Home » Eclipse Projects » GEF » ZoomManager reference for Zest GraphViewer
ZoomManager reference for Zest GraphViewer [message #481490] Fri, 21 August 2009 05:15 Go to next message
sridhar is currently offline sridhar
I am using Zest for visualization.I have a scenario where I need to
have zoom capabilities from toolbar of a editorpart.I have created form in
EditorPart.In the form I have created a toolbar for which I need zoom
capabilities.
Following is the code snippet:
viewer=new GraphViewer(parent,SWT.NONE);
viewer.setContentProvider(new MyContentProvider());
viewer.setLabelProvider(new MyLabelProvider());
viewer.setConnectionStyle(ZestStyles.CONNECTIONS_DIRECTED|Ze stStyles.CONNECTIONS_SOLID);
viewer.setLayoutAlgorithm(new
SpringLayoutAlgorithm(LayoutStyles.NO_LAYOUT_NODE_RESIZING)) ;
viewer.setInput(new Object());
toolbarZoomContributionViewItem = new ZoomContributionViewItem(this);
ToolBarManager tbMgr = new ToolBarManager();
tbMgr.add(toolbarZoomContributionViewItem );
Zoom options are working fine for contextmenu operations, but if I
want to get zoom options through toolbar by passing contribution item,its
not possible.
I found zoomTo() method in GraphViewer, but it do not work.
Is there any way to get the ZoomManager reference?
Re: ZoomManager reference for Zest GraphViewer [message #492284 is a reply to message #481490] Mon, 19 October 2009 14:43 Go to previous message
Casey Marshall is currently offline Casey Marshall
> This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
--B_3338805406_3394230
Content-type: text/plain;
charset="US-ASCII"
Content-transfer-encoding: 7bit
I ran into this exact same issue and fixed it in Zest. The contribution
item was not fetching the items from the zoom manager for managers other
than MenuManager, and also tool item control was not displaying correctly.
With this change, you won't need to get at the ZoomManager to make the
toolbar work.
Patch against Zest 1.1.0 attached.
Casey
On 8/21/09 4:15 AM, in article
95486b1b32480f00a238879b2c9a8580$1@www.eclipse.org, "sridhar"
<g_sridhar258@yahoo.co.in> wrote:
> capabilities.
> NS_SOLID);
> not possible.
Content-type: application/octet-stream; name="zest-toolbar-zoom.patch"
Content-disposition: attachment;
filename="zest-toolbar-zoom.patch"
Content-transfer-encoding: base64
ZGlmZiAtLWdpdCBvcmcuZWNsaXBzZS56ZXN0LmNvcmUvc3JjL29yZy9lY2xp cHNlL3plc3Qv
Y29yZS92aWV3ZXJzL1pvb21Db250cmlidXRpb25WaWV3SXRlbS5qYXZhIG9y Zy5lY2xpcHNl
Lnplc3QuY29yZS9zcmMvb3JnL2VjbGlwc2UvemVzdC9jb3JlL3ZpZXdlcnMv Wm9vbUNvbnRy
aWJ1dGlvblZpZXdJdGVtLmphdmEKaW5kZXggZjc5Mzg3Mi4uNjg3NGJjYyAx MDA2NDQKLS0t
IG9yZy5lY2xpcHNlLnplc3QuY29yZS9zcmMvb3JnL2VjbGlwc2UvemVzdC9j b3JlL3ZpZXdl
cnMvWm9vbUNvbnRyaWJ1dGlvblZpZXdJdGVtLmphdmEKKysrIG9yZy5lY2xp cHNlLnplc3Qu
Y29yZS9zcmMvb3JnL2VjbGlwc2UvemVzdC9jb3JlL3ZpZXdlcnMvWm9vbUNv bnRyaWJ1dGlv
blZpZXdJdGVtLmphdmEKQEAgLTExMSwxMyArMTExLDE3IEBAIHB1YmxpYyBj bGFzcyBab29t
Q29udHJpYnV0aW9uVmlld0l0ZW0gZXh0ZW5kcyBDb250cmlidXRpb25JdGVt IGltcGxlbWVu
dHMgWm9vbUxpCiAJICogICAgICBpbnQpCiAJICovCiAJcHVibGljIHZvaWQg ZmlsbChUb29s
QmFyIHBhcmVudCwgaW50IGluZGV4KSB7Ci0JCVRvb2xJdGVtIGl0ZW0gPSBu ZXcgVG9vbEl0
ZW0ocGFyZW50LCBTV1QuRFJPUF9ET1dOKTsKKwkJVG9vbEl0ZW0gaXRlbSA9 IG5ldyBUb29s
SXRlbShwYXJlbnQsIFNXVC5TRVBBUkFUT1IsIGluZGV4KTsKIAkJQ29tYm8g Y29tYm8gPSBj
cmVhdGVDb21ibyhwYXJlbnQpOwogCQlpdGVtLnNldENvbnRyb2woY29tYm8p OworICAgICAg
ICBpdGVtLnNldFdpZHRoKGNvbWJvLmNvbXB1dGVTaXplKFNXVC5ERUZBVUxU LCBTV1QuREVG
QVVMVCwgdHJ1ZSkueCk7CiAJfQogCiAJcHJpdmF0ZSBDb21ibyBjcmVhdGVD b21ibyhDb21w
b3NpdGUgcGFyZW50KSB7Ci0JCXRoaXMuY29tYm8gPSBuZXcgQ29tYm8ocGFy ZW50LCBTV1Qu
RFJPUF9ET1dOKTsKKwkJdGhpcy5jb21ibyA9IG5ldyBDb21ibyhwYXJlbnQs IFNXVC5EUk9Q
X0RPV04gfCBTV1QuUkVBRF9PTkxZKTsKKwkJaWYgKHpvb21MZXZlbHMgPT0g bnVsbCkgewor
CQkJem9vbUxldmVscyA9IHpvb21NYW5hZ2VyLmdldFpvb21MZXZlbHNBc1Rl eHQoKTsKKwkJ
fQogCQl0aGlzLmNvbWJvLnNldEl0ZW1zKHpvb21MZXZlbHMpOwogCQl0aGlz LmNvbWJvLmFk
ZFNlbGVjdGlvbkxpc3RlbmVyKG5ldyBTZWxlY3Rpb25BZGFwdGVyKCkgewog CQkJLyoKQEAg
LTEzNCw2ICsxMzgsNyBAQCBwdWJsaWMgY2xhc3MgWm9vbUNvbnRyaWJ1dGlv blZpZXdJdGVt
IGV4dGVuZHMgQ29udHJpYnV0aW9uSXRlbSBpbXBsZW1lbnRzIFpvb21MaQog CQkJCX0KIAkJ
CX0KIAkJfSk7CisJCWNvbWJvLnBhY2soKTsKIAkJcmV0dXJuIHRoaXMuY29t Ym87CiAJfQog
Cg==
--B_3338805406_3394230--
Previous Topic:Hook for GMF editor startup?
Next Topic:Highlighted border width
Current Time: Tue Oct 08 08:00:47 EDT 2013
Powered by FUDForum. Page generated in 0.01603 seconds
