advance!
> Toan.
> xsd file :
> <xsd:selector
> </xsd:key>
> <xsd:selector
> </xsd:keyref>
> </xsd:element>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:choice>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> xml file :
> <CompositeType>
> </CompositeType>
> <CompositeType>
> <Attribute>
> <name>b</name>
> </Attribute>
> <Attribute>
> <name>d</name>
> <CompositeType>
> </CompositeType>
> </Attribute>
> <Attribute>
> <name>n</name>
> <CompositeType>
> <Attribute>
> <name>m</name>
> </Attribute>
> <Attribute>
> <name>c</name>
> </Attribute>
> </CompositeType>
> </Attribute>
> </CompositeType>
> </Model>
> will be two errors at :
Re: key/keyref does not validate with recursion? [message #485282 is a reply to message #485151] Fri, 11 September 2009 07:55 Go to previous messageGo to next message
Member
Ed,
I'm sorry because I don't know the link of Xerces forum in order to post
this question. Can you please inform it to me? Thanks.
Toan.
Ed Merks wrote:
> Toan,
> Toan wrote:
>> Hi everyone,
>> Toan.
>> xsd file :
>> <xsd:selector
>> </xsd:key>
>> <xsd:selector
>> </xsd:keyref>
>> </xsd:element>
>> <xsd:sequence>
>> </xsd:sequence>
>> </xsd:complexType>
>> <xsd:sequence>
>> </xsd:choice>
>> </xsd:sequence>
>> </xsd:complexType>
>> <xsd:sequence>
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:schema>
>> xml file :
>> <CompositeType>
>> </CompositeType>
>> <CompositeType>
>> <Attribute>
>> <name>b</name>
>> </Attribute>
>> <Attribute>
>> <name>d</name>
>> <CompositeType>
>> </CompositeType>
>> </Attribute>
>> <Attribute>
>> <name>n</name>
>> <CompositeType>
>> <Attribute>
>> <name>m</name>
>> </Attribute>
>> <Attribute>
>> <name>c</name>
>> </Attribute>
>> </CompositeType>
>> </Attribute>
>> </CompositeType>
>> </Model>
Re: key/keyref does not validate with recursion? [message #485361 is a reply to message #485282] Fri, 11 September 2009 13:45 Go to previous messageGo to next message
Toan,
I don't know either, but I find Google searches quite effective. No
doubt it's at Apache somewhere...
Toan wrote:
> Ed,
> post this question. Can you please inform it to me? Thanks.
> Toan.
> Ed Merks wrote:
>> Toan,
>> the XSD model doesn't provide support validation of XML instances
>> only support for validating XSD instances themselves.
>> Toan wrote:
>>> Hi everyone,
>>> the validation of an element defined with recursion doesn't work.
>>> Toan.
>>> xsd file :
>>> <xsd:selector
>>> </xsd:key>
>>> <xsd:selector
>>> </xsd:keyref>
>>> </xsd:element>
>>> <xsd:sequence>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> <xsd:sequence>
>>> </xsd:choice>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> <xsd:sequence>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> </xsd:schema>
>>> xml file :
>>> <CompositeType>
>>> </CompositeType>
>>> <CompositeType>
>>> <Attribute>
>>> <name>b</name>
>>> </Attribute>
>>> <Attribute>
>>> <name>d</name>
>>> <CompositeType>
>>> </CompositeType>
>>> </Attribute>
>>> <Attribute>
>>> <name>n</name>
>>> <CompositeType>
>>> <Attribute>
>>> <name>m</name>
>>> </Attribute>
>>> <Attribute>
>>> <name>c</name>
>>> </Attribute>
>>> </CompositeType>
>>> </Attribute>
>>> </CompositeType>
>>> </Model>
>>> there will be two errors at :
Re: key/keyref does not validate with recursion? [message #485376 is a reply to message #485361] Fri, 11 September 2009 14:15 Go to previous message
Member
Hi Ed,
Ok, I'll search, thanks anyway.
Toan.
Ed Merks wrote:
> Toan,
> Toan wrote:
>> Ed,
>> Toan.
>> Ed Merks wrote:
>>> Toan,
>>> Toan wrote:
>>>> Hi everyone,
>>>> Toan.
>>>> xsd file :
>>>> <xsd:selector
>>>> </xsd:key>
>>>> <xsd:selector
>>>> </xsd:keyref>
>>>> </xsd:element>
>>>> <xsd:sequence>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> <xsd:sequence>
>>>> </xsd:choice>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> <xsd:sequence>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> </xsd:schema>
>>>> xml file :
>>>> <CompositeType>
>>>> </CompositeType>
>>>> <CompositeType>
>>>> <Attribute>
>>>> <name>b</name>
>>>> </Attribute>
>>>> <Attribute>
>>>> <name>d</name>
>>>> <CompositeType>
>>>> </CompositeType>
>>>> </Attribute>
>>>> <Attribute>
>>>> <name>n</name>
>>>> <CompositeType>
>>>> <Attribute>
>>>> <name>m</name>
>>>> </Attribute>
>>>> <Attribute>
>>>> <name>c</name>
>>>> </Attribute>
>>>> </CompositeType>
>>>> </Attribute>
>>>> </CompositeType>
>>>> </Model>
Re: key/keyref does not validate with recursion? [message #604359 is a reply to message #485136] Thu, 10 September 2009 15:37 Go to previous message
Toan,
Toan wrote:
> Hi everyone,
> Toan.
