Home » Language IDEs » C / C++ IDE (CDT) » mingw: undefined reference to `WinMain@16'
mingw: undefined reference to `WinMain@16' [message #482026] Tue, 25 August 2009 07:36 Go to next message
Originally posted by: outskywind.hotmail.com
I am new to eclipse cdt, i installed the mingw and the eclipse c/c++
ide as reccomended , and set the bin in path right . However, i can get
the toolchain configured with eclipse , when i am compiling an easy c++
project to check it out, i got the problem:
here is the c++ projet :
#include <iostream>
using namespace std;
int main(void) {
cout << "hello, word" << endl;
return 0;
and the error shows £ºC:\MinGW\lib/libmingw32.a(main.o):main.c: undefined
reference to `WinMain@16'.
how can i get rid of this problem? and anyone who have eclipse with mingw
worked successfully could give me a detail guide how to set them ? i would
appreciate it very much!
my email : outskywind@hotmail.com.
Re: mingw: undefined reference to `WinMain@16' [message #482049 is a reply to message #482026] Tue, 25 August 2009 09:07 Go to previous messageGo to next message
Dmitry Smirnov is currently offline Dmitry SmirnovFriend
Member
What kind of project do you use?
I suppose, you should ensure that mingw is creating console program. Check with gcc/g++ options how to do this.
Re: mingw: undefined reference to `WinMain@16 ' [message #482134 is a reply to message #482049] Tue, 25 August 2009 13:24 Go to previous messageGo to next message
i see , but in eclipse c++ project menu , there are only two kinds :
makefile project and executable project... i choosed the makefile project.
and how should i set the gcc/g++ options right? thanks!
Re: mingw: undefined reference to `WinMain@16 ' [message #482202 is a reply to message #482134] Tue, 25 August 2009 16:57 Go to previous messageGo to next message
Member
This means that your project contains some makefile(s) that are processed by GNU make utility. Typically these files are called "Makefile" or have some extention like .mk.
Such file describe what and how to build. In this case you need to read make utility and mingw manuals.
Also you can try to get some help with
gcc --help
command.
it will tell you what options are supported by mingw GCC
Re: mingw: undefined reference to `WinMain@16 ' [message #482550 is a reply to message #482202] Thu, 27 August 2009 02:04 Go to previous messageGo to next message
i see that if i build the excutable c++ project , it will work well,and
it says " --library = mingw32 ". while when i build the makefile c++
project , i add that "creat makefile automatically" option.
in the objects.mk file the "LIBS := "is empty ,is this cause the error?
and someone says you should install Msys too if want to build makefile c++
project, is that ture ? and do you mean that i should write the makefile
myself?
Re: mingw: undefined reference to `WinMain@16 ' [message #482722 is a reply to message #482550] Thu, 27 August 2009 16:55 Go to previous messageGo to next message
Member
H-m, where did you find that "create makefile automatically"?
I meant, yes, you should create it by yourself. If there is some option to create it automatically, just try to add mingw32 to LIBS.
I'm not sure whether you need MSYS. If you have mingw, you most likely have all you need to build (i.e. make, gcc). Otherwise, you will get some error like "unable to run make" in Eclipse console.
Re: mingw: undefined reference to `WinMain@16 ' [message #482795 is a reply to message #482722] Fri, 28 August 2009 02:28 Go to previous messageGo to next message
Ah, in the properties menu,click the "c/c++ construction" mode , i see
"generate makefile" option.
yeah, i made the makefile myself,and it works :
CXXFLAGS = -O2 -g -Wall -fmessage-length=0
OBJS = say.o
LIBS =
TARGET = say.exe
$(TARGET): $(OBJS)
$(CXX) -o $(TARGET) $(OBJS) $(LIBS)
all: $(TARGET)
clean:
rm -f $(OBJS) $(TARGET)
and the eclipse console shows:
make all
g++ -O2 -g -Wall -fmessage-length=0 -c -o say.o say.cpp
g++ -o say.exe say.o
but,if i add "#pragma comment(linker, "/subsystem:console") " in my
sourcefile,without my makefile but using the"generate makefile
automatically" option,it works well too. so i have the idea there is
something missing in g++ link flags by default, and i saw someone add
"-Wl,-subsystem,console" as g++ link flag, what's that? and how could i
set the g++ link as console project,not win32 project.
thanks very much.
Re: mingw: undefined reference to `WinMain@16' [message #628930 is a reply to message #482026] Fri, 24 September 2010 18:46 Go to previous messageGo to next message
hoser is currently offline hoserFriend
For anybody who finds this from a search, as I did: Another way to achieve this error is by not saving your file. The build system uses the version of the file on disk, not in the editor buffer. If the disk version of the file did not have a main function, then there is no place for the local application to start. If you get this error, make sure you saved your file.
Re: mingw: undefined reference to `WinMain@16' [message #649388 is a reply to message #628930] Wed, 19 January 2011 03:04 Go to previous messageGo to next message
No real name is currently offline No real nameFriend
Excelent response. This is the way to solve the problem. Thank you.
Re: mingw: undefined reference to `WinMain@16' [message #787058 is a reply to message #628930] Tue, 31 January 2012 05:15 Go to previous messageGo to next message
Faez Shingeri is currently offline Faez ShingeriFriend
WAY to go Man..!!! TOOO GOOD... Smile
Struggled for two days with this prob... and finally simply saving the file was the SOLUTION..! Smile
Thanks alot
Re: mingw: undefined reference to `WinMain@16' [message #793149 is a reply to message #787058] Tue, 07 February 2012 20:38 Go to previous messageGo to next message
Ali Nematollahi is currently offline Ali NematollahiFriend
But sadly that doesn't help me Sad I save my file but I still get this error and I don't know how to get rid of it. Any ideas?
Re: mingw: undefined reference to `WinMain@16' [message #993732 is a reply to message #628930] Tue, 25 December 2012 09:23 Go to previous messageGo to next message
Alaa Albashar is currently offline Alaa AlbasharFriend
Thanx!!!
Exactly what I want Smile
Re: mingw: undefined reference to `WinMain@16' [message #998675 is a reply to message #628930] Thu, 10 January 2013 13:47 Go to previous messageGo to next message
Frederic Jeanmougin is currently offline Frederic JeanmouginFriend
It worked for me : I had this error because I forgot to save my "hello world" source file (because I was used to Visual C++ who do it automtically).
Re: mingw: undefined reference to `WinMain@16' [message #999094 is a reply to message #998675] Fri, 11 January 2013 10:27 Go to previous messageGo to next message
Axel Mueller is currently offline Axel MuellerFriend
Frederic Jeanmougin wrote on Thu, 10 January 2013 14:47
In Preferences->General->Workspace you can enable "Save automatically before build".
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Re: mingw: undefined reference to `WinMain@16' [message #1737286 is a reply to message #628930] Wed, 06 July 2016 23:04 Go to previous message
Christopher Keveny is currently offline Christopher KevenyFriend
Thank you friend. 2 hours it took before I found this.
For some reason the IDE at home prompts me to save, the IDE at work does not, so it threw me.
Previous Topic:Minimal Eclipse Neon C/C++
Next Topic:Problem with Template class and Code generation
Current Time: Wed Feb 21 21:44:55 GMT 2018
Powered by FUDForum. Page generated in 0.02559 seconds
