Home » Archived » Memory Analyzer (MAT) » Error during the parser
Error during the parser [message #478850] Fri, 07 August 2009 09:00 Go to next message
roger is currently offline rogerFriend
Hi guys,
While I am trying to open one dump file, actually after the parser the
following
error appears.
Do you have any similar experience regarding the issue?
"Extracting Biggest Objects" has encountered a problem.
Dominator tree now available. Delete indices and parse again.
I am using IBM JDK 1.4.2 SR12 and zipped dmp file.
Thank you guys.
Best Regards
Roger
Re: Error during the parser [message #480162 is a reply to message #478850] Fri, 14 August 2009 08:32 Go to previous messageGo to next message
Andrew Johnson is currently offline Andrew JohnsonFriend
Are there any messages in the error log? (See menu items 'Window' 'Error Log' )
Re: Error during the parser [message #535047 is a reply to message #480162] Fri, 21 May 2010 07:52 Go to previous messageGo to next message
Baris Evrim Demiroz is currently offline Baris Evrim DemirozFriend
I am having the same error. When I look at the error log it only shows:
"Dominator tree not available. Delete indices and parse again."
Any update on the subject?
[Updated on: Fri, 21 May 2010 07:53]
Report message to a moderator
icon12.gif  Re: Error during the parser [message #535051 is a reply to message #478850] Fri, 21 May 2010 07:58 Go to previous message
I found the cause of this problem. If a previous parsing of a heap dump is not completed, it leaves some files in a corrupt state in the same directory with the heap dump. Deleting those intermediate files will solve the issue.
Previous Topic:Dumping Memory when VM Heap size is not at maxmemory
Next Topic:MAT on Solaris: SWT not found
Current Time: Sat Jun 23 17:44:24 GMT 2018
Powered by FUDForum. Page generated in 0.01553 seconds