> xsd file :
> <xsd:selector
> </xsd:key>
> <xsd:selector
> </xsd:keyref>
> </xsd:element>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:choice>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> xml file :
> <CompositeType>
> </CompositeType>
> <CompositeType>
> <Attribute>
> <name>b</name>
> </Attribute>
> <Attribute>
> <name>d</name>
> <CompositeType>
> </CompositeType>
> </Attribute>
> <Attribute>
> <name>n</name>
> <CompositeType>
> <Attribute>
> <name>m</name>
> </Attribute>
> <Attribute>
> <name>c</name>
> </Attribute>
> </CompositeType>
> </Attribute>
> </CompositeType>
> </Model>
Re: key/keyref does not validate with recursion? [message #604360 is a reply to message #485151] Fri, 11 September 2009 07:55 Go to previous message
Member
Ed,
Toan.
Ed Merks wrote:
> Toan,
> Toan wrote:
>> Hi everyone,
>> Toan.
>> xsd file :
>> <xsd:selector
>> </xsd:key>
>> <xsd:selector
>> </xsd:keyref>
>> </xsd:element>
>> <xsd:sequence>
>> </xsd:sequence>
>> </xsd:complexType>
>> <xsd:sequence>
>> </xsd:choice>
>> </xsd:sequence>
>> </xsd:complexType>
>> <xsd:sequence>
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:schema>
>> xml file :
>> <CompositeType>
>> </CompositeType>
>> <CompositeType>
>> <Attribute>
>> <name>b</name>
>> </Attribute>
>> <Attribute>
>> <name>d</name>
>> <CompositeType>
>> </CompositeType>
>> </Attribute>
>> <Attribute>
>> <name>n</name>
>> <CompositeType>
>> <Attribute>
>> <name>m</name>
>> </Attribute>
>> <Attribute>
>> <name>c</name>
>> </Attribute>
>> </CompositeType>
>> </Attribute>
>> </CompositeType>
>> </Model>
Re: key/keyref does not validate with recursion? [message #604364 is a reply to message #485282] Fri, 11 September 2009 13:45 Go to previous message
Toan,
Toan wrote:
> Ed,
> Toan.
> Ed Merks wrote:
>> Toan,
>> Toan wrote:
>>> Hi everyone,
>>> Toan.
>>> xsd file :
>>> <xsd:selector
>>> </xsd:key>
>>> <xsd:selector
>>> </xsd:keyref>
>>> </xsd:element>
>>> <xsd:sequence>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> <xsd:sequence>
>>> </xsd:choice>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> <xsd:sequence>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> </xsd:schema>
>>> xml file :
>>> <CompositeType>
>>> </CompositeType>
>>> <CompositeType>
>>> <Attribute>
>>> <name>b</name>
>>> </Attribute>
>>> <Attribute>
>>> <name>d</name>
>>> <CompositeType>
>>> </CompositeType>
>>> </Attribute>
>>> <Attribute>
>>> <name>n</name>
>>> <CompositeType>
>>> <Attribute>
>>> <name>m</name>
>>> </Attribute>
>>> <Attribute>
>>> <name>c</name>
>>> </Attribute>
>>> </CompositeType>
>>> </Attribute>
>>> </CompositeType>
>>> </Model>
Re: key/keyref does not validate with recursion? [message #604366 is a reply to message #485361] Fri, 11 September 2009 14:15 Go to previous message
Member
Hi Ed,
Toan.
Ed Merks wrote:
> Toan,
> Toan wrote:
>> Ed,
>> Toan.
>> Ed Merks wrote:
>>> Toan,
>>> Toan wrote:
>>>> Hi everyone,
>>>> Toan.
>>>> xsd file :
>>>> <xsd:selector
>>>> </xsd:key>
>>>> <xsd:selector
>>>> </xsd:keyref>
>>>> </xsd:element>
>>>> <xsd:sequence>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> <xsd:sequence>
>>>> </xsd:choice>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> <xsd:sequence>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> </xsd:schema>
>>>> xml file :
>>>> <CompositeType>
>>>> </CompositeType>
>>>> <CompositeType>
>>>> <Attribute>
>>>> <name>b</name>
>>>> </Attribute>
>>>> <Attribute>
>>>> <name>d</name>
>>>> <CompositeType>
>>>> </CompositeType>
>>>> </Attribute>
>>>> <Attribute>
>>>> <name>n</name>
>>>> <CompositeType>
>>>> <Attribute>
>>>> <name>m</name>
>>>> </Attribute>
>>>> <Attribute>
>>>> <name>c</name>
>>>> </Attribute>
>>>> </CompositeType>
>>>> </Attribute>
>>>> </CompositeType>
>>>> </Model>
Previous Topic:key/keyref does not validate with recursion?
Next Topic:Unable to load mixed content when loading an ecore model derived from an xml schema
Current Time: Sat May 26 04:38:39 GMT 2018
Powered by FUDForum. Page generated in 0.02245 seconds
