Home » Modeling » EMF » EMF + CouchDB
EMF + CouchDB [message #479556] Tue, 11 August 2009 14:26 Go to next message
Roland Tepp is currently offline Roland TeppFriend
Has anybody implemented ResourceSet for persisting EMF models to CouchDB
yet?
Re: EMF + CouchDB [message #479557 is a reply to message #479556] Tue, 11 August 2009 14:35 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Roland,
I'm pretty sure that not. How can I know? Because one would extend
ResourceImpl to provide custom persistence in EMF ;-)
I don't know of any Resource implementation with support for CouchDB. Is
that an SQL DB?
There are two components of EMF that offer custom persistence:
1) Teneo --> http://www.eclipse.org/modeling/emf/?project=teneo
2) CDO Model Repository --> http://wiki.eclipse.org/CDO
Cheers
/Eike
> CouchDB yet?
Re: EMF + CouchDB [message #479558 is a reply to message #479557] Tue, 11 August 2009 14:48 Go to previous messageGo to next message
Hi Eike,
CouchDB is _not_ an SQL db, that is why I asked :)
Basically - CouchDB[1] is a database for storing arbitrary JSON documents.
It seems to me the the persistence model of CouchDB is pretty nice fit
for EMF persistence...
[1] http://couchdb.apache.org/
11.08.2009 17:35, Eike Stepper kirjutas:
> ResourceImpl to provide custom persistence in EMF;-)
> that an SQL DB?
Re: EMF + CouchDB [message #479566 is a reply to message #479558] Tue, 11 August 2009 15:00 Go to previous messageGo to next message
Roland,
A fundamental "problem" with JSON as a general serialization format for
EMF instances is lack of support for something equivalent to xsi:type.
When we deserialize we always need to know what type of object to create
to hold the subsequent data. Certainly we can always try to create an
instance of the feature's type, but often the actual serialized instance
is a subtype of the feature's type and we need to know that up front.
This makes JSON a poor fit for representing strongly/explicitly typed
instances without some additional conventions...
Roland Tepp wrote:
> Hi Eike,
> documents.
>> that an SQL DB?
Re: EMF + CouchDB [message #479570 is a reply to message #479566] Tue, 11 August 2009 15:17 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
There are JSON-Serialization formats (in end this are common rules) who
store the value of the type in a "special" feature like (@type :
"com.bla.Bla").
E.g. jersey serializes/deserializes JSON-Data with the help of this IIRC
giving you the possibility to use your objects in REST very easy :-)
Tom
Ed Merks schrieb:
> Roland,
> Roland Tepp wrote:
>> Hi Eike,
>> documents.
>>> that an SQL DB?
Re: EMF + CouchDB [message #479579 is a reply to message #479570] Tue, 11 August 2009 15:45 Go to previous messageGo to next message
Andre Dietisheim is currently offline Andre DietisheimFriend
I am working in a similar setup. I have an EMF Model im my Eclipse
client (RCP) and I communicate on behalf of ECF-REST with a
REST-Service, that wants json. I therefore experienced these limitations
and tried to get rid of them. I'd like to share what I found out so far:
A possibility to overcome the limited types-set would be a json-scheme,
as proposed here:
http://json-schema.org/
I'm not quite sure, but I thought jackson already supports this.
The other limitation, that is the lack of references is covered by
another proposal, json referencing:
http://www.json.com/2007/10/19/json-referencing-proposal-and -library/
http://www.jspon.org/
http://www.sitepen.com/blog/2008/06/17/json-referencing-in-d ojo/
I don't know of any java library that supports this, but might be a good
starting point to research possibilities.
Cheers
André
Tom Schindl wrote:
> "com.bla.Bla").
> Tom
> Ed Merks schrieb:
>> Roland,
>> Roland Tepp wrote:
>>> Hi Eike,
>>> documents.
>>>> that an SQL DB?
Re: EMF + CouchDB [message #479656 is a reply to message #479579] Tue, 11 August 2009 21:00 Go to previous message
Just a few word to another possible solution:
Use Xtext to declare the grammar of your object model. Doing so, you
declare the mapping that rules your Ecore/Json. Xtext has a custom
resource implementation that stores the instances in your own json based
DSL. Of course, the Xtext resource stores to files like the default
resource does. Extend this one to use CouchDb instead of files shoudn't
be too hard, I guess.
I just needed the serialization/de-, not a plain persistence solution. I
did a PoC using Xtext and I was pretty amazed by its slickness.
Cheers
André
Ande Dietisheim wrote:
> Hi
> as proposed here:
> Cheers
> André
> Tom Schindl wrote:
>> "com.bla.Bla").
>> Tom
>> Ed Merks schrieb:
>>> Roland,
>>> xsi:type. When we deserialize we always need to know what type of
>>> object to create
>>> Roland Tepp wrote:
>>>> Hi Eike,
>>>> documents.
>>>>> CouchDB. Is
>>>>> that an SQL DB?
Previous Topic:grouping containments for tree ui - unnecessary?
Next Topic:replace gen Date instead of XMLGregorianCalendar
Current Time: Thu Apr 26 10:05:55 GMT 2018
Powered by FUDForum. Page generated in 0.01666 seconds
