Home » Newcomers » Newcomers » Plug-in not in the plug-in registy
Plug-in not in the plug-in registy [message #478868] Fri, 07 August 2009 10:06 Go to next message
saurav sarkar is currently offline saurav sarkarFriend
Hi All,
I have developed a plug-in and exported it.
Then i had put the plug-in in the plugins directory of the eclipse.
I could not find the plug-in in the plugin registry.
I can find the plug-in in the plugins view.
May be i dont have the full concept of plugin registry.
Please provide your inputs here.
Thanks and Regards,
Saurav
Re: Plug-in not in the plug-in registy [message #478911 is a reply to message #478868] Fri, 07 August 2009 12:50 Go to previous messageGo to next message
Suarav,
These days you should be putting it into the dropins folder if you're
adding it later. You might use -clean -debug as flags when starting and
then look at the <workspace>/.metadata/.log for clues why your plugin
might not be activated (because of missing dependencies for example).
saurav wrote:
> Hi All,
> Thanks and Regards,
> Saurav
Re: Plug-in not in the plug-in registy [message #478986 is a reply to message #478868] Fri, 07 August 2009 19:52 Go to previous messageGo to next message
Lars Vogel is currently offline Lars VogelFriend
have a look here for an example including how to import it into Eclipse
3.5. http://www.vogella.de/articles/EclipsePlugIn/article.html
Best regards, Lars
saurav wrote:
> Hi All,
> Thanks and Regards,
> Saurav
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
Re: Plug-in not in the plug-in registy [message #479551 is a reply to message #478986] Tue, 11 August 2009 14:36 Go to previous message
Thanks Lars and Ed for your helpful replies.
I could find out the major reasons were the dependencies were not properly
loaded.
Thanks again.
cheers,
Saurav
Previous Topic:HowTo: Add Text under the Image in Action of ToolbarManager?
Next Topic:Eclipse doesn't compile anything
Current Time: Thu Jun 21 03:19:25 GMT 2018
Powered by FUDForum. Page generated in 0.03077 seconds
