Re: preventing exit code window [message #480688 is a reply to message #478948] |
Tue, 18 August 2009 08:42 |
If your application based on workbench, There is no way to override
return code in general approach.
But, System.exit() is much worse idea. It can cause a lot of data loss.
So, I suggest alternative way:
IWorkbench bench = PlatformUI.getWorkbench();
Method closeMethod =
bench.getClass().getDeclaredMethod("close", int.class, boolean.class);
closeMethod.setAccessible(true);
closeMethod.invoke(bench, YOUR_RETURN_CODE, true);
Jörg Kiegeland wrote:
> If my rcp application executes System.exit(1), then the typical window
> with the message "JVM terminated. Exit code=1 ..[startup parameters]"
> appears. How can I prevent this window from being displayed?
> As you may ask now why I use exit codes: another program starts the rcp
> application and evaluates the exit code after the rcp is closed by the
> user. This other program allows communication only by exit codes. The
> exit code returned by the RCP depends on what the user did.
Re: preventing exit code window [message #500716 is a reply to message #480688] |
Fri, 27 November 2009 16:36 |
Dawid Kostrzycki Messages: 5 Registered: July 2009 |
Junior Member |
is it possible to suppress this popup window being displayed if my
command line RCP application is NOT based on workbench ?
best regards
Dawid
Am Tue, 18 Aug 2009 17:42:23 +0900 schrieb Jiyul:
FUDForum. Page generated in 0.02732 seconds
