Home » Eclipse Projects » Eclipse Platform » [Debug] Use of org.eclipse.debug.internal.ui.viewers.*provisional as API
[Debug] Use of org.eclipse.debug.internal.ui.viewers.*provisional as API [message #481894] Mon, 24 August 2009 16:19 Go to next message
Christian Georgi is currently offline Christian GeorgiFriend
is it ok to use packages
org.eclipse.debug.internal.ui.viewers.model.provisional and
org.eclipse.debug.internal.ui.viewers.provisional as API? From what I have
seen during the last releases these packages have become stable, and JDT
debugging uses them already. Or are there plans to refactor them into usual
API packages?
Additionally I noticed that JDT uses internal classes like
org.eclipse.debug.internal.ui.model.elements.ElementContentP rovider in its
implementation. Are there plans to make these classes API as well? In
general, shouldn't JDT debug tooling be treated like any other client?
Currently it seems to me to be more equal than others.. ;)
Christian
Re: [Debug] Use of org.eclipse.debug.internal.ui.viewers.*provisional as API [message #481915 is a reply to message #481894] Mon, 24 August 2009 17:43 Go to previous message
Chris Aniszczyk is currently offline Chris AniszczykFriend
Christian Georgi wrote:
> have seen during the last releases these packages have become stable,
> and JDT debugging uses them already. Or are there plans to refactor
> them into usual API packages?
> its implementation. Are there plans to make these classes API as well?
> In general, shouldn't JDT debug tooling be treated like any other
> client? Currently it seems to me to be more equal than others.. ;)
I think asking this question on platform-debug-dev mailing list is a
better idea. In Eclipse, provisional API can still mean that the API may
change, so you have to becareful.
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Previous Topic:Overlay Icon
Next Topic:Fragment only works OK when app run from Eclipse
Current Time: Wed Jan 17 22:24:42 GMT 2018
Powered by FUDForum. Page generated in 0.01882 seconds
