Home » Eclipse Projects » Plugin Development Environment (PDE) » get the URI of a file selected
get the URI of a file selected [message #481341] Thu, 20 August 2009 14:43 Go to next message
guenin is currently offline gueninFriend
Member
I’m new in plugin development. I would like to get the URI of the file
when I right click on it to do some operations with it.
I have created a plug in and an extension org.eclipse.ui.popupMenus with
the template popupMenu to define the context menu. I obtained the class
here under.
How it is possible, in the function run to get the URI of the file
selected?
Thank you for your Help
Aurelie
public class NewAction implements IObjectActionDelegate {
* Constructor for Action1.
public NewAction() {
super();
* @see IObjectActionDelegate#setActivePart(IAction, IWorkbenchPart)
public void setActivePart(IAction action, IWorkbenchPart targetPart) {
* @see IActionDelegate#run(IAction)
public void run(IAction action) {
Shell shell = new Shell();
MessageDialog.openInformation(
shell,
"Monplugin Plug-in",
"Verif Ordo was executed.");
* @see IActionDelegate#selectionChanged(IAction, ISelection)
public void selectionChanged(IAction action, ISelection selection) {
Re: get the URI of a file selected [message #481345 is a reply to message #481341] Thu, 20 August 2009 14:48 Go to previous message
Originally posted by: aurelien.pupier.esial.net
You can get the selected element via the selection element in the method selectionChanged(generally take the first)
guenin a écrit :
> I�m new in plugin development. I would like to get the URI of the file
> when I right click on it to do some operations with it. I have created a
> plug in and an extension org.eclipse.ui.popupMenus with the template
> popupMenu to define the context menu. I obtained the class here under.
> selected?
> Aurelie
> super();
> shell,
Re: get the URI of a file selected [message #600869 is a reply to message #481341] Thu, 20 August 2009 14:48 Go to previous message
Aurélien Pupier is currently offline Aurélien PupierFriend
guenin a écrit :
> selected?
> Aurelie
> super();
> shell,
Aurélien Pupier - Red Hat
Senior Software Engineer in Fuse Tooling team
Previous Topic:ant unable to delete file
Next Topic:PDE Extension Points and Import Package
Current Time: Wed Feb 21 16:03:15 GMT 2018
Powered by FUDForum. Page generated in 0.01557 seconds
