Home » Newcomers » Newcomers » Can't start eclipse
Can't start eclipse [message #483782] Wed, 02 September 2009 23:17 Go to next message
Originally posted by: orfeo61.gmail.com
Hi all,
I'm having a problem with starting eclipse.
It used to run well but from some point it fails to start leaving the
following logs.
Could anyone shed some light on this?
Sangmin
eclipse.buildId=I20090611-1540
java.version=1.6.0_11
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os linux -ws gtk -arch x86 -product
!ENTRY org.eclipse.osgi 4 0 2009-09-02 17:29:12.743
!MESSAGE Startup error
!STACK 1
java.lang.IllegalArgumentException: invalid qualifier: 6+desktop7+24
at org.osgi.framework.Version.validate(Version.java:188)
at org.osgi.framework.Version.<init>(Version.java:92)
org.eclipse.osgi.framework.internal.core.Framework.initializ eProperties(Framework.java:361)
org.eclipse.osgi.framework.internal.core.Framework.initializ e(Framework.java:196)
org.eclipse.osgi.framework.internal.core.Framework.<init>(Framework.java:157)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:286)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:175)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
Re: Can't start eclipse [message #483868 is a reply to message #483782] Thu, 03 September 2009 12:41 Go to previous messageGo to next message
eager2know  is currently offline eager2know Friend
I am having the exact same problelm
Re: Can't start eclipse [message #483936 is a reply to message #483782] Thu, 03 September 2009 16:20 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric RizzoFriend
On 9/2/09 7:17 PM, Sangmin wrote:
> Hi all,
> following logs.
I don't know this particular error, but many problems running Eclipse on
Linux are the result of gcj. Install the Sun JDK and then make sure
Eclipse is using it by following the instructions here:
http://wiki.eclipse.org/Eclipse.ini
Hope this helps,
Eric
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
Re: Can't start eclipse [message #553741 is a reply to message #483868] Wed, 18 August 2010 16:23 Go to previous message
topcat  is currently offline topcat Friend
I don't know if this is still relevant. But, this might solve your problem..
https://bugs.eclipse.org/bugs/show_bug.cgi?id=305452
Its because of a '+' in the version name. A workaround is to set org.osgi.framework.os.version in the config file.
Previous Topic:Eclipse crashes on file system access
Next Topic:creating jar for swing application (java)
Current Time: Tue Jan 16 10:00:56 GMT 2018
Powered by FUDForum. Page generated in 0.03588 seconds
