Home » Archived » Voicetools » How to Download VTP 3.0 Source Code
Re: How to Download VTP 3.0 Source Code [message #497132 is a reply to message #497125] |
Thu, 12 November 2009 15:02 |
Randy Childers Messages: 121 Registered: July 2009 |
Jay, I think you're on the right track. Attached is the current
CoreTeamSet.xml -- we really need to host this somewhere publically, but
for now here it is.
Good luck,
Randy
In <hdh6sq$205$1@build.eclipse.org> wrote:
> Hello Randy,
> In this thread, you mention CoreTeamSet.xml. Where can I get a copy
> of this file? I'm trying to build VTP. Can you confirm if I'm on the
> right track so far: 1. checkout https://dev.eclipse.org/svnroot/
> technology/org.eclipse.vtp/F ramework/trunk/plugins/ 2. checkout https://
> dev.eclipse.org/svnroot/technology/org.eclipse.vtp/D esktop/trunk/
> plugins/ 3. In Eclipse, in a fresh workspace, use 'import existing
> projects into workspace' to import projects downloaded in steps 1 and
> 2 above.
> After step 3, there are build errors and I'm hoping CoreTeamSet.xml
> brings in the right settings to fix those errors.
> Jay
Re: How to Download VTP 3.0 Source Code [message #497383 is a reply to message #497132] |
Fri, 13 November 2009 04:46 |
No real name Messages: 7 Registered: November 2009 |
Junior Member |
Hi Randy,
The dtd referenced by CoreTeamSet.xml is not available it seems. Thus, import fails. The dtd referenced is: http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd
Is there another version of CoreTeamSet.xml?
I created a psf file by placing <psf>...</psf> portion of the xml file into a new file. I was then able to import the psf file, allowing Eclipse to connect using CVS and download many dependencies.
However, there are still many errors in the workspace. Errors are in org.eclipse.vtp.modules.attacheddata.ui, org.eclipse.vtp.desktop.model.interactive.core. Some dependencies are still missing. Some of the missing parts are BrandManager, ConfigurationException, IBrand, FormatterRegistration, FormatterRegistrationManager.
Jay
Re: How to Download VTP 3.0 Source Code [message #578820 is a reply to message #578805] |
for now here it is.
Good luck,
Randy
> Hello Randy,
> 2 above.
> Jay
Re: How to Download VTP 3.0 Source Code [message #663426 is a reply to message #483378] |
Tue, 05 April 2011 01:35 |
Carlitos Messages: 13 Registered: April 2011 |
Junior Member |
Hi all,
Is there a neat document that details the 1, 2, 3,... step-by-step instructions to download, build, and deploy VTP? I suppose a general description of the different plugins, etc. that make up the project would be useful as well. Trying to make sense out of all of these bit and pieces all over the place is a bit confusing! I worked on a similar framework for my previous company before and I'm willing to contribute to the advancement of VTP but first I must be able to download it, build it, and deploy it. I did take the OpenVXML studio and that is working fine but the VTP framework for eclipse I have not tried just because I do not feel there is a good document that shows HOW-TO. I may use this for an IVR solution at my current employer and so I have an incentive to make sure that it is production quality. Please help with providing all details on getting me started!
Carlos
PS: I do have subclipse setup and can take stuff via SVN;
Current Time: Thu Apr 25 03:41:28 GMT 2024
Powered by FUDForum. Page generated in 0.05010 seconds
