Re: Mirror local archive site from command line? [message #485027 is a reply to message #485014] |
Thu, 10 September 2009 10:16   |
Tom Dalton Messages: 12 Registered: September 2009 |
Junior Member |
Ok, so I tried to use the p2.director instead of standaloneUpdate to do the install, and while I get a little bit further, it still runs into the same problem:
java -jar plugins/org.eclipse.equinox.launcher_*.jar
-application org.eclipse.equinox.p2.director
-repository /path/to/my/extracted/emf/site.xml
-installIU org.eclipse.emf.feature.group
Starts off ok with it saying it's installing the first feature, but then spams a mass of file not found errors that again seem to be because it's only looking for .jar files and not the actual .jar.pack.gz
I tried modifying the extracted site.xml to change the references in that from .jar.to .jar.pack.gz but then when i run the command line about it says it cannot find the features as all!
Help, this is driving me mad - is it a bug?!
[Updated on: Thu, 10 September 2009 10:20] Report message to a moderator
FUDForum. Page generated in 0.01457 seconds
