Home » Modeling » OCL » OCL, AnyType and FeatureMaps
OCL, AnyType and FeatureMaps [message #479054] Sat, 08 August 2009 16:09 Go to next message
Derek Palma is currently offline Derek PalmaFriend
I have been using OCL to query all EMF models in my system. I ran into an
issue when I tried to query models with AnyTypeImpl. Its interface, AnyType,
is defined in com.eclipse.emf.ecore.xml.type. AnyType contains some feature
maps.
public interface AnyType extends EObject {
FeatureMap getMixed();
My problem is that I cannot query the contents of the FeatureMap with OCL.
Assuming self == the AnyType instance
self.mixed.<something in FeatureMap> does not seem to work. For every
feature name in the FeatureMap I give it it complains about an unrecognized
variable. self.mixed returns the featureMap, however.
Is query FeatureMaps supported as they are defined here? If yes, how should
the OCL look?
Derek
Re: OCL, AnyType and FeatureMaps [message #479097 is a reply to message #479054] Sun, 09 August 2009 06:19 Go to previous message
Ed Willink is currently offline Ed WillinkFriend
Hi Derek
I'm pretty sure that there is no support for FeatureMaps, but it is
possible that there is an extension that I'm not aware of.
I don't think that there is any easy backdoor approach, since
EFeatureMap is an EDataType rather than an EClass, so there are no
operations visible to OCL.
Explicit support for FeatureMaps in OCL is unlikely any time soon since
there is no counterpart in EMOF.
I think that your best approach is to develop an EcoreHelper class that
provides maybe a getFeatureMapEntryKey(EFeatureMap, String) method that
can be invoked from OCL. Feel free to contribute the result.
Ed Willink
Derek Palma wrote:
> an issue when I tried to query models with AnyTypeImpl. Its interface,
> AnyType, is defined in com.eclipse.emf.ecore.xml.type. AnyType contains
> some feature maps.
> OCL. Assuming self == the AnyType instance
> unrecognized variable. self.mixed returns the featureMap, however.
> should the OCL look?
> Derek
Previous Topic:OCLExpressions
Next Topic:New to EMF and OCL
Current Time: Sun Feb 18 22:46:45 GMT 2018
Powered by FUDForum. Page generated in 0.01505 seconds
